So, any technical details?
What is the driver size, type and current?
In one line it says ‘High efficiency constant current circuit’, in the other it says A17DD.
Sorry, it seems this release was a complete surprise. AFAIK no one seems to have any more confirmed info at the moment.
Judging from the description it uses standard FET + 1xAMC driver with ToyKeeper firmware like BLF A6 and Astrolux S41 but that’s just an educated guess.
Voltage indication using LED under the button could be realized on separate PCB along with USB charging functionality. That’s probably why there’s duplicated voltage level indication using main LED - they did not modify A6 driver at all, just added charger board with side button and LED indicator under button. They already have experience with this driver and probably enough spare units so using that is cheaper and means faster time to market. This would mean the setup is highly modable as the main mode-driver could be simply substituted. But we will not know for sure until somebody will take it apart and do a proper review. Probably that’s also the reason it’s so competitively priced in preorder along with the ability to use BG points to get it even cheaper for loyal customers.
There must be some other item in your cart with unbeatable price - it doesn’t have any special designation beside usual orange Promo tag.
Purchase this item in separate order. You can use check marks on the left side of the item to disable it from current order to see which one is causing the problem.
If that’s not the case or you only have one item in your cart try refreshing your cart and/or clearing browser cache and cookies.
XANES 300LM Sensing Headlight Night Fishing Cycling Double Light Source Rechargeable Clip Cap Lamp is in preorder for $5.99. ~150 pcs left at that price. Main LED with reflector seems to be Cree XP-E, there’s also COB LED for diffused light. Package includes headband (not pictured) and apparently 2 USB cables.
IR sensor probably works similar to Boruit IR “sensor” headlamp - i.e. just for switching selected LED on and off. Description does not clarify that aspect.
Battery has standard 2 pin connector (same as used in small drones) and is easily replaceable.
BlitzWolf® BW-LT5 Pro IP68 Waterproof LED Panasonic 3350mAh Powerbank Emergency Camping Lantern with coupon travel is 20% off at $15.19.
Lamp uses single 18650 Panasonic NCR18650B 3400mAh (typical, 3350mAh minimum) cell but it’s not replaceable, it’s USB rechargeable and has ability to charge other devices via standard USB type A female port. It is completely waterproof, white light has two steady modes with up to 75h runtime in low mode + 3 modes red light (2 emergency blinkers + steady red), uses separate blue LED as charge indicator.
Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 use coupon 76648A or 2017FNL to drop price from $29.95 to $20.96.
This is exactly the same flashlight as BLF A6 but with different name and additional matching 18350 tube already included in the box.
Haikelite is under restocking right now so we have to wait until new stock arrives. When the light is avaiable again you can use BG points to drop price according to your account VIP level as shown in the table. You still need enough BG points to do so.
