Fun, Ain’t it?
I had 4 XHP-50’s in a Lucky Sun D80, made an extension tube for it so it’d run with 2 18650’s. What a heater that one was!
Fun, Ain’t it?
I`d like one. Thank you!
Dale with the knurled head changing cells shouldn’t be a problem. Designwise a knurled tube would not look as nice as what Fritz made IMHO
i’ll take one of each (assuming a copper and titanium version will follow). otherwise, just this one
Put me on the list for one, please.
This looks great!
Sign me up for one please.
In for 1 please.
I’d be down for one!
Possible one for me.
Put me down for one as well, please.
Good thoughts! The tailcap has knurling on it to improve the overall grip and also of course, to make it match to the head. The groove is just to have a clear stop for the knurling and the thickness of the wall is just as much as at other “thin” spots, so there is no decrease in durability there.
The reason the head is used to change the battery is because the head is larger which makes it easier to grip. The tailcap is very short and I think it wouldn’t be very easy to get a hold of it, especially with the clip besides it. Then you’d also have to be careful to not rotate the clip (so the anodizing doesn’t scratch off). That way I think it’s easier - construction-wise it’s also a little safer because then the driver is fixed in place, which is more important than the switch-PCB being held in place.
heheh this is the A
Who knows when this is a success B C and T might follow. Brass Copper Titanium (dang that it is not called Ditanium :D, can somebody ask the International Union of Pure and Applied Chemistry to change Ti to Di for us ))
Please add me to the list for 1, thank you.
Put me in for one please.
Wow awesome design Fritz The light is very well detailed.
Put me down for one please miller.
Sign me up for one!
Will update the list later!
Welcome to BLF
aha I guess you have to figure out where to place the USB charging port and cool the XHP35 first now that you know the size of the tube to make that from brass
Can’t wait on what you are going to do with it, from scratch and not special lights you create art, what would come from starting with something as the FW3A!
Count me in for one, please.
Please add me to the list for one. Thanks.
Id be really keen if there was to be a Nichia 219C 4000k triple emitter version:
http://www.mtnelectronics.com/index.php?route=product/product&product_id=839&search=219C+4000K
Would that be possible?
