If the former, would there be any way to not have the battery-tube thinned down like that, but be the same diameter as the 2 “collars”? (Basically, just skip that one step in machining-down the tube.)
Gawd, I’d love to have a straight-through light like that. Basically an overgrown BLF348…
In the discussion we’re having about this light on reddit, fritz15 asked for votes about users’ preference for the emitter. The XP-G3 option, and indeed the current planned emitter is 5000K and 70 CRI (not sure if that’s specified or just typical). That option has no votes at the moment, while the other option, a 4000K Nichia 219C (90 CRI) has 9 votes.
My own preference would probably lean toward a 5000K 219C, but there are often group buys for emitters here and I have a soldering iron.
After a long hiatus from Flashlights it is great to see this project. A ground up, truly custom built budget light. Thanks everyone who is a part of this project. Size of this light seems so nice, please put me on the interested list
Oh My! With a negative power feeding to the LED's via the host, one could use DTP with emitters that don't have dedicated thermal pads. This light's design will open up some nice possibilities. :)
EDIT: Haven't decided if I will join this GB due to the clear finish, but I certainly wish the best on the endeavor. Very sweet light this will be for sure.
NarsilM is com'n along pretty good now. 2 and 3 output channels can be configured with compile time settings. Been testing it on a triple channel board.
Think'n it would be perfect for this light - same UI, same manual as for the BLF Q8, and should also work for the BLF GT.
