13583 posts / 0 new
FW3A Team
FW3A Team's picture
Last seen: 1 week 11 hours ago
Location: This is not a real account. Contact Neal for support instead.
FW3A
F Fritz
W Works/Werke
3 triple
A Aluminium
A compact, ergonomic, feature-packed EDC-style light.
Current status (2019-08-07): New flavors are available for order or pre-order: Bare aluminum, TK Purple, Blue, Military Green, polished copper, bead-blasted copper, titanium, and titanium+copper. The “TK Purple” version has a stylized moonbeam logo on the button, and a portion of the sales from it will be sent to ToyKeeper.
Coupon codes are:
  • Colors: BLFFW3A 20%OFF
  • Copper (FW3C): BLFFW3C 15%OFF
  • Titanium (FW3T): BLFFW3T 20%OFF
… and for a short time, there is a private 25% off coupon available for people who already bought a FW3A and post pictures of it in this thread.
Current status (2019-06-12): The SST-20 version is available to order now, and the tint bin is FA3.
The coupon codes at Neal’s Gadgets are “NDFW3A” and “BLFFW3C”. These work for the aluminum version (FW3A) and the copper version (FW3C), respectively.
Proto4 units have been reviewed:
To sign up: No need. Just order what you want. The interest list is closed and not necessary any more.
A pic of proto4, photographed by Maukka. Click to see full review:
A word of warning for BLF specials:
The BLF part is done by BLFers who do it in their spare time, despite they may seem professionals and the work they do is at professional level, BLF is not our full time job. So give us a break and relax if thing are not going as fast as you want.
Nothing is sure so expect waiting:
- Waiting for news and updates.
- Waiting for the project to come to fruition.
- Waiting till the result can finally be ordered.
- And then waiting for arrival at your home, shipping from China can take a long time.
So relax, enjoy the many other facets of BLF while you wait and remember:
It is done when it is done Smile
Computer renders of the light:
Original design in bare aluminum:
Updated design with bead-blasted surface and light grey anodizing:
The production model is expected to be like this second picture, only in dark grey.
The FW3A is a collaboration between TLF (Germany) and BLF (global). Fritz15 made a small triple flashlight on his lathe. TLF reacted very positively and at first a small hand made batch would be pursued. But this elegant design screams for a wider audience, so it became something bigger.
An unusual feature is the electronic tail switch. This allows the light to do much fancier things than a clicky switch, yet retains the ergonomic benefits of a clicky tail switch.
Team
  • Fritz15: Design
  • Tommy TLF: General TLF communication
  • DEL: Driver
  • Tom E: Firmware (originally), driver
  • ToyKeeper: Firmware / UI, BLF gardening
  • The Miller: General BLF communication
  • pepinfaxera: Interest list management
  • MRsDNF: Early prototyping
  • Neal: Retail service, coordination with Lumintop
  • Lumintop: Manufacturing
The FW3A
Small elegant EDC triple flashlight designed by Fritz15
  • Runs on a single 18650 battery.
  • 92.5 × 25.5 mm: Unusually small for an 18650 light — about the size of a SK-68 (1xAA).
  • Battery size: 18mm x 65mm (66mm maximum). Protected cells won’t fit.
  • Tail e-switch.
  • Wide range from ~0.3 lm to ~2800 lm.
  • Regulated output up to ~900 lm.
  • Fancy yet easy UI.
  • Nice clip firmly attached.
  • Good ergonomics.
It’s meant to be a good all-around EDC light, something to be used heavily.
Second prototype:
First prototype:
Size reference:
Size and color reference (the production model is dark grey, in the center):
Looks
The original plan was clear anodized aluminum complete with the original machining marks, but after three rounds of prototypes this did not happen. The attempts did not turn out as desired. So, based on forum feedback, the plan is to do dark grey anodizing instead. It is also possible that a bare unanodized version could be made later, but this remains to be determined.
No marking/logo for a clean look
Custom-designed stainless steel clip
Machined steel button on the tail:
Pricing
Target $30 including shipping, manufacturer can decide own pricing afterwards.
Maybe $36 if XP-L HI emitters are used.
Not fixed yet!
Emitters
3 pieces 3535 footprint
XP-L HI 3D (~4875K), SST-20 4000K 95CRI, or maybe Samsung LH351D 4000K 90CRI (if it can be obtained)
LEDs mounted on DTP triple star
Emitter Comparisons:
Price Lumens Throwiness CRI Beam Heat
Cree XP-L HI $36 2800? **** 70+ ****
Luminus SST-20 $30 2400? ***** 95+ ****
Samsung LH351D $30 2800? * 90+ ****
For price and heat, lower values are better. Throwiness depends on personal needs and taste. For everything else, higher values are better.
Throwiness is a rough measure of candelas per lumen. It’s the overall beam shape. Even the throwiest option is not a thrower, because compact triples are floody by nature. At a guess, the range here is about 2 to 4 cd/lm, and common reflector-based EDC-style lights are usually about 5 to 10.
Beam is the overall beam quality, like smoothness and color consistency.
More peppers makes thermal management harder, reduces the sustainable brightness after step-down, and increases risk of damaging the emitters on turbo.
Values indicate approximate performance in a Carclo 10511 optic using a FET for direct drive on 1×18650. These have not been directly tested in the FW3A host, so this data is more of an educated guess than a measurement.
All of the emitter types are good, but here is the worst part about each:
  • XP-L HI: Costs more. Medium CRI.
  • SST-20: Green at low levels.
  • LH351D: Super floody. Green at low levels. May be unobtainable.
Visual estimate of the floodiest option compared to a throwy option:
Internals
Integrated LED shelf for good thermal dissipation.
Driver retainer ring.
Threads square or trapezoidal (not triangular) for connection head and body
Electronic switch in tail with stainless steel button
Double tube to connect the electronic switch to the driver
Optics
Triple TIR optics http://www.carclo-optics.com/optic-10511 , easily replaced with other common models if desired.
Glass AR coated lens 23.0 mm x 1.5 mm (original spec was 2.25mm thick)
More info in post #3 below.
Protective
O-rings at lens, bezel, both ends of body tube, clip (to keep it from spinning), and inner tube (to isolate it from the outer tube). Button uses rubber boot internally to block water ingress, with metal cap on the outside. Set of spare O-rings in box.
Smooth thermal regulation to avoid overheating. However, turbo is a burst mode only, and the user should use it only for short periods instead of relying on thermal regulation to prevent heat damage. Full turbo is powerful enough to start fires in just a few seconds, especially when aimed at dark-colored materials.
Packaging
Cardboard with protective foam:
Quality Control
Lights made as specified and agreed upon.
Samples as specified and agreed upon for the team before the go is given for actual production.
All lights tested before shipping to spot and fix problems and avoid DOA. (turn on, ramp up and down, if not working properly factory fixes problems so all receive a good working light.)
TLF BLF cooperation
This light is a joint project between TLF and BLF.
For German speakers, use the TLF threads:
For English speakers, use this thread, right here on BLF.
FAQ
When will it be available?
  • Orders began on 2019-04-26.
How can I get one? What is the ordering process and payment method?
  • The interest list is closed, so if you didn’t get a private message with purchase instructions, it’s too late now. But it can still be purchased at retail price through Neal’s shop, and should also be available later from Lumintop.
Will there be a 18350 version / 18350 tube?
  • No. The entire back half of the light would need to be redesigned/replaced.
Will there be an empty host version?
  • Probably not. The only components which aren’t custom are the LEDs and optic.
Can I buy spare parts, like an extra driver or clip?
  • Not yet determined.
How does the FW3A compare to the Emisar D4?
  • FW3A advantages: Slightly smaller, lighter, nicer clip, metal tail switch, higher regulated modes, cheaper (probably), much fancier firmware.
  • D4 advantages: Sturdier, more emitter/optic/host choices, rubber side switch, higher turbo modes, available from mid-2017, also comes in throwy D1/D1S flavors.
Old News
2019-05-19: Neal reports that all orders have shipped, except for a couple orders with address problems. He’s contacting people individually about that. There is no news about SST-20 yet, but Neal will make sure people know about it when it’s ready.
2019-05-08: Orders which haven’t shipped yet may be delayed a bit. Neal and his wife are having a baby and he texted from the hospital to let us know he won’t be at work for a little while.
2019-04-28: The interest list is closed so no more requests are being accepted. Orders are still in progress. The SST-20 4000K version should be available to order soon. Shipping for most orders should start on May 8.
2019-04-26: Ordering starts today! Details are posted here and quoted below:
Quote:
Some info about the ordering process… Sorry for the short notice! I thought we would have more warning before ordering was ready to start.
The plan is:
At around the following time when Bluzie and I are both available…
  • 19:00 UTC
    • 12:00 west coast US
    • 15:00 east coast US
    • 16:00 Sao Paulo
    • 20:00 London
    • 21:00 TLF/Berlin
    • 03:00 Beijing
    • 05:00 Australia
    • 07:00 NZ
… people should start receiving private messages on BLF and TLF with the order URL and coupon codes. On BLF, the message should come from “FW3A Team”.
Messages will be spread out over time, so it will probably take 24 to 48 hours to get through the entire interest list. This is to make it easier for people early on the list to order before people later on the list.
After you receive the message, follow the link to Neal’s shop and order the items you want. Please do not post any coupon codes in public though, for at least a week afterward.
If you want to make your ordering process go faster, it may help to create an account on Neal’s site first.
2019-04-22: Production samples have started to arrive, and results so far look good. If nothing goes wrong, sales should start soon.
2019-04-11: Production samples are being sent to one person at TLF and two people at BLF for final testing, and then hopefully sales will start. Some extra details…
  • Estimated price is $36 for XP-L HI, or $30 for other emitters.
  • Emitters are XP-L HI 3D (~4875K) for now, and then probably SST-20 4000K 95CRI soon, and with any luck, also LH351D later.
  • The lights are Aircraft Grey in color. (medium grey with a slight hint of blue)
  • Group buy lights should be entirely free of markings and logos. After the group buy, Lumintop will probably sell a branded version with their bunny logo on the tail.
  • Unanodized bare aluminum might happen later, but this isn’t determined yet.
2019-01-31: Proto4 had an issue with the driver cavity being too small. Needs to be fixed before production.
2019-01-29: Proto4 samples have started to arrive.
2019-01-28: Production samples begin to arrive tomorrow for testing/review. Production should start within days, if things go well.
2018-11-28: Trying to get production started.
2018-09-17: Third (final?) prototypes arrived, waiting for test results from Fritz and Cawi.
2018-06-22: Second prototypes tested, emitter poll results collected, sending in feedback for host changes and emitter type(s). Only a few product details left to finish before production.
Poll (2018-06-08): Voting is open for emitter details: (results: the top choices were XP-L HI 3D and LH351D 4000K)
2018-06-08: Second prototypes arrived, many things are fixed, only a few things left to finish.
2018-06-03: Lumintop made a second prototype, hoping it’ll arrive soon for testing.
Poll (2018-04-19): What UI style do you want for muggle mode?
Results (2018-06-03): By popular choice, smooth ramp is now implemented for muggle mode.
  1. Smooth ramp (Condorcet winner: wins contests with all other choices)
  2. 3-mode Baton (loses to Smooth ramp by 66–36)
  3. 1-mode (loses to Smooth ramp by 71–31, loses to 3-mode Baton by 63–31)
  4. None (loses to Smooth ramp by 72–34, loses to 1-mode by 57–38)
  5. 3-mode clicky (loses to Smooth ramp by 80–22, loses to None by 51–47)
2018-04-17: Waiting on Lumintop to make second set of prototypes based on feedback from first batch.
2018-02-22: “FW3A Team” account created, thread ownership changed, so now updates can be posted again.
2018-12-xx: The first round of LT prototypes arrived. Details are posted in the thread around that time, and also a little bit in the OP.
2017-11-ish: The Miller is taking some time away from BLF to deal with real-life matters. Tom E has also been too busy to be on BLF much. ToyKeeper is filling in for both… for Tom since 2017-11, and for The Miller since 2018-04.
2017-07-20: Exciting news!
http://budgetlightforum.com/comment/1155360#comment-1155360
With the active support from Neal we finally found a new partner for our project and the progress is far enough to reveal the name: Lumintop
Change Log
2019-04-28: The interest list has been closed.
2019-04-26: Orders have started. Only a day or so left to get on the interest list.
2019-04-11: Updates in post #1 and #3.
2019-03-31: Added emitter comparison table.
2019-02-25: Updated lumen specs based on maukka’s measurements
2019-01-31: Added production sample pics, and links to reviews
2018-11-28: First post updated to reflect recent news.
2018-10-05: Current status updated. Not sure what the status is for the latest prototypes.
2018-06-22: Updated spec for optics and O-rings, added note about thermal regulation. Moved emitter type polls down to old news.
2018-06-08: Proto2 info added/updated.
2018-06-03: Updated FAQ, closed muggle mode poll, second prototype confirmed to exist (via potato pics), filled in some missing “old news”.
2018-04-24: Added newer model render with tapered tube.
2018-04-19: Muggle mode poll created.
2018-04-17: First post updated, small FAQ added.
2018-04-05: Moved interest list to its own first-page post.
2018-04-03: Added firmware/UI info to its own first-page post.
… (some team changes happened) …
06.05.2017: ordering of triples and optics for some testing
06.05.2017: revision of the driver draft with Tom and DEL
04.05.2017: publication of the project
FW3A thread – contact Neal on BLF or email for FW3A questions and support
Edited by: FW3A Team on 08/07/2019 - 16:49
FW3A Team
FW3A Team's picture
Thanks Wrathbringer27 for the translation!
FW3A
Small elegant EDC triple flashlight designed by Fritz.
Chinese: Fritz设计的小巧优雅的EDC三重手电筒。需要一个 18650 大小的电池操作
Looks
Clear anodisation (no pigments) and NO sanding or sandblasting of the parts after machining.
This makes the FW3A look like it came of a lathe of a skilled machinist with the added protection anodisation offers to keep it beautiful for a long time.
Stainless steel clip
Chinese:
外观:
机械加工后清除阳极氧化(没颜料)和没有打磨或喷砂。
这使得FW3A看起来像是熟练机械师的车床,增加了阳极氧化保护的优点,使其长时间保持美观。
没有标记/标志,干净的外观
不锈钢夹
Pricing
Chinese:
价格:
30美元包括运费,制造商可以自行决定自己的定价
Emitters
Cree XPG3 NW
Chinese:
发射器
3 个 3535 footprint 大小的led
Cree XPG3 NW
Led 安装在 DTP 三星上
Internals
20 AWG Wires.
Threads square or trapeziod (not triangular) for connection head and body
Double tube to connect the electronc swich to the driver
Chinese:
集成LED灯架,散热好
20 AWG线。
驱动器固定环。
螺纹方形或梯形(不是三角形)用于连接头部和身体
电子开关尾部带不锈钢按钮
双管将电子开关连接到驱动器
Optics
Optics
Triple TIR optics http://www.carclo-optics.com/optic-10507 (link is external)(link is external) (link is external)
Glass AR coated lens 2,25mm thick
Chinese
光学
三重TIR光学http://www.carclo-optics.com/optic-10507 (link is external) (外部链接)
AR玻璃涂层透镜厚度为2,25mm
Protective
2 x O-ring bezel, perfect fit
Chinese:
保护
2 x O形圈表圈,完美契合
发货前所有的灯都必须经过测试,以便可以发现和修复问题,避免DOA。 (打开,亮度调整,如果不能使用,工厂需修复问题,确保都能获得良好的灯)
FW3A Team
FW3A Team's picture
Some extra info about the light…
FW3A Interface
The FW3A uses the Andúril‎ firmware by ToyKeeper. It is similar to Tom E’s fantastic NarsilM, but with some extras.
Basic usage is very simple: Click for on/off, hold to change brightness. But there’s much more available for those who want it.
This is the UI diagram for it, showing most of the functions:
The interface uses mostly the same ramping as Narsil, and basic usage is identical. Click to turn the light on or off, hold the button to change brightness. However, this style applies to both the smooth ramp and the mode group, and the user can switch between them with three clicks while the light is on. No need to remember two interfaces or navigate a config mode.
Ramping also has some additional usability tweaks. If the user holds the button, ramping will always go up unless the button was released less than a second ago or it’s already at the top. To ramp down without ramping up first, do a “click, release, hold”. This eliminates the need to remember which way it was ramping in the past.
Both the smooth ramp and mode group are configurable. The user can set the lowest level, the highest level, and (mode group only) the number of steps. Full turbo is still available via double-click even if the ceiling is set somewhere more sensible.
While on, a double click toggles between turbo and the memorized level. So, if you hear a noise and want full power for a moment, double click. When you’re done, double click again to return to the original brightness.
Two groups worth of blinkies are included. To reach them, do “click click click” from off or a “click click hold”. These include:
  • Group 1: (always starts at battcheck)
    • BattCheck: Show remaining charge in volts and tenths.
    • Sunset: Start at “low”, then slowly ramp down to moon for an hour, then turn off.
    • Beacon: Blink once every N seconds at the last-ramped level. N is configurable.
    • TempCheck: Show current temperature and optionally configure settings for thermal regulation.
  • Group 2: (remembers the last-used mode)
    • Bike flasher: Steady output with a “stutter” once per second. Adjustable brightness.
    • Party strobe: Motion-freezing strobe. Adjustable speed.
    • Tactical strobe: Bright, disorienting strobe. Adjustable speed.
    • Lightning storm: Exactly what it says on the tin. No adjustments available.
    • Candle: Simulates a flickering candle or fireplace. Adjustable brightness. Also works as a self-shutoff timer in 30-minute increments.
A few other modes are available by clicking even more times from off:
  • 4 clicks: Soft lockout. Light won’t turn on until it’s unlocked. This mode doubles as a momentary moon mode, so when the button is held down it’ll light up at the current ramp floor. This is handy for checking something quickly without having to unlock the light.
  • 5 clicks: Momentary / signalling mode. Using the last-ramped brightness, the light will be on when the button is held, or off otherwise. Good for Morse code and such. To exit this mode, physically disconnect power (unscrew the light).
  • 6 clicks: Muggle mode. An extremely simple interface with a limited brightness range — ~10 lm to ~300 lm, with smooth ramping and no blinkies. Persists after a battery change. To exit this mode, quickly click exactly 6 times.
Some features which aren’t visible on the diagram:
  • Low voltage protection will reduce the brightness when the battery is low. If the brightness is already down all the way, it will shut the light off entirely.
  • Thermal regulation keeps the light from overheating. It’s not normally visible by eye though; it ramps smoothly across 512 internal steps to adjust output while it searches for the highest level it can maintain without overheating.
  • By default, the ceiling is set to the highest fully-regulated output level — 3 Amps. This is about 1000 lumens. Full turbo is about 3000 lumens, but cannot be sustained for long due to the heat it creates.
There are also some other interfaces available for this hardware, but it requires the user to flash different firmware. You can make it work like a BLF Q8, or like an Olight, or like a Zebralight, for example. However, these are not tested and not officially supported.
Driver
The FW3A uses a FET+7+1 driver.
So, three power channels:
  • 1xAMC7135 chip for 0 to 350mA
  • 7xAMC7135 chips for 350mA to 2.8 A
  • FET for 2.8 A to full power (direct drive)
This keeps most of the levels pretty stable and reasonably efficient, as far as linear drivers go. But it still has a direct drive circuit for turbo.
In a totally non-scientific qualitative manner, the overall efficiency curve compared to a constant current linear driver looks something like this:
LEDs also change tint according to the power level. This driver attempts to minimize that effect by blending power channels, but it may still be noticeable. The curve for that looks roughly like this:
Optics
The optic is a Carclo 10511, which is a lightly frosted optic with a relatively narrow spot. It gets almost as much throw as the 10507 optic, but with greatly reduced tint shift and artifacts.
BLF user maukka measured this in great detail in his review, which is quoted here:
maukka wrote:
Beam angle comparisons between three Carclo optics,
10508 (Medium Spot Frosted) – This was installed in my light when I got it
10511 (Narrow Spot Frosted) – Default optics in the production light
10507 (Narrow Spot Plain) – Clear optics with throwiest beam but more artifacts
Throw comparison (edit: 2019-02-12, fixed wrong cd for 10507 and 10511)
Color temperature shift within the beam. Limited to 2% output, that’s why 10511 and 10507 only cover up to 31°
Duv comparison. (Green-magenta axis)
Tint deviation (deltaxy). How much does the tint change within the beam. This illustrates the 10507 color artifacts the best as it has a big shift right in the bright part of the beam. The further from the hotspot the shift is, the less noticeable it is.
FW3A Team
FW3A Team's picture
Interest List
The list is closed, so this is the final set of requests. It’s not getting any more updates.
TLF adds about 450 lights to the list below.
BLF list:
1670 people, 2479 lights.
Requests:
People:
  • 1 -Rick-: 92
  • 1 -X3-: 23
  • 1 .-’_: 1275
  • 3 10fold: 902, 1535, 1536
  • 1 18000bph: 890
  • 1 1C3: 422
  • 1 1LL1: 1922
  • 1 2 DOGS: 537
  • 1 240: 2001
  • 1 264: 113
  • 1 2Ace: 285
  • 1 2Rowdy: 2373
  • 2 3061fps: 1418, 1995
  • 2 3WangDangler: 2387, 2388
  • 1 4492011: 2404
  • 1 4everAwake: 517
  • 1 7YP160214: 2389
  • 4 808Hi: 1028, 1033, 1034, 1039
  • 1 94Z28: 1072
  • 1 AEDe: 110
  • 1 ARMS.AARON: 735, 1376, 1376
  • 1 Aardvark: 1911
  • 1 Abe87: 546
  • 1 Abqjohnny: 3
  • 1 AcIDsNaZz: 1451
  • 4 ActiveAl: 1239, 1245, 2343, 2344
  • 1 Adam706: 2055
  • 4 Adhara: 1729, 1730, 1731, 1732
  • 1 Ag76: 239
  • 1 AgentSteel: 323
  • 1 Agiri: 238
  • 1 Aleister: 1525
  • 0 AlexGT: 961, 961
  • 1 AlexHH: 139
  • 1 AlexLED: 369
  • 1 Alldale: 2435
  • 2 Alumenator: 1091, 1092
  • 1 Alux: 575
  • 1 Andybibbville: 49
  • 2 Angel Martínez: 736, 760
  • 2 Animisk: 1565, 1566
  • 1 Anthon: 78
  • 2 Archangel72: 1557, 1558
  • 2 Archibald: 2245, 2362
  • 1 Arlau94: 2460
  • 2 Asian8640: 2024, 2025
  • 4 Astromanic: 588, 589, 693, 694
  • 3 Athlon2350: 1185, 1186, 1187
  • 1 Atom00: 1277
  • 2 Attackhorse: 1961, 2301
  • 1 Aulic458155: 1207
  • 1 Aussie78: 1251
  • 1 Awdtsi: 228
  • 1 Azza: 1532
  • 1 B42: 320
  • 1 BDM: 257
  • 3 BT100: 1000, 1051, 1150
  • 1 BadWolf: 1523
  • 2 Bam35: 30, 772
  • 1 Bangarangy: 1827
  • 1 Batch1: 904
  • 1 BazzH: 1093
  • 1 Bd7: 1313
  • 4 BeardedRaleigh: 286, 570, 937, 938
  • 1 Benidin: 877
  • 1 Bentakemoto: 1947
  • 1 Bervilat: 1257
  • 4 Bevo: 192, 1878, 2085, 2086
  • 1 Bigoaktree: 1597
  • 1 BigusLightus: 704
  • 1 BillyBobJoe: 2424
  • 1 BingoThink: 1068
  • 1 Blades: 402
  • 1 Blinky1: 706
  • 1 Blu3iris: 2066
  • 2 BlueSwordM: 1220, 1220, 2410, 2468
  • 1 Bmg2514: 2444
  • 1 Bo4ka: 381
  • 4 Boaz: 269, 824, 1800, 1801
  • 1 BobG: 2415
  • 6 Bob_McBob: 1035, 1116, 1117, 1792, 1793, 1794
  • 2 Bogdan: 1546, 1547
  • 1 Bonham: 573
  • 1 BooBooBear: 193
  • 1 BorisBar: 166
  • 1 Boro: 305
  • 1 Box: 311
  • 2 Brawler1588: 1912, 1913
  • 1 BrewsWayne: 2191
  • 1 Brian Metcalfe: 527, 528, 528
  • 1 BrianButlerCPA: 1544
  • 1 BrianCharles: 1029
  • 2 BrianK: 250, 251
  • 1 Bribo: 248
  • 1 Bright_Mike: 1761
  • 2 Brinkmann: 1268, 1269
  • 2 Bruno28: 828, 841
  • 2 BuDn3kkID: 2314, 2322
  • 2 Buckeye_Guy: 1943, 1944
  • 1 BurningPlayd0h: 1358
  • 3 Buzzy243: 226, 1608, 1609
  • 1 CC268: 1907
  • 2 CJ Avlis: 539, 1108
  • 2 CJW: 1795, 1796
  • 1 CM2010: 1104, 1165, 1165
  • 1 CMU_84: 1789
  • 2 CRX: 46, 291
  • 1 CabalGrim: 1397
  • 2 Cajones32: 2413, 2414
  • 2 Calaveras: 992, 1978
  • 2 Caleb: 173, 176
  • 1 Calmaja: 644
  • 1 Calzoner: 2014
  • 1 Cameron Wilcox: 2125
  • 1 Camo5: 63
  • 1 Cano: 303
  • 1 Capital: 1882
  • 1 CaptainBears: 1844
  • 1 Catnap: 1743
  • 1 Cercis: 1994
  • 1 Cereal_killer: 1400, 1424, 1424, 1424, 1424
  • 1 Charga: 71
  • 1 Charledflash: 551
  • 1 Chasealmighty: 2190
  • 2 Chatika vas Paus: 1300, 1301
  • 2 CheapThrills: 606, 683
  • 1 ChibiM: 1137
  • 1 Chicken Drumstick: 9
  • 1 ChrYoko: 886
  • 2 ChrisRedeemed: 2056, 2057
  • 1 CircaM: 538
  • 1 Cirnyan: 483
  • 1 CitizenK: 1373
  • 3 ClaudeMBallz: 2098, 2099, 2146
  • 1 Clayman83: 1956
  • 2 Cliwilnew: 1983, 2118
  • 2 Cobra502: 730, 1858
  • 2 Cody_carries_stuff: 2142, 2143
  • 1 Cookster: 1531
  • 1 Correllux: 2408
  • 2 Corzy: 258, 449
  • 2 Coscar: 1339, 1339, 1719, 2347
  • 1 Costom56: 2381
  • 2 Cpeng: 1564, 1660
  • 1 Crazy999: 1282
  • 2 Crazyeddie: 315, 316
  • 2 Creeker18: 2234, 2355
  • 1 Crimsonnj: 587
  • 1 Curdog: 1095
  • 2 Curetia: 1690, 1691
  • 1 Cursecut3r: 1349
  • 1 Cutchya: 1236
  • 1 Cythras: 74
  • 2 Cyzan: 1290, 1291
  • 1 D10ten: 388
  • 1 D4rka2nx: 1485
  • 1 DAGG3R: 2278
  • 0 DB Custom: 18, 18
  • 1 DBSAR: 200
  • 1 DBSS: 1931
  • 1 DOCFAR: 400
  • 2 Dadpool: 391, 1324
  • 2 Dannick: 2121, 2370
  • 1 Dannopiano: 2022
  • 1 Darbonius: 1098
  • 1 Dario: 1624
  • 1 DarkParagon: 1281
  • 1 DarkShot: 2076
  • 3 DarkerInSol: 1560, 1561, 1562
  • 3 DarthTader: 356, 2165, 2354
  • 2 Deadsailor21: 1612, 1613
  • 1 Deanocino: 697
  • 1 Deca: 1856
  • 1 Delta_V: 1467
  • 1 Depot_Shredder: 1681
  • 1 Desert Lumens: 1452
  • 1 DeusLight: 1064
  • 2 Dewalt101: 592, 959
  • 2 Dextersmexters: 2385, 2386
  • 1 DigitalDevourer: 148
  • 2 Dikkedikk: 952, 953
  • 1 Dinoplex: 2289
  • 1 Diomedes: 1177
  • 2 Dman7777: 586, 655
  • 4 Dobtruckers: 332, 684, 2133, 2134
  • 1 Doctawho: 242
  • 1 Doddsy: 1857
  • 2 Dogtown: 326, 554
  • 2 Dogue: 1586, 1587
  • 2 Dominion003: 2305, 2306
  • 2 DontWorryScro: 1533, 2477
  • 1 DooMMasteR: 486
  • 1 Doobyscoo: 1322
  • 2 DoubleU: 1238, 1779
  • 1 Dougdimadome: 2205
  • 3 Dougiestyle: 1981, 2157, 2158
  • 1 Dovii: 705
  • 2 DrHook59: 500, 739
  • 1 DrinkingJar: 1835
  • 1 Driver 2: 2027
  • 1 Drock: 2255
  • 2 Dsvist12: 1320, 1321
  • 1 DunchBlaster: 1736
  • 1 Dutcheee: 1661
  • 2 Dwantink: 880, 1088
  • 3 Dyrnwyn: 2292, 2293, 2294
  • 1 ERDOS: 549
  • 1 Easyrr: 21
  • 2 EcuBebge: 2144, 2145
  • 2 Edindevon: 1262, 1712
  • 1 Edness: 218
  • 2 Eggun: 182, 1484
  • 1 Eivwer: 153
  • 1 ElginAgain: 595
  • 2 Elrostan: 2433, 2434
  • 1 EmptyWallets: 2419
  • 1 Enelooper: 42
  • 2 EnlightenMe: 1606, 2281
  • 2 Enlightened1: 1414, 1415
  • 2 Eraursls1984: 674, 2250
  • 1 Erethryn: 62
  • 1 EricJ2190: 1724
  • 3 Erwin18: 325, 492, 583
  • 1 F.i.l.a.s: 811
  • 2 FBsLights: 779, 1230
  • 1 FKJ: 2104
  • 1 FMcamaroZ28: 2181
  • 2 FPV: 2264, 2265
  • 3 Fady: 1406, 1407, 1408
  • 1 Fantomet: 237
  • 1 Farns: 565
  • 1 Fiiish: 1514
  • 1 FilipeBanana: 1203
  • 1 Fin17: 536
  • 2 FindThisHumerus: 668, 2226
  • 1 Finnno: 1575
  • 2 Firelight2: 197, 198
  • 2 Firtop: 2270, 2361
  • 2 Flash Foto: 2042, 2043
  • 1 Flash-O-Maniac: 440
  • 2 FlashIight: 861, 1102
  • 1 FlashMax: 964
  • 1 FlashPilot: 829
  • 2 Flifish48: 608, 609
  • 1 Flying Luminosity: 696
  • 1 FlyingJ: 436
  • 1 Frank A.: 172
  • 1 Frankie Baby: 309
  • 1 Franzen: 2470
  • 1 Freedom: 1788
  • 1 FromSeatoSky: 2428
  • 2 Frost1235: 752, 753
  • 2 Funzel67: 1697, 1698
  • 1 Fuzzylogic: 490
  • 1 G0OSE: 1140
  • 1 GalaxyWide: 1263
  • 2 Garth: 882, 883
  • 2 GearedTowardGear: 2194, 2195
  • 3 Geese: 1426, 1442, 1853
  • 2 Geoduck: 1610, 2350
  • 5 Gerrh: 101, 337, 338, 528, 529
  • 1 Gerrit: 130
  • 1 Geuzzz: 310, 310, 1164
  • 3 GiveALux: 968, 1210, 1211
  • 1 Gizzy: 1896
  • 4 Gj: 366, 417, 418, 419
  • 1 Gladimir_Gluten: 499
  • 2 Glas4d: 1337, 1338
  • 1 Glenn7: 579
  • 3 Glov: 945, 1721, 1722
  • 2 GoMeR: 1223, 1224
  • 1 Gondwanaland: 1368
  • 2 Goodfellafin: 1663, 1687
  • 1 Gpf2ez: 2400
  • 2 Grappler: 1167, 2366
  • 1 Gravedigger1: 1460
  • 1 GreenBolivian: 1674
  • 1 GreenLights: 1148
  • 2 GreenShrike: 252, 253
  • 2 Greener: 1614, 1615
  • 1 Greg_M: 411
  • 3 Guesticles: 2015, 2016, 2017
  • 3 Gunga: 59, 60, 475
  • 3 Gunnerboy: 261, 420, 421
  • 1 Guns712: 284
  • 2 HONDARIDER: 1293, 1294
  • 2 Hairy_Steve: 134, 505
  • 1 Hallamski: 1335
  • 2 Harborseal: 756, 757
  • 2 HeavyD3: 1435, 1436
  • 1 Hedmark: 2189
  • 2 Helios azimuth: 2141, 2360
  • 2 Henk4U2: 29, 133
  • 1 Hesh24: 1350, 1351, 1351
  • 1 Hexlord: 1493
  • 1 Hezekiah: 331
  • 2 He�sdeadJim: 2046, 2110
  • 1 Hikelite: 2091
  • 2 Hobo: 55, 2002
  • 2 Hojobones: 1182, 1887
  • 1 Hollybrook: 2075
  • 1 Hotwater84: 1757
  • 1 Hugburger: 2446
  • 1 Hugh Johnson: 1989
  • 1 I LIKE FLASHLIGHTS: 1237
  • 2 IH8MYX: 707, 708
  • 2 ISO: 219, 750
  • 1 I_like_lamb: 346
  • 1 IanBP: 1980
  • 1 IanTL: 1768
  • 1 Ijon: 1220
  • 1 Illumenated: 236
  • 3 Ilmatic: 531, 1448, 1449
  • 3 Ilumenati: 2162, 2163, 2445
  • 1 ImA4Wheelr: 235
  • 6 IndyArcher: 932, 933, 1883, 1884, 1885, 1886
  • 1 Inkidu: 2047
  • 1 Insane Dawe: 721
  • 1 Iselldrugsforgolf: 1361
  • 1 Itsme: 820
  • 1 J-Dub74: 100
  • 2 JCR1904: 2328, 2329
  • 2 JJMcGee83: 431, 432
  • 2 JLightz: 1046, 1047
  • 2 JPM3: 680, 681
  • 1 JSNTNG123: 2063
  • 1 Jaded: 1500
  • 1 Jagger: 1354
  • 1 Jalben: 299
  • 2 Jambo: 494, 733, 734, 734
  • 1 Jan_Ds: 1762
  • 3 JaredM: 478, 1542, 1543
  • 1 Jarms: 541
  • 1 JasonWW: 563
  • 1 Jay: 1401
  • 2 Jbraman: 823, 827
  • 1 Jcfunk: 2053
  • 2 Jello: 2420, 2421
  • 2 Jensen: 1633, 1634
  • 1 Jensen567: 163
  • 2 Jercb123: 744, 745
  • 2 JermsMalibu: 2028, 2114
  • 1 Jerommel: 24
  • 2 Jesjes: 161, 1189
  • 1 Jiffy: 939
  • 2 JimSac: 2160, 2161
  • 1 Jinx: 37
  • 2 Joat: 552, 607
  • 2 JoeRodge: 1664, 1668
  • 2 Joey Adams: 318, 920
  • 4 Johm: 1742, 1775, 2135, 2136
  • 1 John M: 748
  • 1 JohnCalvin: 837
  • 1 JohnnyUtah: 1443
  • 1 Johnsonbrook: 812
  • 1 Jonandreadolan: 1580
  • 1 Jondallas311: 718
  • 3 JordanZHP: 48, 1179, 1180
  • 2 JorgeDetroit: 2430, 2431
  • 1 Jtm94: 190
  • 1 Juls Boo: 1499
  • 1 Just a Guy: 999
  • 2 JustFit: 1771, 1772
  • 1 Jvrthp321: 1124
  • 2 K1NGP1NT: 1192, 1958
  • 2 KJ4BXT: 1377, 1378
  • 2 KW: 910, 956
  • 1 KaiserSosa: 1828
  • 1 Kalihi: 960
  • 2 Kalpn: 1708, 1709
  • 2 Kame Sennin: 1872, 2296
  • 1 Karl M Atwood: 2103
  • 4 KawiBoy1428: 11, 12, 2478, 2479
  • 1 Kaz: 1171
  • 4 Keepitsharp: 181, 1717, 2348, 2349
  • 1 Keisari: 247
  • 2 KevinZA1988: 2127, 2439
  • 2 KgaBombadier: 1847, 1848
  • 1 Khsaccali: 2353
  • 1 Kindle: 75
  • 3 Kingjohn: 817, 818, 1181
  • 1 Kinniver: 881
  • 1 KiwiKane: 94
  • 1 Klayking: 1733
  • 2 Klotski: 625, 626
  • 1 Koaksijalac: 82
  • 1 Kodachrome40: 146
  • 1 Korpen: 1774
  • 1 Kourtinoksylo: 317
  • 1 Kozy: 154
  • 2 Kuato: 1737, 1738
  • 1 Kulumatic: 189
  • 4 Kurt_Norway: 709, 710, 1744, 1745
  • 1 KutKhemist: 136
  • 2 Kuyaaaron: 2227, 2228
  • 1 KyleGates: 545
  • 2 Kysumi: 754, 755
  • 1 LAB: 1551
  • 3 LG: 605, 1112, 1113
  • 1 LGW: 1495
  • 1 LOTL: 1930
  • 2 Lagittaja: 1625, 2337
  • 1 Lamont56: 399
  • 2 Lance_Hardrod: 1629, 1630
  • 2 Lane32x: 2276, 2277
  • 1 LanternGuy: 1283
  • 1 LargeDog: 2074
  • 1 Lazy-R-us: 643
  • 1 Lemons for the Lemon God: 1874
  • 1 Lfatman: 1279
  • 1 Lick: 1398
  • 1 Light: 1559
  • 1 Light Years: 1057
  • 2 LightUpTheDark: 1353, 1790
  • 2 Lim_Wee_Huat: 462, 1122
  • 1 Linburger: 1669
  • 3 Lion42: 125, 1246, 1247
  • 1 Lips: 901
  • 1 LiteBriteKnight: 1701
  • 1 Litefighter: 578
  • 2 LoPan12: 2411, 2412
  • 1 Lol: 1075
  • 1 LouieAtienza: 2090
  • 1 Lowtech: 70
  • 2 Lumens Industry: 183, 184
  • 2 Luminosity: 897, 898
  • 4 Lund1660: 610, 611, 2332, 2333
  • 1 Lyubo Yanev: 389
  • 1 M4D M4X: 169
  • 2 M78: 151, 978
  • 1 MBuitendorp: 230
  • 2 MCT: 86, 365
  • 1 MG: 1078
  • 1 MRsDNF: 85
  • 1 Macka17: 673
  • 1 MagPap: 690
  • 1 Majoroverkill: 839
  • 1 MaksVasilev: 1159
  • 2 Man Without Shadow: 282, 283
  • 1 Mapster: 728
  • 2 Marc E: 1679, 1680
  • 1 Marcello: 1545
  • 1 Markymarcus: 2087
  • 1 Marnav1: 1486
  • 1 Marothar: 501
  • 1 Marshymarsh26: 1202
  • 1 Martinc5618: 2177
  • 2 Martini: 514, 542
  • 1 Marubae: 1298
  • 3 MascaratumB: 510, 1119, 1461
  • 1 Mat_77: 1892
  • 2 Matchoo: 469, 569
  • 1 Mattfox27: 1050
  • 1 Maverick1947: 1011
  • 2 Maxxsounds: 698, 2045
  • 1 McLight: 1521
  • 2 Medicijnman: 1264, 1894
  • 6 Megapanda66: 1155, 1156, 1918, 1919, 1920, 1921
  • 2 Melez: 2106, 2107
  • 1 Melven: 1454
  • 1 Meshark: 2132
  • 1 Metallurgist: 601
  • 2 Meyer: 1705, 1706
  • 1 MichielSanders: 915
  • 1 Mikael: 157
  • 2 Mike Fitz: 1030, 1899
  • 1 Mike72: 540
  • 3 MikeMacD: 1490, 1491, 1541
  • 1 Mikehino: 2254
  • 2 Mikesch54: 1683, 1684
  • 1 Mindaugass: 409
  • 4 Minocc: 895, 896, 1820, 1821
  • 2 Minty: 687, 688
  • 3 MobileEMP: 1326, 1327, 1328
  • 2 Modestep: 423, 424
  • 3 MokrySedeS: 1582, 1583, 2178
  • 6 MonkeyLight: 1429, 1430, 1431, 1432, 2315, 2316
  • 2 Moomoomao: 1266, 1267
  • 4 Moparguy: 1271, 1272, 1273, 1274
  • 3 Mops1: 1387, 1388, 1438
  • 3 MorpheusT1: 2323, 2324, 2325
  • 1 MortyDuck: 295
  • 2 Mr.Beam: 1649, 1650
  • 2 Mr.Scott: 95, 1304
  • 1 MrJohnny: 58
  • 2 Mrdrewbear: 324, 2109
  • 2 Mrpincherey: 2243, 2244
  • 1 Msan: 1993
  • 1 Mstevens113: 179, 179, 1062
  • 1 MtnDon: 36
  • 1 Mudpie86: 891
  • 2 MustSimon: 132, 179
  • 2 Muto: 7, 8
  • 1 MyDangus: 215
  • 1 MyRants: 2080
  • 2 NITEbiker: 1553, 1554
  • 2 NWoodsman: 1658, 1799
  • 2 Nash_Vegas: 1265, 1996
  • 1 Natanael_L: 2453
  • 1 Nathan42: 627
  • 1 Nathan_RB4: 2455
  • 2 Neilyboy: 1765, 1813
  • 1 Neodraconic: 2021
  • 2 Nev: 1127, 2467
  • 2 Nexus: 635, 636
  • 4 Nguyen: 276, 439, 515, 1058
  • 1 Ni-Cd: 2068
  • 1 Nichia: 1498
  • 2 Nicolicous: 558, 672
  • 1 Nine9n1ne: 523
  • 4 Nite Shadow: 120, 121, 2284, 2285
  • 1 Nitetime: 43
  • 1 NoPro: 2251
  • 2 Nooner: 1276, 1423
  • 1 NordicMist: 1318
  • 3 Nortson: 211, 1333, 1334
  • 1 NotSoBrightGuy: 1083
  • 1 Nowhere: 2231
  • 2 NuggetMcNugget: 567, 568
  • 1 OKCOREY: 1004
  • 1 O_CACA_: 1826
  • 2 Ocelot: 1037, 1038
  • 2 Old Davo: 2393, 2394
  • 3 OldSchoolAirCool: 1804, 1805, 1870
  • 2 Oldtinpan: 941, 942
  • 1 Oli: 2298
  • 1 Oneiromant: 2050
  • 1 OohNai: 1018
  • 3 OrangePeel: 287, 1568, 1569
  • 1 Ormbett: 301
  • 1 OscarM: 180
  • 2 Oswald3211: 615, 616
  • 2 Owen the K: 1710, 1711
  • 4 Ozythemandias: 17, 415, 843, 844
  • 1 P220C: 1897
  • 2 P33: 1602, 1780
  • 2 PBWilson: 53, 543
  • 1 PCFX: 335
  • 1 PJ: 982
  • 1 PabloVerde: 441
  • 1 Pacoboyd: 641
  • 1 Panoptic: 1682
  • 2 Paradise: 2239, 2240
  • 1 Paradoxical Antagonist: 1208
  • 4 Parallax: 1022, 1023, 1141, 1142
  • 2 Paranoidpizzas: 2383, 2384
  • 2 Paul321: 1040, 1041
  • 1 Paul59: 1662
  • 2 Paulz323: 2221, 2222
  • 1 Pavlo: 852
  • 2 Pe_Ehl: 1693, 1694
  • 1 PeasFull: 1909
  • 1 Peetz: 648
  • 1 Pegaso: 671
  • 1 Peho: 717
  • 2 Penguin: 1380, 1381
  • 1 Persechini: 995
  • 2 Pete33: 1889, 1890
  • 1 Petroleum Lantern Guy: 13, 326, 326
  • 1 Pfeffernuss: 1074
  • 1 PhantomPhoton: 1567
  • 1 Phaze13: 1360
  • 1 Pixll: 1657
  • 2 PleinPhare: 2170, 2247
  • 1 PocketSammich: 1862
  • 1 Poguche: 1641
  • 1 Polyesterboy: 1370
  • 1 Ponythug: 2469
  • 1 PookyChang: 2365
  • 1 PragmaticMurphyist: 1825
  • 1 PreacherCasy: 1843
  • 1 Primal: 292
  • 1 PrinceValorum: 96
  • 1 Pugna: 1666
  • 1 Pukachi: 149
  • 1 Pulsar: 271
  • 3 Pwsmith: 2088, 2203, 2464
  • 1 QwertzHz: 1289
  • 1 Qwibbles: 790
  • 1 RDHewitt1985: 2257
  • 1 RT—: 944
  • 2 RZRNUT: 2140, 2166
  • 1 RaVeN: 1172
  • 2 Ragsy: 628, 629
  • 1 Rah_BE: 548
  • 1 Ramrod: 1676
  • 2 Rando: 2081, 2180
  • 1 Random Dan: 1284
  • 2 RandyC: 1462, 1463
  • 2 RapidLux: 484, 1063
  • 1 Rat_Racer: 33
  • 1 Ratus: 1261
  • 1 Ravehawaii: 2297
  • 1 Rdubya18: 1617
  • 1 ReallyInToCheese: 1356
  • 1 Rectors: 2083
  • 1 RedForest UK: 340
  • 1 Redlyne22: 1081
  • 1 Relampago: 2172
  • 1 Res1cue: 1831
  • 1 Revlio: 1814
  • 1 Ricflair: 203
  • 1 RichardBrown: 1457
  • 2 Ristafas: 2061, 2062
  • 1 Rob_K: 612
  • 1 RobertB: 123
  • 1 Robosaur: 2302
  • 1 Robowski: 1100
  • 2 Roc32: 1383, 1384
  • 1 RockHugger: 645
  • 1 Roger Sully: 2295
  • 1 Roger Wilco: 869
  • 1 Rokypop: 830
  • 1 RoloFresh: 1065, 1254, 1254
  • 1 RotorHead64: 379
  • 1 Rsqweezy: 1548
  • 2 Rusty: 993, 994
  • 3 Rxich: 1550, 1740, 1741
  • 2 Rylee900: 1133, 1134
  • 1 Ryzbor: 2119
  • 1 SG3: 833
  • 1 SIGShooter: 255
  • 2 SKV89: 838, 1016
  • 2 SKY69: 1639, 2082
  • 1 Saigon: 222
  • 1 Sal415: 119
  • 4 Salty_Pancake: 2018, 2019, 2167, 2168
  • 1 Sam3gX: 590
  • 1 SamHaLeKe: 509
  • 2 Sarge930: 965, 966
  • 2 Satan@103TFS: 873, 1910
  • 2 Scallywag: 948, 1875
  • 1 Schkü: 429
  • 1 Schoki: 1655
  • 1 SciFiFreak: 232
  • 1 Sciencetists: 327
  • 2 Scooby: 1816, 1817
  • 2 Screwball69N: 1970, 1971
  • 1 SebaZ74: 162
  • 4 Seeker1: 729, 1101, 1132, 1901
  • 2 SeenTheLight: 312, 313
  • 1 Sergey_1998: 1938
  • 1 Sh4ggy: 1797
  • 1 Shadow.X1: 1552
  • 1 Shadowcactus: 430
  • 4 Shadowfax: 1036, 1871, 1999, 2000
  • 1 Shame-Ranger: 1145
  • 1 Shelton55: 1904
  • 2 Sherbona: 1529, 1530
  • 1 SilentObserver: 1555
  • 1 Silent_Star: 354
  • 2 Silentcropduster: 371, 1385
  • 1 Sillen: 1492
  • 1 Sirawatka: 1594
  • 1 Sivy: 1196
  • 0 SkittleStoat: 808, 808
  • 1 Skullker: 2095
  • 1 Sky4: 2299
  • 1 Skybid: 2399
  • 1 Slayer1: 56
  • 2 Slayer2003: 821, 822
  • 1 Sledgestone: 51
  • 1 Slipgun: 1695
  • 1 Smittymojo: 639
  • 1 Smokecutter: 1839
  • 3 SmokinH: 613, 614, 765
  • 2 Snoballz: 832, 1302
  • 2 Soldier: 1747, 1748
  • 2 SomethingRandom: 1713, 1714
  • 1 Sonullo: 1103
  • 1 SoulCraves: 954
  • 1 SpAwN: 949
  • 2 Sparks65: 1984, 1985
  • 2 Speadge: 1006, 1007
  • 1 Speed4goal: 4
  • 2 Spiderlight: 911, 2321
  • 1 Spinifex: 2456
  • 1 SpinySoftshell: 2417
  • 1 Spud: 464
  • 1 Steeldog: 1651
  • 1 Stereodude: 1372
  • 2 StevenK: 962, 1194
  • 1 StinkyTool: 467
  • 1 Stippier: 691
  • 1 Stittville Ed: 10
  • 1 Strangel0ve: 1005
  • 1 Streamtronics: 1759
  • 3 Sudsy: 2126, 2204, 2402
  • 1 Sukoi: 135
  • 1 Suncoaster: 308
  • 4 SvenWalker: 1802, 1803, 2371, 2372
  • 1 Swennie: 168
  • 2 T18: 405, 446
  • 2 TMaxxJJ: 1925, 1926
  • 1 TUNE4IT: 1106
  • 1 Tad_LOL: 2092
  • 0 Tally-ho: 557, 557, 1537, 1537, 1537, 1537, 557, 557
  • 2 Tarvos: 1241, 1242
  • 1 Tdh66: 921
  • 1 Teamliberty: 971
  • 1 Tech25: 1474
  • 1 Tecmo: 1627
  • 2 Tejasandre: 1471, 1472
  • 2 Tender: 656, 990
  • 1 Tete: 294
  • 2 Tex_Tbone: 1934, 1935
  • 3 The Burgh: 145, 819, 1121
  • 1 The Imp: 93
  • 1 The Jinx: 963
  • 2 The Miller: 1, 2
  • 2 TheAuditor: 1191, 2188
  • 4 TheHebrewHammer: 321, 322, 1880, 1881
  • 2 TheLonelyLumen: 362, 363
  • 1 TheOnlyDocc: 1526
  • 2 TheShadowGuy: 1347, 1348
  • 1 TheSoulless78: 1286
  • 1 Thekernels: 1149
  • 2 Thewrights11: 924, 925
  • 2 Thro: 1873, 2079
  • 0 Throw me in to darkness …: 814, 814
  • 3 Thrust84: 2031, 2268, 2269
  • 2 Tixx: 349, 491
  • 1 Tjhosan: 79
  • 3 Tjohn: 502, 503, 504
  • 1 Tldd: 2197
  • 1 Tobehz: 2407
  • 1 Tofudebeast: 2026
  • 2 Toglud: 2448, 2449
  • 2 Tom E: 5, 6
  • 0 Tom Tom: 1088, 1088, 1088, 1088, 1636, 1636
  • 1 Tomatopotato: 2073
  • 1 Tomogchi: 1138
  • 2 Tony Cape: 1351, 1764
  • 1 TonyG: 1404
  • 3 Toolboxkid: 2211, 2212, 2213
  • 2 Tooreal: 711, 758
  • 2 Torre246: 1198, 1199
  • 2 Touchofred: 803, 1727
  • 2 ToyKeeper: 245, 394
  • 1 Tranquilator: 2367
  • 1 Travelr: 334
  • 1 Trb5p: 367
  • 1 Trevi_lux: 450
  • 1 Trm904: 1665
  • 2 TrueNerd: 2262, 2263
  • 1 TrueRMS: 2105
  • 1 Tsunamii: 1009
  • 1 Tubercle: 2065
  • 2 Tumbleweed48: 1611, 2003
  • 1 Tweak It: 1955
  • 1 Twistedvizionz: 497
  • 1 TylerDurdenThree: 2044
  • 1 Typevii: 1362
  • 1 USA: 2271
  • 4 Umpi2000: 714, 722, 722, 850, 2048, 2102
  • 2 Uname: 845, 846
  • 2 Unloco: 1517, 1518
  • 1 Uriah: 264
  • 1 UserM4: 2447
  • 2 Valerianis: 973, 1458
  • 1 ValuseekeR: 2193
  • 1 Vaxd: 1715
  • 1 Vaztes: 2401
  • 1 Venice: 526
  • 1 Ventsi: 2266
  • 1 VictorB: 1973
  • 1 Victorio: 763
  • 1 Villae: 2357
  • 1 Virisenox_: 1640
  • 2 Vortexbig: 1940, 1941
  • 1 WES-7: 631
  • 2 WTF: 1866, 2156
  • 1 WakingToWinter: 900
  • 1 WalkIntoTheLight: 1131
  • 2 WarHawk-AVG: 591, 2150
  • 1 Wavefront: 734
  • 2 WaylonJennings: 480, 556
  • 1 WeeG: 1932
  • 1 Weidercs: 2120
  • 1 Wekr: 2390
  • 1 WelshDan: 1158
  • 2 WhatsAFoote: 2374, 2375
  • 1 Whezzel: 2111
  • 3 WhitedragonBC: 397, 809, 1510
  • 1 Wildcat: 2007
  • 1 Willt718: 1986
  • 2 WolfA: 333, 1915
  • 1 Wrathbringer27: 159
  • 1 Wvled: 1752
  • 2 Wyre: 57, 961
  • 1 ×0R: 414
  • 1 XD9: 950
  • 1 XXX-Man: 525
  • 1 Xavier Blak: 1734
  • 1 Xebrecito: 854
  • 2 Xikex: 974, 975
  • 1 Xoroxronis: 1118
  • 2 YYCN8: 342, 759
  • 1 Yammie: 776
  • 1 Yanlee13: 856
  • 3 Yoav.Klein: 1312, 1791, 2035
  • 1 Yohan110: 1190
  • 1 Yokiamy: 522
  • 4 Yourrid: 1165, 1166, 1777, 1778
  • 1 YouthMolecule: 1846
  • 1 Yummy Yam: 1749
  • 4 ZempOh: 780, 781, 782, 783
  • 1 Zeratull: 1345
  • 1 Zero-K: 1080
  • 1 Ziggie: 1584
  • 0 ZozzV6: 231, 231
  • 2 Zulumoose: 375, 1147
  • 1 a12luke: 220
  • 2 aL1: 442, 521
  • 1 a_idiot: 1341
  • 2 a_idoux: 1076, 1077, 1277, 1277, 1277, 1277
  • 2 abarehands: 1024, 1025
  • 1 abbazaba: 2093
  • 1 abhinit90: 185
  • 1 abril: 598
  • 1 acml: 433
  • 3 adam7027: 1507, 1508, 1509
  • 2 adirus: 1393, 1776
  • 2 adnj: 766, 767
  • 2 adrn77: 1055, 1060
  • 2 adsum: 310, 2241
  • 1 aeon: 1824
  • 2 agent80: 1195, 1756
  • 2 aggillator: 773, 1924
  • 1 aginthelaw: 41
  • 1 agnelucio: 685
  • 1 aim120: 1089
  • 1 ajohn151: 1648
  • 2 akoposilester: 506, 507
  • 1 albertopnp: 199
  • 1 alchemi: 1527
  • 1 ale9g: 1379
  • 2 alejandrov: 723, 1130
  • 1 alejo: 1314
  • 1 alex64: 124
  • 1 alexirc: 2036
  • 2 alifpb98: 574, 1129
  • 1 alphazeta: 77
  • 2 amars7: 1672, 1700
  • 4 amplificus: 314, 404, 1703, 1704
  • 3 andrewmac: 1010, 1419, 1420
  • 1 andrewprime: 805
  • 2 andyxxx: 1248, 1249
  • 3 ansb29: 1477, 1478, 1479
  • 1 antoninuspius: 1626
  • 1 anycolourfloyd: 1396
  • 2 apt323: 302, 1577
  • 2 apurva: 1296, 1297
  • 1 archimedes: 14
  • 1 arditty: 512
  • 1 arekm: 604
  • 1 args1: 747
  • 1 arisdes: 1344
  • 1 arttwou: 2049
  • 1 asciiphil: 1405
  • 1 askj: 855
  • 1 aslpg: 83
  • 2 asot: 1807, 1808
  • 2 aswang: 1596, 1974
  • 1 ataleoffiction: 2100
  • 1 atasuke_: 1450
  • 1 atbglenn: 594
  • 1 aurum: 1760
  • 1 autodidact: 387
  • 2 autoxer: 1456, 1556, 1556, 1927
  • 1 azhu: 2320
  • 1 azj: 1123
  • 1 b1i1l1l1y1: 202
  • 1 bald1: 879
  • 2 balinzwerg: 836, 851
  • 2 bansuri: 509, 509, 1227, 2258
  • 1 barrybluejeans: 998
  • 1 basic42: 2358
  • 2 bassoverflow: 1976, 1977
  • 1 bd52: 273
  • 1 beam0: 382
  • 2 beastlykings: 2152, 2153
  • 1 bento_blf: 1374
  • 1 bexamous: 1066
  • 1 bibin: 1079
  • 1 bidas: 1667
  • 1 bigtrav261: 1864
  • 2 bikedave99: 19, 300
  • 1 bleomycin: 2060
  • 1 blinky: 2034
  • 1 blueb8llz: 76
  • 1 bluereidon: 1837
  • 2 bmansc: 1528, 1891
  • 1 bmengineer: 1019
  • 1 boTy: 955
  • 2 bobkido: 946, 1099
  • 1 bonfire: 1270
  • 1 boomermax: 2242
  • 3 boostedsubie: 597, 1849, 1850
  • 2 borealis: 746, 1879
  • 3 bossf350: 319, 847, 848
  • 1 boznet: 344
  • 2 bquinlan: 1168, 1169
  • 1 bradjamesley31: 2376
  • 1 brettr1: 1307
  • 1 brianch: 1015
  • 1 brtactical: 1082
  • 1 bts: 1621
  • 2 bucky: 1052, 1161
  • 2 bulbeee: 1453, 2280
  • 2 bunnicula: 682, 771
  • 2 bushmaster: 1365, 1424
  • 2 bvincent: 796, 797
  • 1 bwings: 288
  • 2 byarnell05: 1225, 1226
  • 5 cabfrank: 91, 1128, 1758, 2137, 2196
  • 1 caddylover: 981
  • 4 candor: 642, 724, 1178, 2246
  • 1 cannesahs: 1369
  • 1 cap90: 1962
  • 2 caplang: 1427, 1480
  • 3 carmantl: 164, 471, 472
  • 2 cavesprings: 725, 726
  • 1 cavorite: 25
  • 1 cdjaney: 1867
  • 1 celeryjack: 1638
  • 1 cellguy: 957
  • 1 cephalofoil: 2432
  • 4 chadvone: 1096, 1097, 1769, 1770, 1788, 1788, 1788, 1788
  • 1 chakrawal: 1806
  • 1 charles lin: 246
  • 1 charwinger21: 2020
  • 1 chasm22: 470
  • 5 cheesecheeks: 634, 667, 695, 722, 751
  • 1 cheezedippah: 2267
  • 2 chesterqw: 663, 664
  • 2 chooma: 15, 481
  • 1 chops728: 38
  • 2 chrisc: 155, 209
  • 1 chrisddo: 383
  • 2 christoph: 640, 1975
  • 1 churchilllafemme: 906
  • 1 cittroman: 2352
  • 4 cjoe7: 740, 741, 742, 743
  • 4 clip.: 2173, 2174, 2175, 2176
  • 1 cloggy: 916
  • 1 cmflippen: 107
  • 2 coban: 1464, 1465
  • 2 coherent-rambling: 1832, 2148
  • 1 compression: 364
  • 1 contactcr: 280
  • 1 contigo: 972
  • 1 copperheaded: 793
  • 1 cormun: 2438
  • 1 crankynetadmin: 1069
  • 1 crazyglockman: 1061
  • 1 cressdrvr: 2312
  • 2 crz6662: 384, 831
  • 1 cswingle: 2012
  • 2 cujo255: 216, 1292
  • 1 cwright314: 2225
  • 2 cypherz: 1109, 1110
  • 2 cyropro: 306, 1810
  • 2 d_t_a: 980, 1176
  • 1 danak1000: 2466
  • 1 dantemens: 1863
  • 2 darkpenguin: 532, 533
  • 1 darrenm: 689
  • 2 darrylo: 580, 581, 928, 928, 928, 928
  • 1 dave101: 1656
  • 1 davidkappelt: 485
  • 1 db00: 2425
  • 1 dbellas: 2187
  • 1 dbmeed: 988
  • 1 dchoe: 1021
  • 1 dealgrabber2002: 1787
  • 1 deathless: 347
  • 1 dekozn: 427
  • 1 delete: 899
  • 4 delusional: 620, 621, 1688, 1689
  • 1 denkiman808: 1861
  • 1 dentillozie: 352
  • 2 derivepower: 1469, 1643
  • 1 dezoe: 201
  • 1 dh79: 2303
  • 1 dhiltonp: 802
  • 1 diesel72: 1836
  • 2 djburkes: 31, 32
  • 1 djinni_cake: 2377
  • 2 djozz: 34, 1154
  • 1 dluckey86: 603
  • 2 dmsoule: 1252, 1253
  • 1 dodo: 144
  • 1 dompred: 1632
  • 2 donnakebab: 1475, 1476
  • 1 donthelegend: 1905
  • 1 dorin: 2454
  • 2 dotBLF: 1833, 1834
  • 1 doubleone44: 840
  • 1 drillbit: 355
  • 1 drjamesfox: 813, 1270, 1270
  • 1 dropman: 1957
  • 2 dtom: 2009, 2054
  • 2 dts71: 270, 2219
  • 1 dubyrunning: 2235
  • 1 duhduhduhdiabeetus: 1332
  • 2 dukeface13: 459, 2223
  • 1 duvallite: 1735
  • 2 dyang: 884, 885
  • 1 e1000: 1445
  • 2 eas: 1070, 1466
  • 1 eb1888: 1751
  • 1 edeekeos: 712
  • 1 el_duderino: 701
  • 2 electricjelly: 137, 138
  • 1 electromage: 2013
  • 1 electromotive_force: 1987
  • 1 elnino: 1416
  • 2 elpaulo: 1604, 1605
  • 1 emarkd: 348
  • 1 embee: 380
  • 1 emerel: 194
  • 1 engber: 662
  • 1 eric800: 582
  • 1 erik: 1212
  • 2 erikbuch: 716, 794
  • 1 ersecu: 637
  • 1 etienne440: 2416
  • 1 even-more: 679
  • 1 everydaysurvivalgear: 50
  • 1 f0xx: 2040
  • 1 fancrazy7: 408
  • 1 fantomR: 853
  • 1 fatjuicylarva: 2429
  • 1 fed893: 434
  • 1 fedcas: 658
  • 1 felp_s: 2006
  • 1 ferongr: 401, 401, 1898
  • 1 ferthur: 947
  • 2 fgials: 2229, 2230
  • 1 finges: 1914
  • 1 finnegans: 1285
  • 1 fireblade893: 158
  • 1 firstcipher: 1421
  • 1 five.five-six: 177
  • 2 flashme: 2217, 2218
  • 3 flashycali: 1205, 1206, 1250
  • 1 flightless22: 1952
  • 1 flipkicks: 191
  • 2 floydo: 834, 1893
  • 1 flucero28: 2224
  • 1 fly-by-night: 196
  • 1 flysohigh: 1750
  • 1 fneuf: 2202
  • 1 folg: 1540
  • 3 fonLED: 912, 913, 914
  • 2 fonfan: 265, 266
  • 1 fourbyfive: 1628
  • 2 franktv: 1125, 1126
  • 1 freedrinks: 2452
  • 1 freeme: 217
  • 1 freethink: 983
  • 1 full-beam: 1031
  • 1 funkychateau: 2004
  • 1 fusion_m8: 1440
  • 1 fuzun: 465
  • 1 g_damian: 553
  • 4 g_sintornillos: 231, 623, 624, 908
  • 1 galex: 1812
  • 1 gangstead: 585
  • 1 garrybunk: 770
  • 1 gavrook: 1218
  • 1 gds95: 826
  • 1 gearowl: 374
  • 1 geepaw: 87
  • 2 geetee03: 1295, 1394
  • 1 gehrmo: 1539
  • 2 gemmell: 1339, 1340
  • 1 ggf31416: 1114
  • 1 gi.lumens: 923
  • 1 giorgoskok: 16
  • 1 gisewhcs: 143
  • 2 gkushev: 1308, 1309
  • 1 glide 1: 328
  • 1 glockboy: 297
  • 2 gloomywarfreak: 227, 444
  • 1 glowz: 650
  • 1 gman7228: 1522
  • 1 goatfarmer: 786
  • 1 gokalpm: 1631
  • 1 gorgak: 2256
  • 1 gorky: 73
  • 2 goshdogit: 443, 864
  • 3 gottawearshades: 1417, 1505, 2108
  • 1 gottobegeek: 1496
  • 4 gpbeiew: 2071, 2072, 2368, 2369
  • 1 grahamgraham: 1045
  • 1 gravelmonkey: 858
  • 1 gravitysux: 2342
  • 3 gregfortune: 677, 678, 810
  • 2 gregor: 234, 479
  • 1 grizzley: 1635
  • 1 gtv4: 1511
  • 2 guerrilla154: 345, 1085
  • 1 gungoat: 170
  • 1 hank: 651
  • 1 hanoilighting208: 1481
  • 1 hanson405: 2124
  • 2 hardlybowing: 731, 732
  • 1 harry218: 463
  • 4 hatman: 396, 403, 1990, 1991
  • 1 hcanning: 1593
  • 2 hcjake: 1902, 1903
  • 2 headburger: 1359, 1784
  • 1 heatwaves: 1954
  • 1 henry: 922
  • 2 hex1979: 1945, 1946
  • 1 heysquanchy1916: 2423
  • 1 higbvuyb: 1054
  • 3 hiker89: 1315, 1316, 1317
  • 1 hippotomato: 857
  • 2 hksmatrix: 926, 927
  • 1 hmihaylov: 296
  • 2 hoabegrubn: 1157, 2364
  • 1 hobapolight: 2011
  • 2 hodor: 1447, 1647
  • 1 hron61: 1200
  • 1 hsiddharta: 2406
  • 1 huey18: 1482
  • 1 hugh: 2041
  • 1 hunter1: 28
  • 1 hyperduc: 1653
  • 1 iamlucky13: 1386
  • 1 ianfollett: 2403
  • 3 id30209: 1677, 1678, 2130
  • 2 idleprocess: 1501, 1502
  • 2 ifratos: 498, 2206
  • 1 ikkentobi: 2067
  • 2 illuminos: 223, 224
  • 1 illusioned: 466
  • 2 infinity526: 65, 66
  • 1 inqbus406: 2378
  • 1 interval: 1524
  • 1 iosala: 1026
  • 1 ishak: 2070
  • 2 ispeedy: 1619, 1620
  • 2 isuckatmakingupnames: 617, 618
  • 1 itsonlyme: 2450
  • 2 j00ski: 2214, 2215
  • 1 jaharkes: 1342
  • 2 jakeattack77: 1968, 1969
  • 1 jamaya: 576
  • 1 james y: 357
  • 1 jamio: 1446
  • 1 jamjar: 2317
  • 1 jasontheguitarist: 2307
  • 1 javipiloto: 1278
  • 1 jayddots: 1953
  • 2 jaynick: 1020, 1233, 1234, 1234, 1234, 1234
  • 1 jcooper: 1090
  • 1 jdh00: 2409
  • 1 jdunlap27284: 210
  • 1 jerrod: 602
  • 1 jerrymanderine: 2334
  • 1 jescereal: 241
  • 1 jfalk1: 256
  • 1 jgradyc: 1707
  • 2 jimahi: 437, 438
  • 1 jimmy yang: 825
  • 2 jimmymke: 1520, 1607
  • 1 jinjin19: 1288
  • 2 jkbam: 1053, 2465
  • 1 jknut: 2472
  • 1 jmike: 1048
  • 1 jmoots: 260
  • 1 jmpaul320: 555
  • 2 joeangi: 343, 774
  • 4 joechina: 435, 584, 1537, 2094
  • 1 johnpc: 112
  • 1 jojosupir: 2128
  • 1 jon7: 1997
  • 2 jonxxn: 103, 1908
  • 1 josephqool: 390
  • 1 jtq: 889
  • 1 juhha: 1860
  • 1 junglejim13660: 1173
  • 1 junkyardbiker: 1798
  • 1 jurasik1: 524
  • 2 justaguy: 1433, 1434
  • 2 justanotherguy: 1441, 1868
  • 2 jwhitmore: 1151, 1152
  • 2 jycheang: 958, 984
  • 1 k-wong: 61
  • 2 k125bw: 1785, 1786
  • 1 kahvitahra: 807, 1089, 1089
  • 1 kal444: 564
  • 1 kanton: 1670
  • 1 kase: 2391
  • 1 kat: 2122
  • 1 kaybi: 118
  • 1 kazibole: 2112
  • 1 kbmeister: 804
  • 1 kbro: 428
  • 2 keengeorge: 97, 98
  • 2 kent21972: 1916, 2326
  • 1 kermorvan: 2338
  • 1 kevinfc: 385
  • 2 kevinm: 2252, 2253
  • 2 kevinmartingreen: 2232, 2233
  • 1 kevinw0lf: 1366
  • 0 khas: 135, 135
  • 4 kittonmittons808: 2272, 2273, 2274, 2275
  • 1 kiwi_digger: 451
  • 1 klrman: 1375
  • 2 kmwc72 CN: 1243, 1244
  • 1 knightstalker: 104
  • 2 knuckles: 1437, 1895
  • 1 kollers: 1425
  • 2 kommessy: 1135, 1136
  • 1 kontour: 989
  • 3 koolranch: 2236, 2237, 2238
  • 2 korkfoto: 1726, 2287
  • 3 korpzgrinda: 106, 2209, 2210
  • 1 korylprince: 1260
  • 1 kotobuki: 520
  • 1 koyotee: 456
  • 2 koziy: 1959, 1960
  • 1 krazypoloc: 768
  • 2 kubed_zero: 1258, 1259
  • 1 kuoh: 272
  • 2 lachesis: 1515, 1516
  • 1 lampyris: 160
  • 1 led_400: 2192
  • 1 legofaith: 808
  • 1 legopacific: 842
  • 1 lennshow66: 865
  • 0 leo l.: 1702, 1702, 1702, 1702, 1702, 1702, 1702, 1702
  • 2 leroycp: 147, 290
  • 2 lew123: 1330, 1483
  • 1 lexvegas: 1470
  • 2 lfowner: 1578, 1579
  • 1 light_man89: 1720
  • 4 lightblows: 1950, 1951, 2436, 2437
  • 2 lightboks: 1622, 1933
  • 2 lightknot: 1410, 1411
  • 7 lightlight22: 929, 930, 931, 1570, 1571, 1572, 1581
  • 1 lionheart_2281: 117
  • 1 liquidretro: 89
  • 2 litcrit: 530, 1818
  • 2 litenutz: 359, 445
  • 4 liteyear: 976, 1073, 2475, 2476
  • 4 lmcmann: 1143, 1144, 1589, 1590
  • 2 lohtse: 1305, 1306
  • 1 loki993: 1444
  • 1 loneoceans: 1043
  • 1 longmire: 108
  • 1 lotrbfme: 1840
  • 1 lowcontrast: 1753
  • 1 lroach: 2010
  • 1 lucydog: 1409
  • 1 ludolf: 1671
  • 1 luisgcan: 122, 1260, 1260
  • 1 lumenzilla: 114
  • 2 lumiere: 1659, 1716
  • 2 luongshot: 571, 572
  • 2 m0nk33: 1936, 1937
  • 1 maba: 2458
  • 1 macktastic: 109
  • 1 madness: 1343
  • 0 madsnake: 1864, 1864
  • 1 magnet: 187
  • 1 maildroid: 566
  • 1 majus: 2311
  • 1 malamask: 142
  • 1 manbearpig: 360
  • 0 manithree: 1254, 1254
  • 1 marbs: 2290
  • 1 marcoaml78: 1056
  • 1 marcus_z: 329
  • 1 marcuswong: 1854
  • 1 martook: 406
  • 1 martytown: 44
  • 0 matik42: 1681, 1681
  • 2 mattadores: 1851, 1852
  • 1 mattar12: 917
  • 2 mattlward: 72, 511
  • 1 maukka: 35
  • 1 mb200k: 1402
  • 2 mbp: 2117, 2363
  • 1 merikgvr4: 2077
  • 1 meteorxs: 1811
  • 2 metroplex: 2037, 2038
  • 3 mgracia85: 1519, 1822, 2023
  • 1 mhanlen: 212
  • 1 mhtawfiq: 2379
  • 1 michaeltmohr: 1336
  • 3 mickscott: 659, 660, 661
  • 1 middle age man: 2131
  • 1 mihlit: 2097
  • 1 mikeymikey: 979
  • 2 mikeyn: 2115, 2116
  • 1 mikeyx: 207
  • 1 mikobiker: 676
  • 1 minusic: 1012
  • 1 misterpearguy: 1325
  • 2 miswas: 762, 1084
  • 2 mitsuki08: 2096, 2451
  • 2 mizou51: 244, 373
  • 1 mk23: 1654
  • 1 mkwarman: 1998
  • 2 mlodyulek: 764, 1917
  • 0 mmalive: 1045, 1045, 1045, 1045
  • 2 mniezen: 1228, 1229
  • 1 moeman: 2259
  • 1 moglai: 178
  • 1 moridin: 90
  • 2 morning_wood: 878, 905
  • 1 mortuus: 1702
  • 1 moshow9: 448
  • 1 mountainair26: 2084
  • 2 mpak87: 1646, 1754
  • 1 mrgreengenes42: 1323
  • 1 mrheosuper: 1696
  • 1 mrstealyourgains: 240
  • 1 mts49: 951
  • 2 mundele: 1209, 1888
  • 1 musket3: 2422
  • 1 mustig: 816
  • 1 myad: 2427
  • 1 myflashguy: 630
  • 2 myowin: 392, 393
  • 2 n8_ball: 2200, 2201
  • 1 nassagus: 2461
  • 1 nastynate: 1576
  • 2 nbjly: 1966, 1967
  • 1 neBstress: 1455
  • 1 neabue: 1979
  • 1 nemo001: 516
  • 2 netgear68: 174, 577
  • 2 netprince: 140, 141
  • 1 newandreas: 1766
  • 10 nfetterly: 547, 791, 874, 875, 2154, 2155, 2440, 2441, 2442, 2443
  • 2 nick779: 1094, 1563
  • 2 nick91900: 814, 2397
  • 1 nickmca: 2058
  • 1 nihilistnarwhal: 2310
  • 2 niktak11: 358, 2282
  • 1 nineteen43: 876
  • 1 nishayume: 596
  • 1 nnmnu1: 298
  • 2 nobody: 2123, 2327
  • 1 noboneshotdog: 1170
  • 2 noetik: 1573, 1574
  • 1 noobi3st: 1942
  • 1 noobsanpu: 1357
  • 1 nopasaranof: 727
  • 2 nordlicht: 487, 488
  • 1 norman4 EDCdude: 2069
  • 2 nqcken: 518, 806, 955, 955
  • 1 nsk1979: 1468
  • 2 nvanlaar: 653, 654
  • 1 object_in_space: 795
  • 1 obviouslylogan: 2426
  • 1 occulai: 2319
  • 1 oceanfreak: 1598
  • 1 octav: 386
  • 2 odriewniffe: 1506, 1603
  • 1 offline: 1585
  • 4 offroadatnite: 737, 738, 887, 888
  • 1 ogre23: 2033
  • 2 ohbreeeezy: 699, 700
  • 1 ohhhtravis: 859
  • 1 ohnonothimagain: 2346
  • 1 olafzwaan: 2208
  • 1 olivedrab: 1841
  • 1 ollywood: 186
  • 0 ooeei: 1961, 1961
  • 2 opbigdave: 1042, 1120
  • 1 orbit308: 1204
  • 1 orinjuse: 1162
  • 1 osb40000: 353
  • 2 ossifrage: 2462, 2463
  • 1 oto: 2207
  • 2 ottrocity: 2182, 2183
  • 2 oweban: 2008, 2039
  • 1 pSw: 789
  • 1 paosms: 1819
  • 3 patchythepirate: 67, 1071, 1823
  • 2 patmurris: 208, 544
  • 1 paul6ppca: 778
  • 1 pavol77: 1059
  • 1 pb00: 1838
  • 1 pc_light: 167
  • 2 peabody: 156, 493
  • 1 pegasus21: 336
  • 1 pelle470: 461
  • 2 pendo: 1644, 1972
  • 1 pennsdad: 2159
  • 1 pennylane: 188
  • 2 pennzy: 1197, 2359
  • 3 pepinfaxera: 225, 1636, 1637
  • 1 peppercorn: 2169
  • 1 pfn: 1489
  • 1 pinecone: 1652
  • 1 pinggo: 1939
  • 1 pinkpanda3310: 18
  • 1 pintpot: 171
  • 1 pio: 1992
  • 10 pirate joe 22: 274, 275, 376, 377, 425, 426, 784, 785, 1086, 1087
  • 1 piyoman: 652
  • 1 plarker: 2396
  • 1 polarweis: 339
  • 1 praveendk: 468
  • 1 preface: 1231
  • 2 prepro: 534, 535
  • 1 pscal: 293
  • 1 psumo: 1392
  • 2 pthartung: 2184, 2300
  • 4 qandeel: 115, 1153, 2330, 2331
  • 2 raccoon city: 866, 1105
  • 1 radellaf: 2279
  • 1 radiobrain: 2304
  • 1 rag: 638
  • 1 rahdi: 815
  • 1 raider_03: 2392
  • 2 raqin: 1255, 2288
  • 2 rayman007: 557, 647
  • 1 raynman: 165
  • 1 rbmcmjr: 1217
  • 1 rcwiily: 1725
  • 2 rebelbayou: 281, 1675
  • 1 red72vw: 410
  • 1 reddin: 1988
  • 1 redsuns: 788
  • 2 regaia: 268, 482
  • 2 renhoek: 1049, 2345
  • 1 rennet: 1329
  • 1 retsyx: 1256
  • 1 rgkeller: 1815
  • 2 richnpc: 27, 1222
  • 1 ridasrich: 1003
  • 2 ridepacker: 2151, 2341
  • 1 riorio88: 2101
  • 1 rizaoztop: 775
  • 2 rizky_p: 351, 361
  • 3 robbobus: 243, 935, 936
  • 1 robertino: 1773
  • 1 robertsig: 1865
  • 1 rockhound42: 1146
  • 4 roll_tide: 495, 496, 1963, 1964
  • 1 rondohatten: 508
  • 1 rova2014: 1809
  • 1 royalomaha: 1219
  • 1 rtc123_99: 1949
  • 1 rubyrubidium: 2005
  • 2 run4jc: 2260, 2261
  • 1 russthetoolman: 849
  • 2 rvr: 277, 278
  • 2 ryukin2000: 967, 977
  • 1 sac02: 26
  • 1 sachmo: 1728
  • 2 sacrileizei: 1183, 1184
  • 1 saintsagan: 476
  • 2 samnavy: 649, 1280, 1281, 1281
  • 1 samsat: 2051
  • 2 san san: 1013, 1014
  • 1 sanches: 1008
  • 1 sandanbob: 259
  • 3 sandro: 1829, 1830, 2308
  • 1 sarten350: 862
  • 1 saturdayturtle: 2089
  • 2 saypat: 1845, 2309
  • 1 sbslider: 1352
  • 2 scalyman.: 1494, 1869
  • 1 scdaf: 1842
  • 1 schiesz: 2356
  • 2 scianiac: 213, 214
  • 1 scotlarock: 39
  • 2 scottb7862: 2185, 2186
  • 1 scottie888: 1367
  • 1 scottyhazzard: 1488
  • 1 scout24: 1221
  • 1 sdonjor1: 460
  • 1 sebastiang: 761
  • 2 sergey—neo: 1497, 1503
  • 1 sesgum: 289
  • 2 severide: 1240, 1346
  • 1 shilent: 395
  • 1 shimey: 477
  • 6 shirnask: 378, 513, 715, 1139, 1928, 1929
  • 1 shkig: 2291
  • 1 shunthemask: 2382
  • 2 sidfishez: 2248, 2249
  • 3 skinny_tie: 686, 1422, 2078
  • 1 skovati: 1755
  • 1 skyfaller: 2380
  • 3 sleasys14: 1193, 1876, 1877
  • 2 slimkango: 2029, 2030
  • 1 slmjim: 1107
  • 3 slow2go: 102, 454, 455
  • 1 slowtechstef: 1216
  • 1 smed1275: 175
  • 1 snakeoil: 2340
  • 1 sochi111: 2064
  • 1 soldsoulrockroll: 1355
  • 1 solrac22: 489
  • 1 somnambulism: 593
  • 1 sorotantaz: 131
  • 2 southcovekayak: 1017, 1595
  • 2 sovereignknight: 985, 986
  • 3 spaceminions: 1032, 1115, 1303
  • 1 spade413: 458
  • 1 specialk: 619
  • 1 spinynorman: 52
  • 1 sporez: 2398
  • 1 sportlampa: 903
  • 1 srkfl: 1556
  • 1 srs2000: 99
  • 1 ssschen: 632
  • 1 stanmore: 907
  • 2 starcrazed: 800, 801
  • 1 starflyer58: 2395
  • 2 staticx57: 205, 646
  • 1 steel_1024: 267
  • 1 steepdrop: 1642
  • 2 stehk: 2198, 2199
  • 1 stephenk: 88
  • 2 stolikat: 1403, 1534
  • 1 strongest2004: 111
  • 1 stuartrue: 457
  • 1 sunnyqueensland: 2405
  • 4 supanate7: 1673, 2459, 2473, 2474
  • 1 superbob47: 1487
  • 1 surasakkongtha: 909
  • 1 sweetleaf99: 665
  • 2 swiftblade13: 2052, 2418
  • 1 sygyzy: 1948
  • 2 syracuse: 150, 2318
  • 2 t3rminal: 867, 868
  • 1 takumi86: 1459
  • 1 tango: 1599
  • 2 tatasal: 559, 670
  • 4 teacher: 80, 81, 1214, 1215
  • 2 teachtom: 204, 2147
  • 1 teejay: 2171
  • 1 tekmunki: 45
  • 1 terranaut: 2216
  • 1 the0dore3524: 1371
  • 2 theRealSammyG: 1512, 1513
  • 2 thebaum: 330, 991
  • 4 thecrc: 870, 871, 872, 1699
  • 1 thegameisrigged: 562
  • 1 thejinn: 1439
  • 2 themaindude: 996, 997
  • 2 theoldbill: 560, 561
  • 1 thijsco19: 116
  • 1 thisnameisvalid: 1588
  • 1 throwton: 2129
  • 1 thslw8jg: 657
  • 2 timbo114: 1591, 1592
  • 1 timezero: 1718
  • 1 tindrum42: 1767
  • 2 tirelight86: 1723, 1965
  • 2 tjl014: 1234, 1235
  • 1 tkd15: 1363
  • 1 tmxod: 416
  • 1 tocirahl: 64
  • 2 toddcshoe: 1044, 1163
  • 1 tomtaylor: 692
  • 1 tonylim: 519
  • 1 tops2: 221
  • 1 torqu3e: 934
  • 3 toxiccoccyx: 69, 398, 1213
  • 1 tpc2084: 2220
  • 4 trakcon: 2059, 2113, 2164, 2283
  • 2 treellama: 1692, 2149
  • 3 treoneo: 633, 669, 713
  • 2 treth: 2138, 2139
  • 1 trevize: 1111
  • 4 trigger619: 262, 263, 1174, 1175
  • 1 tristanxoxo: 447
  • 1 troisanh: 254
  • 1 tru3s1lv3r: 54
  • 2 tsouzee: 2179, 2351
  • 1 ttylamg: 1399
  • 1 tu_army: 1781
  • 1 tui2004: 769
  • 1 tundraotto: 1616
  • 1 tungkon: 279
  • 1 turbiny: 1600
  • 1 turpulator: 940
  • 2 tvizk: 1254, 1601
  • 1 two fifty: 860
  • 1 twodollarbill: 622
  • 1 tzmxxhh: 40
  • 3 uncle_muscle98: 918, 919, 928
  • 1 unknown00101: 777
  • 3 uqs1000: 835, 987, 2457
  • 1 vadimax: 1428
  • 1 valera: 1982
  • 1 varbos: 1001
  • 1 vas: 368
  • 2 vasa_visost: 893, 894
  • 1 velarpinch: 863
  • 2 velocraig: 892, 1473
  • 1 ven: 401
  • 1 vinte77: 22
  • 3 voltron88: 206, 1067, 1746
  • 2 vtqanh: 452, 453
  • 1 vulpes: 229
  • 0 vwpieces: 516, 516
  • 1 w4rkry: 749
  • 1 walty: 233
  • 1 waxing twilight: 1382
  • 3 weklund: 473, 474, 508, 508, 557, 557, 682, 682, 557, 557, 508, 508, 2313
  • 1 wellerus: 1002
  • 1 westcoastwonders: 195
  • 1 wfp: 2032
  • 1 whateatsrabbits: 1549
  • 1 whatthewillus: 1188
  • 2 wheelgunwordslinger: 1319, 1900
  • 3 wheremydonky: 1389, 1390, 1391
  • 1 wheresryan: 1685
  • 2 whipskirtayeyay: 969, 970
  • 1 whooda4: 249
  • 2 whopist: 1232, 2339
  • 3 wiley07: 1287, 1310, 1311
  • 1 will34: 370
  • 1 willc68: 1623
  • 1 wimmer2121: 372
  • 1 wiredconcepts: 84
  • 4 wishiwereaskibum: 666, 675, 1160, 1538
  • 1 wle: 307
  • 2 wobba: 1782, 1783
  • 1 wolfstyle: 1906
  • 1 wonwuster: 943
  • 1 woodlandSerenade: 1859
  • 1 write2dgray: 1027
  • 1 wyatt1209: 1645
  • 2 x-ray: 1618, 1763
  • 2 xCentrino: 599, 600
  • 1 xborax: 1686
  • 2 xdouang: 702, 703
  • 2 xertian: 1412, 1413
  • 1 xevious: 1923
  • 1 xikteny: 1364
  • 2 xray291: 341, 792
  • 1 xxx: 720
  • 2 yanya: 2335, 2336
  • 2 yasenf: 412, 413
  • 1 yclongthrow: 550
  • 2 yokomus: 1299, 1376
  • 1 youmansk: 1855
  • 1 yuhsin91123: 719
  • 1 zachary6227: 105
  • 5 zak.wilson: 20, 126, 127, 128, 129
  • 1 zapviii: 1504
  • 1 zaxar0580: 2471
  • 2 zcbtjwj: 798, 799
  • 1 zelee: 152
  • 1 zeroair: 304
  • 1 zeroflow: 1331
  • 1 zifzif: 350
  • 1 zipelgas: 68
  • 1 zortan: 407
  • 1 zotee123: 1395
  • 2 zoysiamo: 47, 2286
  • 1 zxgeoff: 1739
  • 1 zzhawk: 787
  • 1 zzzbgd: 1201
  • FW3A thread – contact Neal on BLF or email for FW3A questions and support
    FW3A Team
    FW3A Team's picture
    reserved
    Jerommel
    Jerommel's picture
    Last seen: 1 week 4 days ago
    Aha, so this is what you were talking about. Thumbs Up
    Very nice !
    …uhm.. no DD driver i hope? Hopefully it will be a CC driver, but with enough (6 to 12) Amperes, like the LD2 (or LD3?) without PWM.
    Another thing, about the anodizing, clear anodizing can make it look very cheap, maybe better to have no anodizing OR sandblasted finish.
    But i love the design concept. Love
    Will possibly be as tiny as the DQG ?
    Abqjohnny
    Last seen: 1 year 1 month ago
    This would be my first multi-emitter flashlight since the old days of blue and purple leds.
    The Miller
    The Miller's picture
    Last seen: 6 months 3 days ago
    Triple channel driver
    So a FET for highest modes but more birhgtness levels on 7135 chips then FET+1 drivers
    94.8 × 25.5 is the FW3A, pretty small Wink
    fritz15
    fritz15's picture
    Last seen: 1 year 6 months ago
    Jerommel wrote:
    […] But i love the design concept. Love Will possibly be as tiny as the DQG ?
    No, the DQG sacrifices too much in order to achieve its small size for my liking. It has no glass lens to protect the optics, especially for an EDC light this is important. Additionally, there is no tailcap spring, which is quite bad for the battery and the LED sits directly on the driver-PCB which grants horrible heat-sinking.
    Speed4goal
    I’d like to be put on a blf list if there is one
    2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
    Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
    Tom E
    Tom E's picture
    Last seen: 4 hours 26 min ago
    Put me down for two please smile
    Muto
    Last seen: 1 hour 19 min ago
    Put me down for 2 also, sharp looking flashlight!
    Later,
    Keith
    “History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
    Well I don’t know if I’m coming or going
    If it’s them or me
    Oh, but one things for certain
    Willie Nelson only smokes the killer weed
    After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
    Chicken Drumstick
    I’d be interested in 1 please.
    Stittville Ed
    Stittville Ed's picture
    Last seen: 2 days 4 hours ago
    A 18650 with a belt clip, Perfect Smile
    One for now with the option to increase order at a later date.
    Looks like another great light with a Coooooooool looking factor.
    KawiBoy1428
    KawiBoy1428's picture
    Last seen: 2 hours 27 min ago
    I would be down for 2 also! Thumbs Up
    Very nice!
    KB1428 “Live Life WOT
    The Miller
    Oh wauw, I’ve had small DQG lights in my cart many times but felt great hesitation to actually buy one and reading this makes me feel good about it Wink
    Petroleum Lante...
    Petroleum Lantern Guy's picture
    Last seen: 2 days 11 hours ago
    Count me in for one, this sounds great!
    I love all kinds of lights... storm lanterns, kosmos & matador lamps, gas lanterns, tallow lanterns, flashlights, lasers, tritium vials...
    archimedes
    archimedes's picture
    Please sign me up for one of them. Thanks.
    chooma
    Last seen: 55 min 12 sec ago
    1 please
    giorgoskok
    giorgoskok's picture
    Last seen: 1 day 3 hours ago
    1 please
    BTW , even should be 25$ possible .
    Ozythemandias
    Last seen: 2 days 1 hour ago
    I’m assuming 18650, I didn’t see it specified.
    I’ll take two!
    DB Custom
    DB Custom's picture
    Last seen: 1 day 14 hours ago
    I’ll have to toss my hat in the ring on this one as well.
    I don’t know when it might occur, if I’m not present much at the time please have KawiBoy or J-Dub send me an email and wake me up…
    pinkpanda3310
    pinkpanda3310's picture
    Last seen: 3 hours 10 min ago
    In for one please
    bikedave99
    Last seen: 2 weeks 5 days ago
    In for one, really like the look of this!
    So, since the design is complete does this roll right into prototyping?
    zak.wilson
    Last seen: 12 hours 24 min ago
    I may be missing something, but why not just put the driver in the tail? Most of these FET and 7135 drivers work by applying PWM (and in the case of the 7135, variable resistance) between LED- and BAT-. The connection from BAT+ to LED+ is direct; it doesn’t even touch the driver board in the case of the new version 17DDm.
    Regardless, this looks awesome. Please put me on the interest list.
    Ceilingbounce – flashlight testing and runtime graphs for Android
    Easyrr
    Last seen: 1 month 1 week ago
    In for one, whenever it’s ready. Smile
    vinte77
    Last seen: 15 hours 7 min ago
    I would like to buy one.
    -X3-
    -X3-'s picture
    Last seen: 2 days 10 hours ago
    I never thought of that, it’s a good idea !
    BTW, i’m in
    "-X3-, is there any place in your house without a flashlight ?"
    My Flashlight public album (mods, emitter swaps, eye candy)
    My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
    My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
    M4DM4X blog, saves you $$$
    Jerommel
    Jerommel's picture
    The driver will need a BAT+ too for it to work.
    But that inner tube can do that. but a thin strip of copper or even nickel plated iron would suffice.
    Me too, if that wasn’t already obvious. Smile
    cavorite
    Last seen: 1 day 21 hours ago
    1 please
    The Miller
    OP list updated
