Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
:FACEPALM: English Premier Soccer of course. World's greatest sport, best league in the world. The "beautiful game", etc.
Chelsea is one of the top teams, currently in 1st place. Yea, not too popular here...
I see the following on the original list. I’m sure The Miller can update.
443 cabfrank
988 cabfrank 2nd?
1076 cabfrank 2nd
Please put me down for one more. Total of two.
Thanks.
AHA, yep good find Mr.Scott, thanks!
Do you want the third spot or shall I place somebody asking to be put on the list on the third spot cabfrank?
It’s sorted asciibetically. That’s how I prefer to sort things.
LANG=C FTW
To change this behavior, on a Linux system, use LANG=en_US.UTF-8 instead.
It’s no big deal, just let folks know that they need to look twice. It’s SOOOO much easier than without any sorting at all.
Can’t find my name on the list
Better give it away before I get tempted. Thank you!
List has been updated.
I thought you were an EBCDIC kind of girl. ASCII is way too common. At least ROT13 it before your sort!
I'm already set to use UTF-8.
$ env | grep LANG
LANG=en_US.UTF-8
GDM_LANG=en_US.UTF-8
It is either python or pandas.
Looks like you are good for two.
ilovejesuschrist: 294 295
Still waiting to apply for battery interest list for eu. (Hope you consider Turkey as a EU country after all these)
I insist on only using Etaoin Shrdlu.
Can we discuss this a bit? What is the plan for the discount codes? I think the idea was to have more than one discount code but less than a unique code per buyer.
With one discount code, people can purchase more than they signed up for, which leaves those who don’t order the first day running the risk of getting an “out of stock” message. One code per buyer is a logistical nightmare, one code per light is a data entry nightmare. Now that we are getting close to buy time, having a plan for this is important.
PS, Tom, congratulations.
a’s r A’s n B’s is b’s
and liddle lamzy divey
Oh, yeah, I was talking about shell commands, not python functions. “ls | LANG=C sort” versus “ls | LANG=en_US.UTF-8 sort” , which will sort in asciibetical order or language-specific alphabetical order. Asciibetical is dramatically faster, when sorting large amounts of data, and I prefer it in general. So I have LANG=C most of the time except when I specifically want something else.
Not that this has anything to do with flashlights, but still. It weirds me out a little when upper and lower case get mixed together while sorting.
same alphabet
Hello,
If possbile, could I add one more for OrangePeel (1275) for a total of 2.
Thanks much!
Swapping places of a pair of cells in 2S1P configuration? Please be advised that this will make absolutely no difference at all. Both cells in a simple serial bank will at all times draw the same current and discharge the same capacity. If they don’t match, swapping their position will not help at all.
Analyzing and pairing-by-capacity every once in a while IS arguably useful, though.
For a 4S2P battery bank, methodically swapping cells between the two holders might have a theoretical advantage. Monitoring, comparing and logging their final voltage might still give better results. I would mostly ignore that because that sort of light will have a dedicated set of batteries and receive comparatively low hours. Just recharging 4 at a time in, say, Nitecore i4, would betray a failing cell in time.
