Review is posted: Test/review of Zhurui Power Recorder PR10
Much appreciated. Looks good!
HKJ: Can you please review the charger that is available at https://goo.gl/3jVap4? Thanks in advance.
There is two reason I cannot review that:
- Amazon will not sell it to me, because I am in EU and not is US
- If they could sell it the shipping cost would probably be way to high.
Oh, let me look for one with an EU plug then.
EDIT: Here is one with the proper plug:
^ That should be purchasable where you live.
German is the closest Amazon store to me, but shipping is the same as the adapter. For know I have put it in my basket and it will have to wait until I need some more stuff from Amazon.
Any news regarding it?
Not yet, I have not needed anything else from Amazon yet.
I didnt get any response last time, so I will just quote myself
Any chance of testing this very cheap (costs like $11) and versatile powerbank Aili 119 (6×18650 not included): http://www.ebay.com/itm/20V-Mobile-Power-Bank-UPS-6-18650-Battery-Charger-For-Laptop-Iphone-Universal-/321866773183
Beside usb output it has options to adjust output voltage from 3,3V to 21V (up to 3,3A) so that it can also be used to charge laptops. I bought this one after I read a review where the writer claimed very high efficiency when charging laptop and average when using usb output . If this test is out of the question for you, can you please take a look at the methodology of this russian test and if its even theoreticly possible that boost from 9-12V to 20V is realized with such a high efficiency (97% ?). Thank you!
Link to the test: http://review-china.com/aliexpress/8488-.html
Translated into english: https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=\_t&hl=sl&ie=UTF-8&u=http%3A%2F%2Freview-china.com%2Faliexpress%2F8488-.html&edit-text=
I do have a couple of power banks in queue, I may even drop some of them because they are getting a bit old.
I have bought one of these and hope I get it tested.
Sorry, I cannot do better, but I usual buy a bit more than I have time to test/review.
How about the strange shaped usb power monitor.
John.
I have ordered the above two devices.
The usb supply will be reviewed, but at that price the most likely outcome is a couple of skulls . I hope the result will be better, but I doubt it.
I hope to get enough time to test the tester, it looks interesting.
Linking is hopeless, either I do raw html or I get errors or I answer my own posts, It looks like the above link works.
The problem is special characters like space, it is sometimes %20 and sometimes just a space, when doing links this often ends up in a non working result.
When doing raw html (Like in my reviews) there is no problem, but the editor tries to be smart and this do not work well together with me
http://www.gearbest.com/nillkin-adapter-_gear/
http://nillkin.org/accessories/chargers/
Asked GearBest staff about this strange “Nillkin Travel Power Adapter Dock”, as in the advertisement “Support 2.0A Quick Charge” is claimed.
Synopsis:
Your original question is "Is this a Qualcomm Quick Charge compatible charger? 2.0? Specs seem strange, what's the difference between this charger and http://www.gearbest.com/chargers-cables/pp_488880.html ? Thank you. Regards, Salvador"
Here is the answer from Our Customer service Team:
Hello Salva,
Yes.It's Qualcomm Quick Charge compatible charger 2.0.
Weird.
Weird.
If it is this one you mean: http://www.gearbest.com/chargers-cables/pp_630687.html
It looks like the quick charge is only a reference to 2A current capabilities, not to any QC standard.
8x18650 power bank with adjustable dc out. Does not come with batteries. The construction looks cheap as hell, but I’m interested how would it fare in your tests.
Or would it be too similar to the 6x18650 Qidian you tested earlier?
“Qidian QD188”:61.11€ |Neue Vesion Spannung Regulierung QC3.0 QD Laptop Power Bank ADJ. 18650 batterie Box QiDian 8 Abschnitte Typ C PD Batterie (QD188PD)|laptop voltage regulator|regulated powerbattery box - AliExpress. 8x18650 power bank with adjustable dc out. Does not come with batteries. The construction looks cheap as hell, but I’m interested how would it fare in your tests. Or would it be too similar to the 6x18650 Qidian you tested earlier?
interested too... and i was about to provide the same link on aliexpress, but than i saw maukka had already provided everything
