I`m in for one please.
If there were not the Q8 and my lack of 26650 cells
Totally in for one. I’d like a dedomed XHP70, but that’s probably not feasible.
Interested
Interested in one. Thanks
put me down pls
Yeah, I’m in die one Light!
I’m in for one.
I would like one. Please put me down.
Please put me down for ” Two ” units.
Thanks
damn that what sweet light kronos, too bad i’m kinda low budget right now.
I`m in for one.
Greets
Carsten
I’m in for one
Great job Kronos! Your light looks great! But the thicker floor plate isnt going to help a whole lot in transferring heat through the head because its not the thermal bottleneck. What are the chances of making the head a solid 1 piece unit for a few dollars more, and keeping the aluminum walls thick to follow the contours of the reflector to better transfer heat through the head? All that dead air between the reflector and the head should be solid aluminum, as thick as possible, without any right angles, using only radius cuts, and of a 1 pc design to assist in maximum cooling. Any compromise here limits heat transfer, which heats the base of the floor plate assembly… which in turn heats up the battery tube and the cells. Then we wind up with another powerful light, where the battery tube is almost as hot as the head after a full power run. This has been the limitation in almost every high powered light sold up to this point. Now you have a chance to address that problem directly before its too late. As it is now, the light has the same thermal bottleneck as the S70 (and most others), which survives at 5 amps. Since you’re almost doubling the amps, I think you’d do much better in asking ThorFire if they can accommodate us. Every little bit is going to count at those power levels, and cells shouldn’t be used as heat sinks for such an awesome light that you’ve created!
Thoughts?
I’ll take one.
Nice project, thanks.
Regards Frank
Put me down for 1pc.
Thank you.
Interesting light.
Nice to see the good heatshedding properties of the S70(S) has been kept and maybe even more inline with the Jax Hunter (the original design that if I understand correctly is a bit better the Thorfire S70(S)
Congrats on starting your Kronos business with a flashlight and not a watch, seems more fitting on BLF, cool.
Too bad you decided to be silent after dropping hint and hint of new lights more then a year ago.
It could have been fun to see this come to life. But lucky us it is mere renders now so there are steps to see after all ;).
Who made these nice renders by the way?
Can you show the driver?
It reads like the normal S70s driver with the sense resistor bypassed mod lots have done to get to around 9A.
Have you tested the new XHP70.2?
XHP70 lights are plenty and from ~$37 a S70S could be bought not long ago. Solder blob is practically free so a modern LED could be a nice justification of the high price (well sure people have no problem with you guys earning money but still almost twice the S70S price is pretty steep) it would also show it is a new light, not something in the works for many many months.
Oh yeah do not place me on the list now.
I am curious about the answers I just posted and can decide to be put on there when they are in.
Put me down for one please. Thanks!
Interested (one).
Add me to the list thanks
