Careful plugging your charger in - Opus 3400
All power outlets in Australia have on/off switches, never seen one without.
Actually, what it sounds like is that your “extension lead” is junk. It shouldn’t be arcing like that when you plug something into it, even a transformer. Also, make sure when you plug something in to a “live” outlet, you are not dawdling about, but pushing it in firmly and decisively. As some others have said, we don’t generally have switched electrical outlets, although there are some specific cases in which an outlet might be switched. We certainly don’t have any like those in the pictures above. Some people may be surprised to learn that we don’t have switched water heaters on our shower heads either.
The extension lead most certainly isn’t junk and both of the transformers will fizz or spark a bit if plugged into a live wall outlet too.
A switched wall outlet?
I have seen this in a few houses in the US, but here in Germany and on my holiday trips of the last years in Italy, France, Denmark, Croatia never.
A power cord extension with a switch of course, but not a switch for a wall outlet.
Okay, then I was wrong. I guess those transformers really are a special kind of junk, because I’ve never seen that problem before and I’m a state licensed electrician. :wink: I have seen more than my fair share of junk power extensions, however.
I’m sure you probably have but these are decent enough. The extension is going to be replaced as a precautionary measure but they do fizz and pop when going into normal mains sockets throughout the house. Only enough to be heard usually so I don’t worry too much. They never get hot and the voltage output is quite stable. Seems they just dont like the initial surge of current when you plug them in.
Doesn’t the transformer have a European plug on it?, mine does so I have to use a uk to euro adapter, if so I’d say the adapter is the cause of your problem
My genuine Apple 85W MagSafe power bricks, which are generally regarded as well designed with high quality components (putting aside the damn strain relief on the cords), give me sparks if I’m not speedy about plugging them in. I’m not exactly happy about it, but it isn’t just a problem with cheap chinese power bricks.
Does this charger still have any problems with the
cooling fan ?
Just checked mine—Like I thought no problems here in Louisiana—My power supply is 120v input to 12v output—The ones you have are 220v—might be the problem—-Does just the cord do this without being plugged in the charger
sound like these transformers have no inrush current limiters in them, therefore, the internal buffer cap draws a massive load till it is charged up.
I’d say the charger is crap. I don’t have issues with the 120V either.
Confirm that power outlet with switch are not used here in Italy, if you find them (maybe one in a dozen million houses :P) it has been putted there on purpose by a very cautious person.
Also never seen that in Switzerland, Germany or France or Ireland either
I can confirm often enough seeing a spark when plugging something into US 110v — and I go back to the era when receptacles and plugs weren’t polarized, but it’s not only old stuff. As EAS says, Apple (and most other) computer power supplies and USB power adapters do this sometimes.
Not usually any noise or oddness internal to the device though, just a little flash at the point the plug connects with the receptacle.
Same thing happens with any straight resistance load like an incandescent lamp, if it’s switched on before plugging it in.
I wonder why not everyone sees this. Personal magnetism?
Maybe it’s just me?
No, ’oogle reassures me it’s normal enough: http://www.quora.com/Why-does-the-electrical-socket-emit-sparks-when-I-plug-something-in
No switches on power points? Heathens.
Actually, I was going to say the same thing, not so much about the extension though. I was always told that if an outlet sparks like that, there is something incorrect about the wiring/grounding. We’ve had to get a couple of the outlets in our house re-wired because of that type of thing.
I have an Opus (US plug), and carry it with me when we vacation in Europe. I use an euro adapter plug, and have never seen it throw a spark of any kind, in the US or Europe
Ireland has switched sockets also. Never seen a house without switched sockets in Ireland unless it’s the shaver receptacle in a hotel bathroom
correct.
some big pc power supplies do this too.at least cheap ones.
all this means is about $0.02 was shaved from the cost of the device.a small icl is really cheap now.even the big ones like used in ecm motors for hvac are cheap in the 100 qty i buy them in.
It’s a UK thing (also adopted by many former British overseas territories) where AC outlets almost always are equipped with individual switches.
