Thanks mrsdnf I think results can be improved too , i hope so .
The copper plate under the mcpcb has exactly the shape of a led mcpcb , it has 2 cut-outs for wires to pass on the sides , and cut the sides of the pill with the dremel . If you need any help , just ask , maybe i can explain it better .
You should try it out with a dded W2 emitter: i did the mod today and i got nearly 2k lumens at 6.2 amps and 256k cds: with the casual glass, those numbers are very close to my heavy modded XPLV6 Olight M2X( the light i like most from all my throwers)
This time i used a t20 blass pill and the emitter`s mcpcb is soldered to it
The pill is defilately different from the first one that i got and they “nerfed” it, i hope they wont continue with those nerfs in future, there are so many of those ” low dollar yet good ” throwers
Just a short update on my purchase:
ordered on 4.24.2017
arrived to country several days ago and then things went south, 2 days later package was delivered to someone that lives 400 kilometers away…
So cheating chinese give me fake tracking number and probably never shipped the light, even after warning him about it he insisted that the package is at my local post office…
Another dispute on the way…
The vagueness and lack of availability of LEDs we all want to have is quite annoying…
Same with drivers by the way…
But i also received this light today.
Didn’t even test it, took it apart immediately.
I’m gonna use the stock pill, but i’ll have to do stuff to it on the “McGyver lathe” so it can take 20mm MCPCB.
I’ll be using a KD DTP board and i will tweak it so it won’t short circuit on the reflector.
I don’t want to spend $5 on a big DTP board for a $13 light.
I’ll put in a XP-L HI V3 and a Nanjg 105 2.8 Ampere driver, maybe add 3 or 4 extra 7135s.
I assume the stock driver is crap and has visible PWM.
Mine is a linear driver, no coil.
The nice thing about the KD DTP boards is that the thermal slug protrudes further than the + and - traces, so the reflector can sit on the thermal slug of the board.
Stock, this light has several problems with things that don’t fit too well.
Obviously the known problems in the head, but also the switch assembly is too tall.
When you screw the tail cap on, the battery tube hits the retaining ring and turns it either fast or loose.
I was looking at the bezel and threads. How and where the o-ring sits to the threads. If you have a lathe, you might consider cutting the body (bezel threads) the depth/width of the o-ring, make a spacer for where the original o-ring is now, so the O.D. is the same as the bezel/head. Then extend the thickness where the o-ring was, forward into the threads. Doing so will move everything forward from the reflector to the lens. That, in turn will give more clearance for the MCPCB (thicker) without the reflector making contact with the LED on the board and shorting out. That, will allow ample space to play with heatsink thickness and focusing if necessary.
Hopefully I make sense. That was a mouthful (and 4 proof-reads..LOL!) for me to explain.
Now, use any board you desire.
I think what I mention is the best solution, and I've never modded a light in my life.
Pretty sure you’re missing something ARsee. The perspective of reflector to mcpcb is the critical point, not how the reflector fits the pill or head assembly. Moving everything forward wouldn’t solve the focus problem, which is a wide flat base on the reflector that touches the pads on a narrow mcpcb. With a lathe, the reflector can be tapered to allow room for these pads… just as easily the emitter shelf can be widened for a larger diameter mcpcb that clears the reflector, and it’s this part that is so much easier to do.
The way I see it, my method eliminates the fuss of not having space at the heatsink now. Which from reading the replies regarding the light, is the main problem. My way opens space at both ends and gives more possibilities to a solution
Mitko. You are cool guy and I am very grateful to you for finding this great single cell throw monster throw reflector.
My pill that I put out from T20 host does not fit into Soup cause it has 1mm shorter threads. Sure I could put it and glue it somehow but that is a mess.
So curious case of Benjamin Button? I mean your T20 pill fits while mine not
Anyway pill is weak point but nothing that can’t be handled so I will not mention this again…
Mitko… You are legend and this light host by fit and finish is far better than some brand lights. Also I dare to say that you found Jacob A60 killer… Beautiful old school(imho), nice to hold and touch, small&light pocket rocket reflector.
Yeah, you’re right.
The pill is too tall to fit between the battery tube and the reflector.
You can gain the necessary space by taking 1.5 mm off the front end of the battery tube and 0.5 mm from the bottom of the pill.
Sorry Mitko - don't mean to sound upset at all. I know you're bizy and probably doin all this on a cell phone. But I'm very interested in get'n/finding some W2's. Whatever info you can provide, appreciate it!! Thanx!!
Phew…
I dremeled, drilled, lathe-ed (without a lathe…), sanded and filed the hell out of the pill, DTP board, battery tube, switch spacer and retaining rings and i think it’s ready for assembly now.
