Interested (one).
Add me to the list thanks
Interested in two.
Thank You
I’d like to take one.
NOT IN, but watching!
In for one!
I`m in for one please.
…If it’s possible to use XHP70.2 final ?
Please, put me down for one. Thx.
Put me down for one please. Thanks!
Regards, Hardware
Dang this topic dropped of the front pages fast, a shame so here you go with a bump
Love the L6 anti roll cutouts smacked on a S70(S)/Jax Hunter head. You guys took the two popular XHP70 lights and used the one with the best cooling properties (good!)
For all the Convoy fans using a clear design feature of the L series, very smart.
I can’t recall what brand uses that diamond tube, something with pineapple in torch name
Clever clever!
I already have the L6, but i cant let this pass. Put me two please.
I’m in for one.
I’ve seen thermal imaging tests taken as a light was turned on and in the first seconds as the heat made it’s way through the heat sink. They said the pattern was almost exactly an inversion of the light coming out the front, so if you consider the light out the top as the top half of an X and the heat out from under the emitter as the bottom half of this X, you see where the heat needs to go for fast and immediate dispersal.
Having fins on the head, up by the reflector, is simply not efficient. Sure, eventually those fins will transfer some heat to the surrounding air, but the light has to get saturated first, allowing the emitter to sit in it’s own heat for far too long a period.
Deep fins in the expanding cone of thermal path would be most effective. And yes, if aesthetic fins on the head need to be figured in then the pill and head should ideally be one piece for effective saturation transfer.
The centering ring is almost always made of a plastic material, effectively insulating the heavy aluminum reflector against drawing heat away from the mcpcb or substrate. Would be nice if this large piece of aluminum were to be optimally mated to the head and a copper centering ring used to allow effective contact for thermal expansion into the upper part of the head/reflector to aid the lower heat sink. My 2 cents.
Reminded me of this guy:
Some 4 or 5 years back, the Solarforce S2200 and S1100 had that large diamond knurling.
The Solarforce had the diamonds as squares, so not quite the same thing. The MecArmy PT16 is also similar…
At any rate, it’s a nice grip platform to be sure, especially on the larger diameter battery tube’s such as this.
Muto, Muto
2 please, looks Awesome!
Thanks,
Keith
Yup, put me down for one!
This looks awesome, any chance on a ~4000K NW tint option?
Is the side switch built into the driver? If so, that will make it very hard to do a driver swap.
Also, what size is the driver?
So this thing may make sense after all. I always thought the cooling fins were in the wrong place. Maybe not.
