Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 use coupon 76648A or 2017FNL to drop price from $29.95 to $20.96.
This is exactly the same flashlight as BLF A6 but with different name and additional matching 18350 tube already included in the box.
Haikelite is under restocking right now so we have to wait until new stock arrives. When the light is avaiable again you can use BG points to drop price according to your account VIP level as shown in the table. You still need enough BG points to do so.
BlitzWolf® 15W 2A Foldable Portable Dual USB SunPower Solar Cell Panel Charger with Power3S using coupon code D321CD brings price down from $32.99 to $26.39 (20% or $6.60 less). This panel can easily charge any smartphone and will also charge in overcast conditions as well (with decreased rate of course).
Registered shipping included but currently in preorder - stock is due to arrive on May 31.
The flashlight uses 2xAAA cells and Nichia 219B LED with CRI over 90 at CCT=5000K. It has 3 modes and always starts in low (4lm), medium is at 45lm and high at 180lm.
This LED marker is also known as FMA V-lite or E-lite (because it’s a clone of $40 S&S V-lite marker), it’s velcro backed, uses CR2032 lithium battery and operate for up to 120h. The light has two modes: constant and blinking and it’s made with elastic silicone so it’s completely waterproof and shock resistant. Good alternative for chemical lights.
Works one or two parallel 18650 cells which are not included, has USB output (can be used as powerbank) and additional red and blue LEDs for red,blue and purple light modes.
Be advised: main LED is probably some kind of XM-L clone, because there’s no Cree name in the description to be found. Still - for the price it should provide ample amount of light from 2x18650 cells - even stated 800lm should be possible but probably designates at best LED lumen. Two COB LEDs provide flood light, main LED is zoomable. There are 3 colors to choose from: black, red and blue.
