Ye i would like to know as well what 3-mode sipik will:
accept 14500
good quality
good price
i now own a 1-mode but low mode would be nice!
Currently i'm considering buying from eletrading or ntxmas
accept 14500
good quality
good price
I received three packets today, this cheapo http://www.ebay.co.uk/itm/220894394485?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 and two different three mode Sipik 68 clones, one each from topicshop and ntxmas. The cheapy is to use the tube as an extension for the 68s so as to run them on 2 X AA; there's a thread about this somewhere. But it was the three mode 'Sipiks' that I was excited about, and they're quite different to each other. Hmm..
To begin with, one of them is unbranded. I would say it's almost certainly the exact same model as Dimlux has reviewed above; it matches the pictures and description precisely, right down to the awol O ring at the bezel. I like it a lot, though you're right about the thinner tail boot Dimlux. Luckily I was able to swap the tailcap with one from a single mode; works perfectly and feels much nicer now. I'm slightly disconcerted by the absence of any logo, but so far no issues. I'll give it a proper test run as soon as I have time.
I would order several more of these right now, but there's a problem.. The other model that came today is different from the unbranded one and also from its single mode siblings, and I don't like it as much. This one is branded 'Ultrafire', like all my single mode versions bought from 365digital, (although the logo is slightly different) and the difficulty is that I don't know which torch came from which seller! I added a note specifically asking both to enclose the company name just in case something like this happened and (of course) neither seller did this. Sigh. The packets are the grey polythene type rather than yellow padded envelopes and there is nothing on either to enlighten me. One is stamped Hong Kong, the other Singapore; strange since the Paypal recipient is the same name for both, but this discrepancy doesn't help since both Ebay sites state that the item location is Hong Kong..
As to the differences, for a start, the Ultrafire version only just tailstands, but it leans at a perilous angle because the boot protrudes (I hate this). And I can't swap this one with a tailcap from a single mode 68 because the UF tube diameter is slightly wider than all the others. The switch mechanism is buried beneath a hard plastic bung, so doing the O ring tailstand mod would be difficult. The switch itself is also slightly less pleasant to use; stiffer in operation, but with the same flimsier, slightly squishy boot that came with the unbranded one. Despite this, I must add that the tail ring does screw in more smoothly than on the single mode versions.
What else? Well, the lens diameter of the three mode Ultrafire appears the same as the single modes, i.e. not quite as wide as the unbranded three mode. The bezel ring is a bit thinner on the non-brand, perhaps to accomodate this extra couple of mm of lens, which makes it feel less robustly built. With both three mode lights, unlike the single mode, the lenses are not fixed to the bezels, which makes it more likely that you'll lose a lens if you want to use mule mode. Also harder to keep fingerprints off. I may try to do some glueing here, if someone can tell me which type of glue to use. The UF has an O ring at the bezel where 'Brand X' doesn't, and, interestingly, the UF 3 mode is the only one out of all my Sipik clones that carries the Cree logo, although like the 'UltraFire' logo, it looks slightly different here; fainter, and with the diamond composed of tight, thin white lines rather than solid white.
Both 3 modes seem to work fine with comparable output on AA in high (haven't tried 14500 yet) although Brand X seems to have a slight edge. This may be because its tint is decidedly cooler; the UF looks almost golden in comparison. Also it zooms a bit tighter and sharper, which adds to an impression of greater brightness. In low mode, however, the UF is noticeably lower than the unbranded version, which isn't necessarily a bad thing. All three models (single mode and both 3 modes) have a slightly different feel to the zoom action with the unbranded being marginally nicer than the UF 3 mode, which in turn is just a bit smoother and tighter than the single mode.
Has anyone else bought from either of these two Ebay outlets? I'd sell my soul to the devil to know which of them supplied the unbranded light, although I guess there's no guarantee that both ntxmas and Topicshop don't sell both models; it could be just pot luck which they send. And to be fair, unless you hate wobbly tailstand as much as I do, the UF torch doesn't seem a bad purchase. A final word on the cheapy extension tube torch: it fits the unbranded 3 mode perfectly, but not the UF version due to the latter's wider bore tube. It's also nowhere near as badly made as I was expecting for the price, just don't expect Romisen quality or output..
Was going to order one of the three modes in the original post, but at $60 shipped I decided not too.
Where can I find the BEST quality Sipik sk68 or clone? Don't care if it has modes or not.
I ordered mine (single mode) from a US based seller campingsurvivals based on this thread (after that other US seller up'd the price to $28.69! I bought on Jan 9th (late afternoon), but haven't seen any emails saying it has shipped (and no shipping/tracking status on Ebay).
I can't speak for "quality" since I haven't received it yet. I'm hoping it's like "how crazy is this"'s experience detailed here with this silver one being a good one.
-Garry
Yeah I actually submitted a best offer of $7 for one to that same seller this morning. (I started the thread about that seller).
Will have to see if he accepts the best offer.
Oh, Duh! My bad! Guess I should pay more attention to thread authors! Will let you know if/when mine comes and what it's like (although I don't have any of these SK68 variants to compare to). I also have the Ultrafire one from Manafont coming as well, but I don't expect it for about 2 weeks.
-Garry
I already have one from TomTop, and I like it so much that I want a spare in case anything ever happens to it.
In all honesty, if I could only have ONE light, this would be it. With a 14500 its very bright, more flood than any of my other lights, and when zoomed it is only out-thrown by my Solarforce MPP-1 (which is a dedicated thrower). It is smaller than all of my lights except my ITP A3 Eos. It can tailstand, and if you remove the bezel and lens, it will do a great job of filling up a room with soft light during a power outage. The ability to run on AA batteries as well is great during an emergency situation or power outage, and it should have pretty long battery life on AA although I haven't tested that yet. It is very well built, the metal seems very thick unlike some other ultra-budget lights I have. Threads are clean on the tailcap. Feels nice while holding, I could go on and on.
I find myself using this light more than any other light.
Now you're making me wish my Tomtop order would arrive! (Well, I would wish for it to arrive anyway!) Last tracking status still says "Dec 11th Chicago Customs". I bet it's lost. Maybe I should ask ChicagoX to head there and threaten a beat down if they don't send me my package!
-Garry
Mine from TomTop doesn't have the o-ring on the bezel either, I think I will try to find a very thin one that will fit.
I guess i'll go for the eletrading one, looks safest option atm :d
@ motodeficient: "Where can I find the BEST quality Sipik sk68 or clone? Don't care if it has modes or not."
Quite a while back VFMaddict put me on to this seller: http://www.ebay.co.uk/itm/330560956221?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 I've now bought ten from him, all identical, all without issues. If it weren't for the fact that I want three modes I'd never have gone elsewhere.
I just checked topicshop again, thinking of buying another three mode 68. Brace yourselves: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130626380594 WTF? Man, what is going on with these sellers and their mad price jumps? Wow..
EDIT:
Same with eletrading http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170758584629
As I write, ntxmas seem to have remained sane for the time being:
http://www.ebay.co.uk/itm/CREE-Q5-LED-300-Lumens-Zoom-Torch-Flashlight-Lamp-Light-/160714464479?pt=UK_SportsLeisure_Camping_LightsLanternsTorches&hash=item256b541cdf
I just bought another one from them; at least this way I might find out which version they sold me last time. Bet I get another wobbly UF branded one..
And yet payments to all three of these sellers show the same payee name in Paypal. All a bit too bizarre for my liking.
Supply and demand?
Can't see much demand at these wacko prices. But their supply is likely to remain plentiful
Does that orange clicky glow in the dark?
No, it doesn't glow in the dark.
Got my TomTop SK68 within 10 days of ordered. I have had it for a couple weeks now, love it! Liked this light so much that I just bought three other ones from various sellers on eBay. Even one from a US seller.
These are the three I just bought.
Silver SK-68 clone from China, says Cree on one side, can't really make out whats on the other side.
Black SK-68 from china, ebay seller Demonerr as mentioned above, not sure if its a clone? Says Sipik on it
Black Sk-68 clone from US seller, has no branding on it (same as my TomTop one?) Paid $8.59 via "Best Offer"
I will report back as I receive these.
Most likely a typo or unrealistic expectations.
Nobody will buy that light for that price.
Don't think it's a typo; too many Ebay sellers been doing the same thing just recently. But you're right, of course, who do they imagine will buy? Begs the question WTF are they doing? Unless it's the old trick of briefly hiking prices by several hundred % so that they can legally anounce an eye-catching
90% OFF!! HURRY WHILE STOCKS LAST!!
Be interesting to see how long they hold these barmy prices..
My first post has been updated with information and a couple of pics of the 3-mode Ultrafire branded Sipik SK68 clone. The first 3-mode light I ordered from eletrading had no text on the side while the second one I got was the Ultrafire version. The information & pics can be found after Update2. There is also more information about this 3-mode Ultrafire version in this post by Lensman.
SO 2 of of the 3 lights shown above you bought from eletrading, you randomly got a unbranded and a ultrafire one and the unbranded version from them and the unbranded has more focused beam and wider lens, but is a bit less bright?
