11864 posts / 0 new
sac02
sac02's picture
Last seen: 1 week 4 days ago
fritz15 wrote:
Jerommel wrote:
[…] But i love the design concept. Love Will possibly be as tiny as the DQG ?
No, the DQG sacrifices too much in order to achieve its small size for my liking. It has no glass lens to protect the optics, especially for an EDC light this is important. Additionally, there is no tailcap spring, which is quite bad for the battery and the LED sits directly on the driver-PCB which grants horrible heat-sinking.
Well, the size of this light is still excellent, under 95mm.
I will buy at least one for sure.
The Miller
The Miller's picture
bikedave99 wrote:
In for one, really like the look of this!
So, since the design is complete does this roll right into prototyping?
We are talking to a Chinese party. Cannot say more for now.
Driver is needed close to the LED for the thermal regulation of Narsil to do its job, though a driver in the tail is clever indeed Smile
Jerommel
Jerommel's picture
Last seen: 1 week 6 days ago
I agree.
I set out to mod it but i have put it aside for later…
Yeah, it’s a shame they didn’t use a metal PCB (alu or copper), that would have solved the heat problem it has.
But when you put a triple in it, you gain space for a MCPCB on the shelf.
And since this thing here has a triple set up, i thought it might be just as short as the DQG.
2Q19
Stittville Ed
Stittville Ed's picture
Last seen: 13 hours 7 min ago
Stittville Ed wrote:
A 18650 with a belt clip, Perfect Smile
One for now with the option to increase order at a later date.
Looks like another great light with a Coooooooool looking factor.
I was post #14 and you did not put me on the list……………..
“No Soup For You”
richnpc
Last seen: 20 min 48 sec ago
Great looking light, and design. Please add me to the list.
hunter1
hunter1's picture
Last seen: 22 hours 29 min ago
Please put me up for one..
Henk4U2
Henk4U2's picture
Last seen: 44 min 17 sec ago
This is really going to be a multilingual enterprise. I guess 3 languages is 36 times more challenging than 2 languages.
At my age you want lumens. If there is to be a CW version, put me on the list for one.
The add-on in my eyes automatic translates CW to other parts of the spectrum. Cool
To compensate for my eye-sight I have certain other means of perception.
In my crystall ball I can see versions with wood tubes (RBD) and carbon tubes (CRX) due to the double tube.
PS: Please hit the “rude”-button if I (mis)quote lines from popular UK made TV-series.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Henk4U2
Henk4U2's picture
“No Soup For You”
I know who said that Facepalm
Bam35
Last seen: 1 month 1 week ago
I would like one. Please put me on the list. Thanks
mrheosuper
Last seen: 1 day 12 hours ago
just checked my balance, too bad, i’m so broken
i need an oscilloscope instead of 1 more light Facepalm
Forgot my pen
djburkes
djburkes's picture
I’ll take 2 please.
Rat_Racer
Please add me in for 1
The Miller
“No Soup For You”
Don’t know who said it but sure not right I missed you Stittville, will correct it next time list gets updated, sorry.
DB Custom
DB Custom's picture
Last seen: 2 days 17 hours ago
I know, I’m probably too much the technical perfectionist (or anal or something) but…
The tail cap is not meant to be taken off to change the cell, so why does it have knurling on it? With the design calling for the tube to be removed for a cell change the tube itself should have knurling to make it easier to take the sections apart. Right? Then that little groove on the tail cap could be left solid so the threads would be that much stronger.
I’m saying this because of the square threads at the head and the retaining ring on the driver. There are normal weaker threads on the tail cap and no retaining ring on the switch PCB, hence, battery swap through the top.
Is this something that can be addressed?
I’m so forgetful I’d forever and always be removing the tail cap to get to the cell, like all the other lights I own.
zak.wilson
Last seen: 7 hours 22 min ago
That’s a very good reason.
It would be great if there were some Nichia options, as I have little interest in the XP-G3. I’m interested either way though; I can change the emitters myself.
Ceilingbounce – flashlight testing and runtime graphs for Android
djozz
djozz's picture
Last seen: 3 min 56 sec ago
I can not else but love it? Well done Fritz!
The clear ano would not be my idea, and it will have huge problems running on the FET (15+ amps, on XP-G3 while 3A is sensible for a skinny light like this and already gives lots of light), but still I’m in wholeheartedly. Smile
maukka
maukka's picture
Last seen: 5 hours 14 min ago
Put me up for one, thanks.
MtnDon
MtnDon's picture
Last seen: 12 hours 45 min ago
I would like 1
BLF Member Map Add your name and location.
Jinx
Jinx's picture
Last seen: 23 hours 19 min ago
1 for me please Smile
fritz15
fritz15's picture
Last seen: 7 months 14 hours ago
zak.wilson wrote:
I may be missing something, but why not just put the driver in the tail? Most of these FET and 7135 drivers work by applying PWM (and in the case of the 7135, variable resistance) between LED- and BAT-. The connection from BAT+ to LED+ is direct; it doesn’t even touch the driver board in the case of the new version 17DDm.
That is a good idea and I thought briefly about it but was not comfortable with the Battery+ being so close to Battery- (the microcontroller for example needs a connection to Battery+). In case of a short between the two tubes (for whatever reason) you’d fry the battery. With the current design the worst thing that happens is that the light gets turned on and you still can operate it by loosening and tightening the head.
chops728
Last seen: 3 hours 7 min ago
Nice—-I’ll take one
DB Custom
DB Custom's picture
djozz points at my initial thought, anyone realize how hot this will get and how fast it will do it? I’ll wager that on a good cell, in Turbo, you won’t be able to hold it in 20 seconds. Wink (Thermal step down not inclusive, it won’t run long in Turbo in other words, not long at all)
scotlarock
Last seen: 3 days 23 hours ago
I like it! Please put me down for one.
Thanks
-X3-
-X3-'s picture
Last seen: 4 min 4 sec ago
Hey, after all a Turbo is’nt meant to be used for extended time Silly
Seeing my HC30 TA FET driven getting scorching hot in less than 30S, I can’t imagine how this one will get with 3 emitters freely fed by a 30Q !
A true Pocket rocket !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
DB Custom
DB Custom's picture
Fun, Ain’t it? Big Smile
I had 4 XHP-50’s in a Lucky Sun D80, made an extension tube for it so it’d run with 2 18650’s. What a heater that one was!
tzmxxhh
I`d like one. Thank you!
The Miller
Dale with the knurled head changing cells shouldn’t be a problem. Designwise a knurled tube would not look as nice as what Fritz made IMHO
aginthelaw
aginthelaw's picture
Last seen: 17 hours 14 min ago
i’ll take one of each (assuming a copper and titanium version will follow). otherwise, just this one
never fear shadows…it means a light shines nearby
Enelooper
Enelooper's picture
Last seen: 3 weeks 5 days ago
Put me on the list for one, please.
Nitetime
Last seen: 3 days 12 hours ago
This looks great!
Sign me up for one please.
