I think you might have misunderstood. (Or did I not understand what you said?)
Someone at the factory installed the xhp70 emitter backwards on the star/mcpcb. So the plus and minus printed on the star are no longer correct.
True Jason, but if the light was working before the mod, simply adhering to the placement of pos/neg wires would have done the trick without worrying about it. I have put one on the star backwards before and wired it accordingly to save time, then later, re-modding it, the wiring was confusing. The simple logic that it worked that way made it clear what I’d done before.
My L2 should be here tomorrow, left Austin earlier this evening, so I’ll be ready to put the XHP-35 in it and have some fun.
Anyone with Texas Avenger in a L6, and Narsil experience know if this is normal.
When side switch is turned off, but not off at the tail switch, the emitter has a very low glow, to it. Its almost like having an illuminated switch at the head. Just wondering if I did something wrong.
Did you ask Lexel yet?
I’ve also observed emitters glowing in my 2s 7xXPL light with a FET driver. I also observe the glowing in its current configuration which is a FET and voltage divider, no MCU. I think it is simply the leakage current of the FET. You don’t see glowing in 1s lights because the voltage across the FET is lower so lower leakage current. Also when the batteries in my 2s light are lower voltage, like 3.7V, the glowing is dimmer or non existent.
Thanks EasyB
Maybe I can assume I didn’t get to sloppy w soldering. For my use, it will act as a tail switch “is on” indicator (& battery warning, come to think of it). Very faint spot of light on the ground when walking (arms down). Not even enough light to read a map in the pitch dark.
Try doing an amp draw across the tail cap (EDIT: with the light off on the side switch)
You also might ask Texas Ace since he designed these drivers.
I’ve never heard of this happening, but then again, TA drivers in L6’s are kinda rare.
I’ll let you know if mine does it once I get my driver.
You could always add a led under a clear side switch cover to let you know the rear switch is on. Also to help find the switch at night.
Wouldn’t you know it…I go reread / youtube amp draw measuring only to find out my Fluke 1587 only does 400ma, and has a blown fuse, to boot.
Remember mine has the Infineon and if your getting SIR800, it may be apples to oranges.
I tested the drivers with a Nichia 219 triple so on LDO drivers I did not drive the driver and LEDs with 2S voltage
My guess on that glow is a faulty 7135 that causes a very low leak current
Ok, thanks for that. Then chances are my second driver may not exhibit the same when I install it.
That makes my one of a kind light, “extra special”. :+1:
You may be right, but I’ve observed the glowing with a FET-only driver with Zener mod.
I just experimented with a couple FETs I bought from mtnelectronics. Their spec is for ~1 microamp leakage current at 0V gate voltage and 20V drain-source voltage. I measured it with an LED in the circuit and got less than 0.1 microamp at 20V (not measurable on my DMM) and the LED did not glow at all. So FET leakage at 0V gate voltage cannot explain the glow. With my sliding resistor 7xXPL light the lowest setting has the gate voltage not equal to 0V, so that could explain some higher leakage in that case. But when I had a FET-only driver with Zener mod I also observed the glowing, so this is unexplained by me.
To satisfy my curiosity I measured the current through an LED necessary to notice the glowing. It needs about 5 microamps to clearly notice the glowing. To measure this I just put a 4.7 megaohm resistor in series with the LED while adjusting the voltage and measuring the current.
My Noctigon Meteor M43 will do this, glow when off. I have 12 XP-L emitters and a single 17mm FET driver, not zener modified as I’m running 4P cells. I have to keep it in lockout or it will drain the cells.
It makes 11,700 lumens in Turbo, so I’m not going to complain about a slight glow when off. (After I typed that 11,700, my memory question check kicked in. It’s up around 11,000 I know but that specific 11,700 is possibly wrong.)
Found my old cheap meter with 10amp dc capability (I dont have a clamp meter). Made 2 X 6” 10ga leads. Measured Stock L6 vs TA Driver L6 mod on the same Keeppower Protected cells @ 4.16v = 5.4 amp vs 7.6 amp, does that seem reasonably close as comparison? How would 40% increase in amps relate to lumens? I don’t have a lux meter.
Got some of the new Shockli 5500mah on the way, expect they will do better.
I’m new at this.
Look at djozz’s XHP70 measurements to get an idea of the output increase. They are buried in the long XHP70 thread. If you do a Google image search for ’XHP70 test” you will see the graph. Just a rough estimate is 40% increase in current might give you 30-35% increase in lumens.
The shockli cells will perform better. Where did you buy them?
Ordered them direct from Shockli / Windyfire.
Quote from Shockli:
“Please check the below cost of 4pcs Shockli 26650,5500mAh battery
goods value:$4.78*4=$19.12
shipping cost by Fujian post: $8.4, it will take about 20-25 days to your place.
paypal handing fee: $1.1
So the total cost of the order is $28.62,”
Thanks. That’s a real good price if you buy enough to spread out the shipping cost.
I meant, do an amp draw at the tail with the light off, not on. That way you can see the amount of drain.
Had to enlist my wife as a third hand, to switch side switch off. Amps dropped to 0.00 (display resolution only shows hundredths).
Got a new Convoy L2 in today, XM-L2 NW, almost 1000 lumens on a single cell. While I really really dig the dimensions on the single cell beauty, I had something else in mind.
I did some machine work on it to fit a 26mm MaxToch mcpcb onto the shelf, loaded a XHP-35 E2 3A emitter on it, bored out the driver bay to take Mountain Electronics MTN Buck driver at 27.5mm and 2.5A for the 12V emitter.
No tail spring bypass and with a rigged spacer as the cells are a bit short (I’m using 3 extension tubes, 4 Basen 26650’s) It’s making…
0.01A for 2.59 Lumens
0.05A for 71.42
1.03A for 1193.7
2.42A for 2352.9 and 2270.1 at 30 seconds.
Edit: Lux is 258Kcd for 1015.87M throw. Not fantastic, but not too bad either.
I machined inside the head and outside the reflector to allow the reflector to sit deeper, used Simons taper centering ring he designed for the XP-L, works great! Kind of a Convoy tribute to the old 4 cell MagLite of old.
(had to double up on some pain meds, made it through pretty well, covering the lathe back up in the shop is a major pita though, ugh!)
Yeah, that’s too high a range. You’d need to switch to milliamps. Maybe one of your other meters can read it.
Nope, with your tactical setting you won’t be able to measure it as it will turn on in turbo mode as soon as you connect power. Don’t try it! You’ll blow a fuse.
My FX30 when switched off at the side switch draws 1.45 millamps. I keep the rear switch on only at work and recharge the batteries every week and I haven’t noticed the drain at all.
