ENDED
Nope, then you’ll get the folks whining about how this is a poorly engineered product because it can’t even stay on high for more than 10 minutes or so. So we get modes called turbo, turbo 1, turbo 2, etc. High can run for 2.5 hours, doesn’t that look great on paper? Ha! I don’t want the highest mode to be able to stay on indefinitely. I want it to push to the point just before damage to the flashlight occurs, and if that causes 3rd degree burns or starts a fusion reaction, that’s okay with me.
I’m going to have to look into that engineering mode. 10 lumen moonlight is ridiculous, but I could see times where I’d swap a true moonlight for a specific low.
/\ Sure but how long will it last on turbo without dropping down in power dramatically.
The body is small. There doesn’t appear to be much mass in there for getting rid of the heat from the emitters.
The nearest thing I’ve got to that is the TN36 and that gets too hot to hand hold after ~15mins
Interested depending on price.
Interested depending on price and dimensions and available tint.
My concern with this light is the size of the light and the amount of heat it’s going to put out. I’ve just sat down with my TN36 (fresh cells), a temperature probe and a lux meter.
The light was on for 15mins and went from room temperature (probe reads a little high here) and topped out at 68c.
At this point the light was too hot to hold and the output had dropped a fair bit. I’ve got no way of accurately measuring at the moment but the lux meter shows you an idea of how many “units” it dropped by rather than just seeing it get a bit darker.
So this is a 6000 lumen light that looses power quite dramatically in under 15mins and at the same time gets far too hot to hold.
How this 10k lumen monster will cope is beyond me!
Not only the heat of the emitters but when I took the cells out just now they were all really hot. 15mins use and down to 3.96v too so quite an impact.
I’ll post a 4x sped up youtube video in just a bit so you can see 15mins compressed a fair bit :smiley:
I’m interested.
Pricing depending.
Also interested depending on price
Interested
interested
Put me on the list.
It’s going to be good competition with the Q8. They each have their pros and cons.
My olight x7 has reasonable spacing 3-5-9000 lumen, why cant other brand make UI like that
I don’t think there is a very big difference to the eye when the spacing is that close. It’s also possible Utorch did not want too many modes. More than 4 or 5 levels might be too difficult to design into the driver or they might think it’s too many for the average customer.
I just hope they don’t make it too hard to get to max output. A double click for Turbo 1 and another double click for turbo 2 with no memory at these levels is not acceptable.
Intrested!
Missing a mode! 1k lm then jump to 10k, why?
Needs something like a 2500 or 3000 in there.
To add…interested if that mode spacing is made more useful and not all or nothing.
