No, that is not it,Kawiboy figured it out.
…. I can’t believe you did either …… :person_facepalming: … … First I heard of it……
Especially after our conversation starting 13 November 2016 by the wonder of PM technology. :person_facepalming: … :cry:
I have however heard it said that time heals all wounds…… hopefully, in time; this wound of not owning this most unique DB Custom TN42 will at least scab over & begin to heal in a few years. :cry:
I’ll be off now to lick my wound……….
Missed the while off part. :person_facepalming:
Leakage current. Makes sense, similar in principle to lighted tailcaps
Humid nights: For me, not applicable. I live in central Arizona hilly high country. It is very easy to see that some lights are better throwers than others.
There’s a good reason that fog lights on a car have a low horizontal beam profile, helps cut under the wall of fog. In my day a fog light was always orange-yellow to help reduce glare for the driver.
Driving in fog teaches a driver a lot, click the high beams on and get blinded! So trying to use a thrower in a high humidity or saturated air scenario is going to yield pretty equal results. Just the nature of things.
Okay, that’s what I figured. Where I live, summer nights mean high humidity. I guess scattering would be an issue with an extreme thrower.
Hi all, I received a response from Thrunite when I told them about the impossibility of complete turning off the TN42. Despite the fact that the glow turned almost invisible after resolder one of the wires from the switch they send me the following pic to fix the problem. I want to share with all of you to have your opinion. I havent do anything yet.
https://s8.postimg.org/itfxl82d1/TN42-\_CUT_OFF_RESISTANCE.jpg
I would rather de soldier that
Yes I will wait for some advice and then try to desolder it! :person_facepalming:
Interesting…… At least they responded with a solution.
Good idea… no point in getting onto a rush.
Thanks for sharing and good luck. :+1:
Thrunite is telling customers to destroy a component on the driver using pliers to fix a standby drain issue? Did I read this right? I could swear that was just black tea I was drinking, not hard drugs.
You could solve the standby drain issue even easier by smashing the whole driver with a hammer.
:FACEPALM :person_facepalming: :person_facepalming:
I feel bad for you. It is NOT your responsibility to fix a defect. I would get very direct and tough w/ them as possible,being polite of course.
Somehow Thrunite or HKE[?] where you got it, is RESPONSIBLE for repair or replacement at their expense.
When my TN32 Emitter fried after just 5 days and I posted pictures on CPF,Guess who was the Second to respond? David,the owner of Thrunite!He was concerned about his reputation and being that I bought it from Illumn in the states where I live,there was no problem,I had a new light in 3 days!
here it is:
CPF link below that!
Ever hear of the group called "Cream"..........from the 60's,,,,,Eric Clapton? Anyway In the song, "BORN UNDER A BAD SIGN" they say, "If I didn't have bad luck I would not have any luck at all"!!! :shakehead In all honesty it has not been that bad...
Send it back!
But first I would check the traces around that 125 sense resistor in between those 2 what look to be 7135’s and see if there is any solder or splatter crossing over and touching one of them 7135’s?
Could be a bad resistor too?
I just took 2 brand new out of the box TN42’s and pulled the driver cap off each, and from what I seen with a 10X magnifying glass was a lot of splatter from when they soldered the Driver bypass spring and the Red Jumper wire!
Underneath the Brass contact button you will find a bypassed driver spring. Then just like the Photo’s show a Red 22-20awg jumper wire with a heavy solder connection on one side. Suspect that’s where the splatter came from. I usually shit can the brass button for less resistance/ driver efficiency any way!!
I have NEVER heard of a Manufacturer giving such explicit instructions in how to deal with a problem. That’s great, if you ask me! They’re LISTENING!
That’s kinda what I was thinking too.
I’m new to lights and I’ve purchased a bunch of Thrunite lights this year. I just received #6 today.
I had a small issue with an accessory part on one light and they were quick to address it. I’m impressed.
So what happens when your an amateur like me and screw it up more? Who is responsible then? I bet you I would be. They would not want it back after that!
Someone like me[no modding skills] I would NOT even touch it,like I said it is the manufacturers responsibility. Plain and simple.
I totally agree, it is the manufactures responsibility.
But FlashMax is not in the good ole’ USA.
And “if I recall correctly” he said somewhere shipping was a long drawn out process for him as well as a somewhat problematic.
IF he thinks he can handle it…. AND wants to give it a shot…… why not.
Otherwise, definitely go another route.
ymmv
