Hi…
Interested 1 piece if still can be added to the list.
Very eye catching design:) Will be awesome if there is AA/14500 form factor.
Hi…
One for me please. Thank you.
The Efest dark purple 3000mAh cell is also on par with the Sony VTC6 and LG HE-2. There is also a dark purple 3500mAh cell in the Efest line that would work well for only slightly less output with more run time.
Fritz, am I right to assume that the anodize layer inside the battery tube will insulate the thin inner tube carrying negative current? Seems simple enough. I suppose the thin tube could also be anodized then have the ends cleared for contact, this might or should double the effective insulation against a short on negative. Just thinking out loud.
Also noticed the rib on the pcb end that will keep the slim tube from falling out when making cell changes, neat touch.
Folks, let’s make it a little easier for the organizer (The Miller in this case), whenever you’re putting yourself on any interest list, please be concise and unambiguous. Over the past year I’ve been on BLF, I keep seeing people use words like “at least”, “maybe”, etc.
How is the organizer supposed to know what you really mean? If you are undecided, come back and post after you make up your mind.
Yeah list will be updated later
Indeed when it is not clear I either add a question mark or in case of “I want one with Nichia LEDs” or something I don’t add for it is specified as having something else then Nichias
Dale indeed the small inner tube needs anodization and you are right, it is not discussed but the outer tube will get ano inside and out making a nice double layer of insulation.
OK, good point. I stand corrected. My bad.
Based on the data given in the OP: I take 1 piece of NW.
BUT IF I CAN CHOOSE between NW & CW: I take 1 piece of CW.
W, I bet you Djozz or another Durchee will gladly reflow a couple of left over CW emitters in place of the NW ones
interested.
Yay more torches
Put me down for one please.
Any plans for a 18500 tube :innocent:
No plans for 18350/16340/14500/AA
The FW3A is so small yet has a 18650 for max runtimes
This is not a light for the faint of heart or people not aware of li ion safety. For us flashoholics without a lathe it is a real treat and sure the turbo will probably make those around us not understanding what we keep on talking about more understanding what we talk about
In for one, please!
Put me down for one. 5k XP-G is ok, with 4k I def prefer Nichia. Thanks!
Put me down for two of these little beauties. Thanks
Hey,
I’m in for one, aswell. Sounds like a great little light!
Alex
Neat… Put me down for two please.
How did I miss this???
One for me please
Yep will update list later!
Two days not online and now this…
Put me down for one, please!
Please, one for me too.
Another bit of MillerMagic!
One please.
