I know the Boss1 is different but maybe it fits to place this driver above the original empted driver, with modding to make it 4S and a XHP35HI would make a nice light.
As a test platform for those up for it.
But maybe after the first test on the bench are done somebody can adapt the GT driver so that it fits in a TN42. A DEL Ton E designed Narsil driven TN42 sounds pretty sweet.
I am not sure what components were selected but the buck IC itself can drive any combo of input and output voltage as long as the output is less then the input. Just a matter of what components are installed on the driver.
I had wanted to do a buck driver when this project started but no one was offering to help with the EE of it at the time. So the only option was the Texas buck which was not an option due to cost.
As TA said, the driver should work in any arrangement where the battery voltage is sufficiently higher than the emitter(s) voltage. That said, efficiency suffers when going to the extreme, like 4S battery to 3 V emitter. This is just a fact of life for (non-synchronous) buck convertors.
3S to 6 V emitter(s) will be a pretty nice setup.
2S to 3 V should be fine.
2S to 6 V will probably not stay in regulation for very long.
With the current components, the driver will not work in a 1S setup. It could be made to work with a few component changes, but it will drop out of regulation too fast.
This light is huge. For me maybe it will be a shelf queen, and pretty expensive for me. My most expensive light was the Convoy L6. I almost asked to remove me from list but it is so unique that I can not miss this so I’m staying on the list and wait
Heheh you never know
Having 1 S70 I thought no more power was needed
Now a S70s at front door (when night falls I turn it on standby so the lighted switch shines reassuring)
A L6 at back door ground level
A TN42 at back door first floor
A S70 near back door first floor
I tend to use the most powerful
So well just know it will be the GT and Q8 at back door first floor and then the TN42 will be placed at front door besides the S70s.
Yesterday viewed google maps and measured distances in my area about what far things going to fit the GT range from higher places. And I was simply amazed by that. My best thrower was the L2 dedomed with 1048m throw. I thought that was far. :person_facepalming:
I guess the largest issue is that this driver will only really work for the GT as it doesn’t have the cell setup to allow it to be modded to 2s or 4s input from a SRK. At least the road has been paved and a SRK / Q8 version should not be that hard to make.
I would love to see this driver in a Q8 with an 841 or 1617 MCU and firmware upgrades to match and the LED’s run ins series.
Its a boost driver but a buck uses the same components in a different layout, programming would be kind of similar. Wikipedia does a pretty good job of covering the different types of converters if someone is not familiar with them.
Components need optimizing and you could use a hall effect current sensor for output feedback(Change in current=change in voltage signal, both are electrically isolated). It would keep more noise away from the controller and the schottky diode could be replaced with a FET for more current control and less power loss. Make it Narsil based and the output modes feed the converter with a feedback loop instead of the PWM outputs. You could do more than one channel with all those pins. If you stagger the FET firing sequence it would cut down on ripple and allow a smaller output capacitor. The inductors could be different sizes, shut the big one off for low modes. The PWM would still be high on the small inductor so flickering would be less noticeable on moon.
How hard would it be to program something like this? Could a determined newb do it?
There are MCUs with built-in SMPS functionality, but not the typical ones we use.
One problem is the relatively low PWM switching frequency. The L1 part on the GT prototype driver would need to be physically ~10x larger to get the same performance. There are other issues as well, like having proper low-impedance driver(s) for the FET (s).
Firmware can be relatively simple. The LM3409 used in the prototype driver uses simple ‘hysteretic’ control: Inductor current gets to set-point, FET switches off. Current drops below set-point far enough and the FET switches back on. No PID loops or compensation issues. But without a dedicated SMPS chip, the SMPS-related logic needs to be robust. In a buck driver a software glitch could be instant death to the emitter.
Indeed, I have thought about using the MCU to control a buck before and it is very possible but also a lot more complicated. If you have the space and budget for the buck IC it is a lot better to just use that. If space or budget is limited then using the MCU would be a good idea.
For example in a 17mm buck space is so tight you might have to go with an MCU controlled buck just to have enough room to fit everything on the driver.
