Oh IDK
Mine came in a plastic padded box (nice) with an Ultrafire cell.
Trust me, you dont want to use that cell, it’s crap very low capacity
Whether it comes with a cell likely depends on your location.
For example shipping a li-ion cell to USA is problematic and won’t be included.
I would be wearly of leds from ebay and you dont want those random bin tints.
Here is a list of places to get a better led
I already have a cell on hand, I’ll likely use that, but I may get a new one. Still thinking about that,
Well, eventually I’ll replace the LED with a chip that has a lower Kelvin rating. What does reflow mean? (Sorry, I’m an amateur at this stuff)
I see you edited. Thanks for the link
What’s the difference between the 5A and 4C tints?
The led has to be mounted to a MCPCB commonly called a star.
You can but the led already mounted to a star (some name brands are sinkpad and noctigon)
or you can buy the bare led, and remove the old one from the star that comes in the light, then put the new led onto that star. This process is called reflowing: led is soldered to the star and to remove/replace it you put it onto a hotplate to reflow the solder.
Easiest way to get a new led is to buy it on a star. You just need to know the diameter of the star that comes in the light so you can replace it with the correct size.
Then it is just a matter of unsoldering/resoldering 2 wires, as opposed to reflowing the whole led.
Wish I had a better answer but I will refer you to this chart.
Cree actually explains it in articulate detail but I can’t make heads or tails of it.
http://www.cree.com/led-components/media/documents/XLampXMBL.pdf
So would 5A have a more reddish tint?
4C is a bit warm, but nice, not too yellowish. 5A is a little warmer, closer to halogen/incandescent.
I’m probably gonna buy this:
~~lck-led.com - Informationen zum Thema lck led.
https://www.fasttech.com/products/1609/10003889/1425002-cree-xm-l2-t6-3b-10w-1100lm-5000-5200k-neutral
Is 20mm the standard PCB size for most flashlights?
It’s a shame that the emitters on all these generic lights are garbage. I’d pay a few $ more to get one of them with a good neutral-white OEM so I don’t have to swap myself. I happen to like the design of a lot of the generic hosts, although I tend to dislike the UIs with the forced strobe modes.
No there is not reaaly a standard size.
I would measure the star that is in the light or wait for someone to reply who has measured theirs. It can certainly be smaller than 20 in which case you would find yourself filing it down and having less area to solder the wires to
Yeah, I suppose I’ll just wait till I get the light, then measure it.
If you look at the thread Angler gave you will see this link
to a FB page with pictures where he diasassembles it.
It seems Thai, but google translate will help, as far as i can make up from his story, the pcb is 21 mm, so 20mm will do fine probably
QUOTE:
LA & A L2-8029 Flashlight
I decided to buy it. Because price and shape.
Price not over 400 baht.
(If not, start KFC around midway. Left hand note)
The shape is not small.
Equipment parts
The overall job is available at this price level.
There are boxes for aluminum body with clips.
Smooth aluminum mirror lens
16mm tube mount
Circuit size 21mm
UI
Shut off switch
Pressing the light will gradually decrease to the lowest level, the light will flash twice.
Double click on strobe mode.
The new Hi mode is always open.
Light indicator
When the red light on the flashing button
Full chart turns green.
Turn on the green flashlight.
The battery is all red.
Eating
@ 4.2V … Hi … 2300mA … Low … 280mA
@ 4.0V … Hi … 1950mA … Low … 240mA …
@ 3.8V … Hi … 1650mA … Low … 200mA
Brightness is about 500 lumen.
Shines about 5600 cd or 150 meters.
Circuit Charts fully charged: 4.19V is considered a flashlight, many brands are still swinging.
Available battery capacity: 1000 mA
Summary of advantages
Price with something Acceptable
Built-in battery box.
Cooling system is available.
Brass tube base with spiral tube Then screw the head with a flashlight.
Conclusion
XM-L2 light forge out the sky.
Ah, thanks.
Very good of you to find and translate this, however
I think something is lost in translation or perhaps just wrong.
If you look at this picture and consider that the LED is 5mm,
there is no way the star can be 21mm. It appears to be 16mm.
Looks like the LED will fit on the star 3 times across with 1mm left over (16mm),
definitely not 4 times with 1 mm left over (21mm).
I do believe after seeing this picture that the star is 16mm.
What do you think?
“16mm tube mount” must be referring to the star
It is more likely that the actual tube of the light is 21mm, but the star can’t be.
I think this picture pretty much confirms it is 16mm based on 5mm LED.
Has anyone seen this light in another store (BG, FT, etc.) ?
Oh, & welcome to BLF, NFRealBathrooms.
Thanks. Yes, I’ve seen it on AliExpress
