tip: thin the base of the reflector as much as possible and do the same for the led centering piece.
Hmm , i was thinking not modding the reflector and have a centering ring as thin as it can be .
I’ll have to test it …
Maybe mod the MCPCB?
Cut grooves on the under side of the MCPCB (with diamond coated disc for example), bend the contacts down, file the bottom flat?
Sanded the centering ring , now it is paper thin . Used the stock LED , dedomed .
With a VTC5A running at 4.75A , i got 203kcd and 1420 lumens .
I think i can gain some more mA with a lower resistance fet and some shorter wires , i might give it a try . Also , i don’t like the glass , on the next one i will be using an AR coated .
With the 26mm mcpcb , there is no issue with led wires…
Everything is possible and I wanted to try similar but I change my mind. I don’t want to fiddle and destoroy everything because of 5$ 26mm mcbcb.
Btw even with 16mm mcpcb soldered very flat(as flat as possible to ± contacts) will bring 260kcd with old type xp-g2
Giorgoskok,
Nice results indeed. That will be easy 300+ kcd with old dd xpg2.
My 26mcpcb’s are on its way.
Edit: About glass… Good and proper glass cleaning can help a lot, and imho with ar glass there will not be any gain(at least ime with old jacob A60 modding… Beautiful? It is but is it worth? Not to me.)
I don’t know if i try it , i really like the extra lumens of the xm-l2 in this particular light .
Love the mod George. I’ve been looking at the pill from one of these with a million ideas going through my head how to fit the wires through the pill. You have hit the nail on the head. Thanks for posting up. I know what I’m doing tonight.
Thanks mrsdnf I think results can be improved too , i hope so .
The copper plate under the mcpcb has exactly the shape of a led mcpcb , it has 2 cut-outs for wires to pass on the sides , and cut the sides of the pill with the dremel . If you need any help , just ask , maybe i can explain it better .
I’ll be sure to holler if I need help. Thanks for the offer. :+1:
You should try it out with a dded W2 emitter: i did the mod today and i got nearly 2k lumens at 6.2 amps and 256k cds: with the casual glass, those numbers are very close to my heavy modded XPLV6 Olight M2X( the light i like most from all my throwers)
This time i used a t20 blass pill and the emitter`s mcpcb is soldered to it
The pill is defilately different from the first one that i got and they “nerfed” it, i hope they wont continue with those nerfs in future, there are so many of those ” low dollar yet good ” throwers
How did the t20 pill fit in there ?
Btw , awesome results…
Just a short update on my purchase:
ordered on 4.24.2017
arrived to country several days ago and then things went south, 2 days later package was delivered to someone that lives 400 kilometers away…
So cheating chinese give me fake tracking number and probably never shipped the light, even after warning him about it he insisted that the package is at my local post office…
Another dispute on the way…
Yes Mitko… Where did you get those T20 brass pills? Fasstech T20 brass pill does not fit. Pretty please.
Also:
Where does one get W2 emitters?
I got several leftovers from Uniquefire/t20 hosts that i usualy craft as IR
As far as i know Cutter has them, for Europe - Arrow EU and Farnell
We are talking XPL W2's? Not XPL2 W2's?
On Cutter, I can only find them on a triple board (http://www.cutter.com.au/proddetail.php?prod=cut2752), then in the description it says they are V4's, so who knows what you really get.
On Arrow.com (US?), definitely no W2 bins of XPL's
I'd really like to see a link - dunno how to get to Arrow EU. Not familiar with Farnell at all...
Mitko ---- please, please try to give us a little more than bread crumbs. Please?
The vagueness and lack of availability of LEDs we all want to have is quite annoying…
Same with drivers by the way…
But i also received this light today.
Didn’t even test it, took it apart immediately.
I’m gonna use the stock pill, but i’ll have to do stuff to it on the “McGyver lathe” so it can take 20mm MCPCB.
I’ll be using a KD DTP board and i will tweak it so it won’t short circuit on the reflector.
I don’t want to spend $5 on a big DTP board for a $13 light.
I’ll put in a XP-L HI V3 and a Nanjg 105 2.8 Ampere driver, maybe add 3 or 4 extra 7135s.
I assume the stock driver is crap and has visible PWM.
Mine is a linear driver, no coil.
The nice thing about the KD DTP boards is that the thermal slug protrudes further than the + and - traces, so the reflector can sit on the thermal slug of the board.
Stock, this light has several problems with things that don’t fit too well.
Obviously the known problems in the head, but also the switch assembly is too tall.
When you screw the tail cap on, the battery tube hits the retaining ring and turns it either fast or loose.
For the rest, i’m happy with this purchase.
I was looking at the bezel and threads. How and where the o-ring sits to the threads. If you have a lathe, you might consider cutting the body (bezel threads) the depth/width of the o-ring, make a spacer for where the original o-ring is now, so the O.D. is the same as the bezel/head. Then extend the thickness where the o-ring was, forward into the threads. Doing so will move everything forward from the reflector to the lens. That, in turn will give more clearance for the MCPCB (thicker) without the reflector making contact with the LED on the board and shorting out. That, will allow ample space to play with heatsink thickness and focusing if necessary.
Hopefully I make sense. That was a mouthful (and 4 proof-reads..LOL!) for me to explain.
Now, use any board you desire.
I think what I mention is the best solution, and I've never modded a light in my life.
