tbh with the wall thickness of the tube, the head is 190mm which is almost 8ā and a bit too bigā¦
At that point I may as well go all the way to 12ā, switch to a parabolic reflector, and get like 4x more lux which would be the worldās farthest throwing LED searchlight for sure.
I guess I have to think longer on which one I want to spend my money on
Thanks for the input everyone.
Impressive throwers. Are you using dedomed XPG2 emitters?
Just to clarify, when you measured the 1.5Mcd, did you use the distance from the effective divergence point behind the light, like you have talked about before?
No, I will be using an oslon flat black.
Planning to buy 10 of them, and bin them myself.
I also didnāt measure the 1.5Mcd using the divergence method because that needs to be done at 100ft+ to get an accurate result. http://nightsword.com/uniformbeamcalc/
Also, due to the crappy chinese lens, itās hard to see where the hot spot actually ends, which is kinda necessary when you want to measure the spot size accurately :C
I still want to build another lens thrower and this time use a proper quality professional lens to see how nice of a spot I can get.
Knight optical quoted ~$250 for a 150mm aspheric, which isnāt too bad
1.5Mcd from a 100mm lens means average luminance is 191 cd/mm^2, which is really high. Must be a pretty quality lens to get that (not to mention bright emitter).
Yeah itās an old-gen XP-G2 S4 dedomed at 6A.
I still think (based on what iāve seen from others) that the flat black will get even more.
The lens is pretty good for a chinese lens but the projection is no where near as sharp as the professional grade lenses I have.
