While getting ready to replace my driver in my black L6 I happen to notice the wires reversed.
EDIT: IOW, the stock light from the factory had the leads reversed, red on (-) black on (+).
I checked the wires on the stock driver and they seemed properly placed. JasonWW suggested it was probably the “factory” LED being put on backwards. So I installed a new TA Driver I received from Lexel and just matched the backward wiring on the mcpcb, and it works.
Just making a note here for others to double check before you desolder and not notice wire placement.
True Jason, but if the light was working before the mod, simply adhering to the placement of pos/neg wires would have done the trick without worrying about it. I have put one on the star backwards before and wired it accordingly to save time, then later, re-modding it, the wiring was confusing. The simple logic that it worked that way made it clear what I’d done before.
My L2 should be here tomorrow, left Austin earlier this evening, so I’ll be ready to put the XHP-35 in it and have some fun.
Anyone with Texas Avenger in a L6, and Narsil experience know if this is normal.
When side switch is turned off, but not off at the tail switch, the emitter has a very low glow, to it. Its almost like having an illuminated switch at the head. Just wondering if I did something wrong.
I’ve also observed emitters glowing in my 2s 7xXPL light with a FET driver. I also observe the glowing in its current configuration which is a FET and voltage divider, no MCU. I think it is simply the leakage current of the FET. You don’t see glowing in 1s lights because the voltage across the FET is lower so lower leakage current. Also when the batteries in my 2s light are lower voltage, like 3.7V, the glowing is dimmer or non existent.
Maybe I can assume I didn’t get to sloppy w soldering. For my use, it will act as a tail switch “is on” indicator (& battery warning, come to think of it). Very faint spot of light on the ground when walking (arms down). Not even enough light to read a map in the pitch dark.
You may be right, but I’ve observed the glowing with a FET-only driver with Zener mod.
I just experimented with a couple FETs I bought from mtnelectronics. Their spec is for ~1 microamp leakage current at 0V gate voltage and 20V drain-source voltage. I measured it with an LED in the circuit and got less than 0.1 microamp at 20V (not measurable on my DMM) and the LED did not glow at all. So FET leakage at 0V gate voltage cannot explain the glow. With my sliding resistor 7xXPL light the lowest setting has the gate voltage not equal to 0V, so that could explain some higher leakage in that case. But when I had a FET-only driver with Zener mod I also observed the glowing, so this is unexplained by me.
To satisfy my curiosity I measured the current through an LED necessary to notice the glowing. It needs about 5 microamps to clearly notice the glowing. To measure this I just put a 4.7 megaohm resistor in series with the LED while adjusting the voltage and measuring the current.
My Noctigon Meteor M43 will do this, glow when off. I have 12 XP-L emitters and a single 17mm FET driver, not zener modified as I’m running 4P cells. I have to keep it in lockout or it will drain the cells.
It makes 11,700 lumens in Turbo, so I’m not going to complain about a slight glow when off. (After I typed that 11,700, my memory question check kicked in. It’s up around 11,000 I know but that specific 11,700 is possibly wrong.)
Found my old cheap meter with 10amp dc capability (I dont have a clamp meter). Made 2 X 6” 10ga leads. Measured Stock L6 vs TA Driver L6 mod on the same Keeppower Protected cells @ 4.16v = 5.4 amp vs 7.6 amp, does that seem reasonably close as comparison? How would 40% increase in amps relate to lumens? I don’t have a lux meter.
Got some of the new Shockli 5500mah on the way, expect they will do better.
Look at djozz’s XHP70 measurements to get an idea of the output increase. They are buried in the long XHP70 thread. If you do a Google image search for ’XHP70 test” you will see the graph. Just a rough estimate is 40% increase in current might give you 30-35% increase in lumens.
The shockli cells will perform better. Where did you buy them?
