Review : Foursevens Mini MK II (Combo) | A bright EDC flashlight
6 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 5 hours 24 min ago
Due to a photobucket’s policy change , pictures can not be shared freely anymore …
To be able to view all the pictures of this review please install this Chrome Extension :
https://chrome.google.com/webstore/detail/photobucket-hotlink-fix/kegnjb...
A few words for Foursevens Mini Mk II :
Developed from the ground up with enhanced Mil-Spec electronics and advanced optics, the Mini Mark II raises the bar of everyday carry lights with a never before achieved 1020 lumens from our custom designed Lithium Ion battery, or 550 lumens from any standard CR123A battery. The Mark II also has a true, current-regulated sub-one lumen moonlight mode.
Overview/Specifications :
First Look :
Flashlight in it’s box , a clear box , really nice and classy :
!{width:80%}Specs on the back side :
http://i794.photobucket.com/albums/yy230/george_kok97/foursevens_mini/20...!
Inside the package :
Package Contains :
  • Flashlight
  • Charger
  • Battery
  • 2 way Pocket clip and detachable keyring
  • Manual (Photos : 1 & 2 )
  • Small catalogue
A closer look :
You can see the flashlight it self :
It’s size is really small ! Flashlight is 5.51cm long and 2.03cm wide :
Here are some pics with flashlight in hand :
Anodization is HA III and seems durable .
The tail , with a nice Foursevens logo . As you can probably see , there isn’t any visible switch . It is a “twisty” .
Knurling is not really aggressive , but it is grippy too :
The 2-way clip has a very clever design . It can be used in both sides without repositioning it :
And here is the “keyring clip” that allows you to attach your light on a keyring :
Led is a XM-L2 , and flashlight uses an optic :
Inside the flashlight :
Driver has a small brass button for the positive battery terminal. It also accepts only button top batteries :
Threads are trapezoidal , or “square” as we call them . They came well lubed :
It has a gold plated spring on the bottom of the tube :
And it’s long as you see :
Charger :
Charger is an automatic charger for Li-ions (4.2V) and Nimh’s (1.45V) , at 0.75A:
It has magnetic ends that connect to the battery , and they don’t have polarity :
It draws about 0.69A from the USB charger , so it must be providing at least 0.75A at the battery :
When :
  • battery is charging , led indicator is red .
  • battery is full , led indicator is green .
Battery :
The battery is a RCR123A (16340) , 550mAh one (protected) , i will ask which brand/model it is :
And here is the battery next to the light :
How it works (&modes) :
While flashlight is off , if you twist the head (clockwise) to tighten , flashlight will turn on . By twisting counterclockwise it will turn off .
Flashlight has 6 available mode groups , with memory on them :
To switch between mode groups , just turn on/off the light many times (over 10) in 3 seconds . When you are in programming mode , by turning off and back on the flashlight quickly you get into the next mode group . If you turn it off for more than 1-2s it stays in this mode group .
Measurements :
Foursevens 550mAh battery was used in all measurements
Lumens :
  • Moonlight – 0.5 lumen !
  • Low – 18.5 lumens
  • Medium – 230 lumens
  • High – 985 lumens
My runtime tests :
Turbo mode :
At the end of the runtime , batterry was at 3.20 Volt .
Intensity :
Mini MK II : 5.6kcd
Beamshots :
Wall @ 12m , Iso 100 & S speed 1/4
Turbo :
I will add some beamshots in the other modes too , later today
Conclusion :
A little but powerful light , and really interesting ! Build quality is very very good , and overall it has a clever design . Output isn’t stable for long time , but you can’t expect something more from a light from it’s size . Beam profile is great too , nice flood beam , optic creates almost no artifacts . For me , seems as a very good deal for an EDC light of it’s size .
Comment if you want me to check something on the flashlight , or tell your opinion . Thanks !
Flashlight was kindly provided for review by Foursevens . Be sure to check their flashlight here : Foursevens Mini Mk II :
Edited by: giorgoskok on 09/26/2017 - 08:52
giorgoskok
Reserved . Thanks
djozz
djozz's picture
Last seen: 36 min 21 sec ago
Thanks for the nice review!
It is a long time ago that a foursevens light was discussed on BLF, and this is one of their classic designs that they even made a bit smaller thanks to the use of the TIR reflector. And brighter of course, squeezing 1000lm out of a 16340 is always good to see Smile
giorgoskok
Thanks Jos !
Waiting for an IMR 16340 to test the output , i have hopes for a better output Smile
CRX
CRX's picture
Last seen: 8 sec ago
I love the form of the Mini ML, nice to see they’ve put some muscle in it.
Tixx
Last seen: 1 hour 23 min ago
Now 20% off with coupon code TURBO at 4Sevens website
