hmmmmm. Just started looking at this thread. Mine is also marked like yours.Theirs in not only marked in a different location, but they separate Thrunite and TN42! I think that means OURS has a bit more output! I know mine does[VN]!
Hold on a second! I found something on my tail cap that neither you or Taschenlampen have!
Is all that throw very useful, especially with a narrow beam? Doesn’t atmospheric scattering (especially with cool white) limit how far the beam can go, and how well you can see “around it” (with all the light being scattered back)?
I don’t have any LED lights approaching anything like that kind of throw, but I used to have a 200w spot-light that would throw like that. Since it wasn’t LED, it was large and heavy and impractical, but it sure threw out a wall of photons. So, I understand the fun part, but is it really useful?
It is useful to me and my Husky Capo! Because the beam intensity at 300,400 or 500 yards is worth it. You can light things up like a barn, Deer or small animal. I am able to put a lot of light on a target I would not normally be able to see.
Then there is the fun of seeing it travel over 1 mile, along with a friend who was at the target[cell tower]. :+1:
In addition to the two replies located above this post: Of course it is useful. It all depends on what range your target is at, and what size of the target. I like the rifle cartridge caliber analogy. Short range low power is a 30-30, short range high power is a .458. Long range low power is a .257, and long range high power is a .378. So, whether you need a 257 or 30-30 or 458 or .378 depends on size and distance of target. That is why I have more than a few lights. Largest lights for the most power at far range, smallest lights for low power at short range, and in between lights for in between range and in between power. All of the zillions of "Flood versus Throw" topics that are so popular in the flashlight forums all boil down to this: What you want, what you like, what you need. Not what someone else needs/wants/likes. My TN42vn cw is tops for two things: Small target far away, and the fun of such. Also, because the beam is narrow, there is very little self-glare; the target appears crisp, clear and sharp.
I did the Pre-Order through Thrunite and ended up with serial number 2. I can’t believe I let it go, seriously liked that light and being somewhat of a numbers freak the number 2 on it should have guaranteed it a spot on my shelves forever. Used it pretty often spotting coyotes, must’ve really brainfahrted on that one…
Okay, I wondered about that. Most lights I’ve seen, especially the cooler tint ones, scatter a lot of light on humid nights. But I’ve never used one with such a thin beam.
Does it really penetrate far on humid nights? I swear on some nights that there’s a wall 100 yards away where light just stops.
One of two things, defective emitter or the emitter was not flowed onto the MCPCB properly or completely. The responsibility to fix a sick light is on the manufacturer or distributor
…. I can’t believe you did either …… :person_facepalming: … … First I heard of it……
Especially after our conversation starting 13 November 2016 by the wonder of PM technology. :person_facepalming: … :cry:
I have however heard it said that time heals all wounds…… hopefully, in time; this wound of not owning this most unique DB Custom TN42 will at least scab over & begin to heal in a few years. :cry:
Humid nights: For me, not applicable. I live in central Arizona hilly high country. It is very easy to see that some lights are better throwers than others.
There’s a good reason that fog lights on a car have a low horizontal beam profile, helps cut under the wall of fog. In my day a fog light was always orange-yellow to help reduce glare for the driver.
Driving in fog teaches a driver a lot, click the high beams on and get blinded! So trying to use a thrower in a high humidity or saturated air scenario is going to yield pretty equal results. Just the nature of things.
