This is really going to be a multilingual enterprise. I guess 3 languages is 36 times more challenging than 2 languages.
At my age you want lumens. If there is to be a CW version, put me on the list for one.
The add-on in my eyes automatic translates CW to other parts of the spectrum. :sunglasses:
To compensate for my eye-sight I have certain other means of perception.
In my crystall ball I can see versions with wood tubes (RBD) and carbon tubes (CRX) due to the double tube.
PS: Please hit the “rude”-button if I (mis)quote lines from popular UK made TV-series.
I know, I’m probably too much the technical perfectionist (or anal or something) but…
The tail cap is not meant to be taken off to change the cell, so why does it have knurling on it? With the design calling for the tube to be removed for a cell change the tube itself should have knurling to make it easier to take the sections apart. Right? Then that little groove on the tail cap could be left solid so the threads would be that much stronger.
I’m saying this because of the square threads at the head and the retaining ring on the driver. There are normal weaker threads on the tail cap and no retaining ring on the switch PCB, hence, battery swap through the top.
Is this something that can be addressed?
I’m so forgetful I’d forever and always be removing the tail cap to get to the cell, like all the other lights I own.
It would be great if there were some Nichia options, as I have little interest in the XP-G3. I’m interested either way though; I can change the emitters myself.
The clear ano would not be my idea, and it will have huge problems running on the FET (15+ amps, on XP-G3 while 3A is sensible for a skinny light like this and already gives lots of light), but still I’m in wholeheartedly.
That is a good idea and I thought briefly about it but was not comfortable with the Battery+ being so close to Battery- (the microcontroller for example needs a connection to Battery+). In case of a short between the two tubes (for whatever reason) you’d fry the battery. With the current design the worst thing that happens is that the light gets turned on and you still can operate it by loosening and tightening the head.
djozz points at my initial thought, anyone realize how hot this will get and how fast it will do it? I’ll wager that on a good cell, in Turbo, you won’t be able to hold it in 20 seconds. (Thermal step down not inclusive, it won’t run long in Turbo in other words, not long at all)
Hey, after all a Turbo is’nt meant to be used for extended time :-p
Seeing my HC30 TA FET driven getting scorching hot in less than 30S, I can’t imagine how this one will get with 3 emitters freely fed by a 30Q !
A true Pocket rocket !
