Please add me in for 1
Don’t know who said it but sure not right I missed you Stittville, will correct it next time list gets updated, sorry.
I know, I’m probably too much the technical perfectionist (or anal or something) but…
The tail cap is not meant to be taken off to change the cell, so why does it have knurling on it? With the design calling for the tube to be removed for a cell change the tube itself should have knurling to make it easier to take the sections apart. Right? Then that little groove on the tail cap could be left solid so the threads would be that much stronger.
I’m saying this because of the square threads at the head and the retaining ring on the driver. There are normal weaker threads on the tail cap and no retaining ring on the switch PCB, hence, battery swap through the top.
Is this something that can be addressed?
I’m so forgetful I’d forever and always be removing the tail cap to get to the cell, like all the other lights I own.
Driver is needed close to the LED for the thermal regulation of Narsil to do its job, though a driver in the tail is clever indeed
That’s a very good reason.
It would be great if there were some Nichia options, as I have little interest in the XP-G3. I’m interested either way though; I can change the emitters myself.
I can not else but love it? Well done Fritz!
The clear ano would not be my idea, and it will have huge problems running on the FET (15+ amps, on XP-G3 while 3A is sensible for a skinny light like this and already gives lots of light), but still I’m in wholeheartedly.
Put me up for one, thanks.
I would like 1
1 for me please
I may be missing something, but why not just put the driver in the tail? Most of these FET and 7135 drivers work by applying PWM (and in the case of the 7135, variable resistance) between LED- and BAT-. The connection from BAT+ to LED+ is direct; it doesn’t even touch the driver board in the case of the new version 17DDm.
That is a good idea and I thought briefly about it but was not comfortable with the Battery+ being so close to Battery- (the microcontroller for example needs a connection to Battery+). In case of a short between the two tubes (for whatever reason) you’d fry the battery. With the current design the worst thing that happens is that the light gets turned on and you still can operate it by loosening and tightening the head.
Nice—-I’ll take one
djozz points at my initial thought, anyone realize how hot this will get and how fast it will do it? I’ll wager that on a good cell, in Turbo, you won’t be able to hold it in 20 seconds. (Thermal step down not inclusive, it won’t run long in Turbo in other words, not long at all)
I like it! Please put me down for one.
Thanks
Hey, after all a Turbo is’nt meant to be used for extended time :-p
Seeing my HC30 TA FET driven getting scorching hot in less than 30S, I can’t imagine how this one will get with 3 emitters freely fed by a 30Q !
A true Pocket rocket !
Fun, Ain’t it?
I had 4 XHP-50’s in a Lucky Sun D80, made an extension tube for it so it’d run with 2 18650’s. What a heater that one was!
I`d like one. Thank you!
Dale with the knurled head changing cells shouldn’t be a problem. Designwise a knurled tube would not look as nice as what Fritz made IMHO
i’ll take one of each (assuming a copper and titanium version will follow). otherwise, just this one
Put me on the list for one, please.
This looks great!
Sign me up for one please.
In for 1 please.
