For the full voltage simply connect to the V+ from the main LED and then to ground via a resistor. Lots of grounds you can use from the input to the FET or the ground ring, OTC ground, C1 ground ect.
Built hundreds of FET drivers, pretty much know the drill there. Just not used to using these tiny SMD LED’s. Nor am I used to doing the mods so heavily drugged. :confounded: Probably shouldn’t, have burned myself a few times lately. Left hand and arm are totally out of whack.
Jason, the package those LED’s came in identifies them as SMD SMT 080. Hope that helps. I got 8 colors, 20 in each tape, for like $8 and some change on ebay.
That would only light the side switch when the main beam is on (and not needed then), but not when the light is in standby mode.
My whole reason for wanting the lighted side switch is so I would know whether the rear tail switch is on or off. It also helps to locate the switch in the dark instead of having to feel for it.
By connecting the side switch LED to the main led V+ and then to the ground ring via a resistor (most likely between 25-50k), the LED will be on anytime power is applied to the driver. The V+ is connected directly to the battery and so in the ground ring.
In all the FET based drivers we use the positive is always connected, we only control the ground. Since you are bypassing the 7135/FET by going directly to the ground ring (with any of the connection points I listed above) the LED always gets power when power is applied to the driver.
You would need a firmware and driver that supports an indicator LED in order to control the LED past that.
I could have done this instead of searching and probing for a positive battery source? I didn’t bother to check this because I assumed it only had power when the main beam was turned on.
Well what I said above applies to the BLF FET drivers in reply to DB. Some buck and boost drivers do switch the positive side, so you need to see if yours is one of those. If so then you can usually tie into the LED ground and then into a voltage source.
The easiest way to find the V+ voltage source is generally to look for the vias from the spring and see where they come up and follow them to the first easy to tap into location.
Okay, so it’s best to take it case by case. Don’t assume. Just apply power to the driver and probe around to make sure you find a good voltage source.
My next driver is going to be one of yours and it has a spot to add a “power on” led. Now since the led has to use the same negative wire as the momentary switch, can you tell me which pad is positive and negative?
I labeled them A and B.
Hmmm, maybe it’s not important. I can try the red switch wire to A and the blue switch wire to B. If the LED doesn’t light, I can switch them around.
Nope, that could damage the driver. Pad A is for the red switch wire and pad B is the ground so that gets the blue switch wire.
I’m not using the “indicator” led. I’m not sure what it’s supposed to be used for actually, but I just need a simple light to tell me if the rear switch is on or off. Nothing fancy. Positive power to the switch LED is shown on the picture above (lighted side switch). I’ll use a smd resistor to drop the power down.
The negative side of the switch LED shares the same wire as the momentary switch. So polarity of the momentary switch is a factor.
You can connect the negative wire to any of the locations I listed above, they all go to the same place, the ground ring. Indeed the e-switch ground is perfectly fine.
The positive is the only thing you need to worry about, in the case of the TA driver the easiest V+ is the bleeder resistor, the pad closest to the LED V+ wire.
Well, I tried it and failed… again. I tried to use a 22K resistor but that’s not going to work, not without some form of support, as the end cap simply pulls off the resistor. In trying this, I somehow messed up my FET driver. Ended up removing the SIR800DP FET and replacing it with an SIR404DP. I have it working again, without the lighted switch but with a clear boot cover and led’s on board. Still have to figure out how to power em up.
I now am getting 12.03A at the tail with the Uni-T clamp meter and 7077.5 lumens with these LiitoKala 5000mAh cells.
These pain meds are totally screwing me up! Even the MCU ended up coming off the driver! Heating up the board with my hot air to remove the FET I somehow got the MCU loose and ended up with it literally falling off when I was trying to test everything. One thing after another when you’re mentally least ready to deal with it all, but of course.
Try using the bleeder pads for the LED. Do you have a lighted tailcap? If so then yes, that will screw with things. In fact that could get interesting to figure out.
Nope, just a little 17mm MTN driver board. I have a bunch of those and a bunch of Wight’s A17DD S08 boards. Richard had OshPark mess up on an order of boards where they covered the spring pad with mask. They worked it out but he had way too many of these to deal with so I bought em from him, I usually build one at a time compared to his hundreds so it works out for me. I don’t need the extra 7135 chip on a ramping e-switch driver anyway. I also don’t use lighted tail caps as they’re just a battery drain for me. I like draining the battery in other ways.
What do you mean by “the end cap pulls off the resistor”?
Are you using a momentary switch like the one that comes on the FX30 driver that has the extra LED pads built in?
If so, then the polarity of the switch wires becomes a factor due to the traces on the pcb.
Normally it doesn’t matter which switch wire (red or blue) goes to ground and which goes to the “switch signal” part of the driver because it’s a simple contact switch. When you add LEDs, the polarity of the switch wires suddenly become important because the LEDs are polarity sensitive and share a ground wire with the switch.
Since the blue switch wire is a common ground (for 3 things, the switch, the left LED and the right LED) you want to make sure it’s going to a ground source. If it’s not, you need to swap the switches red and blue wires around where they make contact on the driver.
If you switch wires were backward then that might have been what caused your problem. You might have fed 3 or so volts into the switch positive trigger when its designed to only sense ground.
Polarity of the LEDs is also important. They need to be like this.
Now if your using a different momentary switch you’ll need to map out its traces on the pcb. I just used the continuity circuit on my multimeter.
Here is the switch from the FX30 again. All the blue dots go to the blue wire. Red dots to red wire.
Received shipment of my Shockli 26650 5500mah batteries today. Came with a nice case, carabiner clip, & magnets. They don’t easily make in series contact, without pretty good spring pressure, 65mm long x 26.7mm. Not enough spring reach / pressure without using magnets, at the moment, although I was able to take tail amp readings without.
Got at least an extra +1.0 tail amp measurement (9.71 @ 4.20 volts) with my cheap setup using 6” x 10ga leads over the Keeppowers. They do make the L6 with TA Driver get warm, real quick. Hard for me to get good representative distant pics, differences are more obvious in person. I can fairly easily tell the difference at a 600 feet (200m) treeline. This night shot is 150 feet (46m) to center brush/wood pile & 250 feet (76m) to background trees (just left of the wood pike in bottom pic).
