Hello all
I purchased a light from a member on here a couple of years ago. It was one of Old Lumens builds. It has stopped working and I am not very good at modding or tearing down and putting back together. Is there anyone that might be able to help me out. trying to see if anyone is interested first and then we can talk how much to do it. I have a link below to the light in question.
Thanks!
This needs to be fixed mutts. I dont think there would be much wrong with it. Hopefully someone in your area will see this and put there hand up.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
I am not opposed to sending it to someone that is a mainstay here either…
does it have a # on it 1-5 Vinh had Old Lumen make 5 host for him—could be one of those
This light was a one-off, I remember when Justin built it.
I could probably do it for you, heck I’ve got all Justin’s gear right here anyway.
Dale
Bugger, that’s a nice looking light!
Def have it repaired…
I knew I hadn’t lost all my memory yet
http://www.candlepowerforums.com/vb/showthread.php?401566-The-JJRV-Throw...
With custom builds like this it can often be a contact issue given all the mods done to the various parts. If you’re hoping to keeping it local then flag the title “for NY please”. Shipping will be medium flat rate at best.
Scott
Anyone closer to NEW YORK STATE that would be interested in trying to fix this?
Heck, why not stuff it in a flat rate priority box and send it off to texas, priority flat rate does not care where you send it. unless you want to see it worked on…
That will most likely be what I do… I was thinking it would be quicker if someone closer was able to do it
If it has a number 1-5 on it —that means Vinh built it—he would most likely fix it for nothing and send it back free
No number… but it might have faded off over the past 2 years…
My guess is that it is not Vinhs work. If he engraved it like he does all his other lights it would never fade!
Solitude breeds contemplation which creates clarity. 7.3.2017
Environment molds a person. Perseverance changes them. 3.4.2001
WOLFDOG
Definitely not engraved….
I’m in NY but this might be out of my league.
If I were you, I’d take Dale up on his offer. Turning down Dale’s offer to fix a light would be like turning down $1,000,000…just doesn’t happen, lol
x2
really USPS flat rate NY to TX should only take 3 days after ship date.
He will do the job right and it is senseless to worry about 2 or 3 day travel each way! Now if you were sending it to China that is a different story! lol!
I get stuff from Calif. and Washington state in 3 days,,sometimes 2 days and that is first class mail! I live in Suburban Philly.
WOLFDOG
+4 …… What they all said.
You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
Texas Lumens Flashlights <> M4D M4X Deals : sign up - save $$$$ |||| Confucius say -- Baaa-haaaaaa......
Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU Flashaholic? Need Professional Help???
/\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
+5 , Dale knew Old Lumens well and I am sure he picked up at least a few hints over the years from Justin to boot.
Dale also has most of the parts and modding stuff Old Lumens had in the end , so more than likely has parts to match the original ones in this light.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 /// ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 / MCC-4S , neutron 2C V3 , TC20 /// ### Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini , M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II / Small Sun ZY-T43 / Warsun X60 //////// ### Thorfire /// PF03 , PF04 , Upgraded PF04 , C8 , S-50 , VG-10 , VG25 , C8s , BL30 , TK4A , S1 , VG15 S , TK 18 //// Atactical (Wowtac) // A1S , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
I sent him a PM to see if he is still interested. Thanks for all your help ! Looking forward to get this light working again…
Paul
Responded to the email.
If you can give me some idea of what was going on with it when it quit working, any problems you were having with it at the time or anything like that, it might help find the issue more quickly. I’ll need the entire light, to rule out a broken solder joint in the battery carrier or anything like that. I know how Justin went about building it, probably something relatively simple wrong with it now, will just have to go in and see.
Dale
Not really Sure… I have a cottage that I take that light as well one that 18sixfifty made as my 2 go to lights. It was working last summer while I was there. I hadn’t used it in a while and over the Winter I went to use it at home and it wouldn’t work. I did have an issue with the power button. Every once in a while I had to press it a couple times for it to come on but it wasn’t a normal thing…
That’s right teacher, it could well be that it has issues with Authority.
Dale
mutts, your light came this morning on the brown truck.
And, your light is now fixed. I need to address a couple of things again later this afternoon but it’s working…
23.6 lumens
58.58
135.59
377.78
979.8
2163.15
4802.4
Edit: On freshly charged LG HE-4 button tops I show 5064.6 lumens
Dale
Wait a minute! What was wrong with it? What did you fix?
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
I fixed what was wrong with it. lol
I figured that in a build like this the most likely candidate for something going wrong was in some of the soldering that had to take place. Justin changed the battery carrier and how the cells interact with the driver contact board, and it was here that the problem was… one of the copper discs that Justin had soldered to the outer ground ring had broken loose. And one of the brass locator pins for the tail pcb where you remove cells had also come out.
Seems that Justin only soldered the copper disc at the very edge, didn’t glue it to the board. So I repaired it by gluing it down with JB Weld and re-soldering the ground contact. Also added solder bumps to the discs so they’d contact the negative end of the cell solidly.
Put the locator back in and soldered the two of em to be sure they were staying, and it works fine. I have 4 cells in it with the tail cap snugged down in order to press the copper disc in place and am allowing the JB Weld to finish curing. This evening I’ll make sure the solder is good at the ground ring and re-enforce it as needed.
Dale
Nice work Dale and its good to see the mateship at work here.
Not sure if this was wanted, but I, uh, bumped it.
The converted tail pcb with it’s solder wick bypassed springs seemed to not be pressed into the ground contacts inside the body by the tail cap, so I was looking at what would be a good way to ensure this would happen when the tail cap was screwed down, and also could it be done to improve current. Justin cut the traces on the top of the pcb and made it 2S2P in configuration, tying the two cells together with 20ga Teflon wire. So, I looked through the kit I bought from Justin and found some 14 Ga wire. Cut a couple of these and soldered them in beside the Teflon wires to do 2 things, both carry more current and also be thick enough with the silicone sheath’s to assist the tail cap in pressing down firmly enough to assure ground.
This worked to the extent of bumping output from 5064.6 lumens to 6285.9 lumens, this on freshly charged LG HE-4 button tops.
I’m going to highly recommend gluing the body to the head to keep from doing damage to the driver board and it’s 2 copper discs. I have it screwed together quite snugly, but it’d be best to glue it.
Dale
