Review: Manker E02 (AAA, L shaped, XP-G3 200+ Lumens)
Neat design and very high output for a AAA light. Some thoughts for the manufacturer, as I see they’re in the thread:
  • There should be a headband, preferably a simple band without a top strap. The main reason I like right-angle lights is that they can be a headlamp or a handheld.
  • Instead of an “engineering mode” to set the moonlight level, just make it a four-mode light with say, 0.2, 10, 60 and 200 lumens.
  • It has a timed stepdown. I don’t like timed stepdowns.
  • The usual Manker e-switch UI that lumps the max mode in with the blinkies is kind of weird.
  • I see there is a Nichia 219C version (presumably 90 CRI, 4000K like everybody is using lately). Thank you for that. I’ll almost always give up some lumens for better color quality.
I vote for engineering mode, I have 21 options for choose my preferred low or moonlight…is great 21 steps for the moonlight, if you like the ultralowest you have less than 0,1, or you can choose, 0,2-0,3…… to a maximun step around 4 lumens.
4 modes is good, but why not the option of engeneering mode? is not obligatory use it…… :wink:
Trevi, 10440?
Thanks for the review Budda! In the UI instructions, it mentions “dragon breath mode”. What is that?
E02 can run of 10440 batteries in emergency situation if you don't have AAA batteries.
There is only one output mode when use 10440.
Thank you for answer. I have e11, u11, u21. I like them very much!
Wow,19.99 with the manker quailty?
It sounds nice.
The upper body design reminds me Xtar Warboy H3
You mean X5?
A headlight without a headband, really?
Mode spacing definitely looks odd and a 90CRI option would be nice too.
X5 may be the one. Manker donated entire sale of like 50 units.
Yes,we did that. Thanks to the members who bought these X5.
Will you have AA version of E02 soon?
why you know our plan?
So, that’s a yes? That’d be my preferred format for this.
+1 I agree AA / 14500(protected) NW /WW :+1:
Yup. This light begs to be a 1xAA neutral white light that comes with a simple headband. (I presume targeting the Zebralight market, like the T01 does, from the looks of it.) Still, it is very impressive output for a 1xAAA light, but unfortunately AAA batteries just don’t hold enough juice to give them useful runtimes for outdoors.
Thanks for the review, Buddha.
+1 for a AA version and headband.
Wow, that’s great !
yes, it's on our plan, I think you will like it.
Great, hopefully it will take protected 14500 and have lower working voltage. My E11 doesn’t power on if it goes below 1.2v using Eneloops
