The MCPCB is 20 mm
The driver is an odd size with the two “ears” protruding. If the USB charger is not kept the easiest method to mount a new driver may be to strip the stock driver and simply use it to piggyback a new driver.
I have not measured any amps at all. Just lumens out the front.
I just ordered two directly from SupFire, flashlight only (no cells or chargers). Total including shipping to Sweden was $55.70.
I asked if they would sell hosts only, answer was no.
I’m having a hard time getting it out. Did you need to heat it up or just use a lot of force? Does it screw out normally or have reversed threads like some Convoy hosts have?
Hmmm. I had very little difficulty unscrewing it. I used my spanner tool, applied a little force and it came loose. It is a normal right hand thread, so CCW to unscrew.
The rear button certainly seems as if it was has hastily added. It doesn’t appear to be water tight at all. The metal cap over the rubber boot also flops around some.
I was able to line up 3 bungee cords and put a small block of wood on top. I pressed with all my body weight and it still slipped. I then added a bit of water to the rubber and wiped it to make it as tacky as possible and it just barely broke loose. Wow! I finally got it. :partying_face:
No glue, but super tight and with little to no edge to grip makes it tough.
I was able to straighten out the ring shape. I’ll just need to do a little touching up on it.
Despite everything being super tight on it, it’s a really nice looking light.
I fixed the metal tail cap button from flopping around by adding a piece of thin cardboard between it an the rubber switch cover under it. So now it feels halfway decent. After looking at the design closer, it may be waterproof.
I really like the side switch. It’s a kind of a white/translucent hard plastic. The button pressure is not real high like my DQG Tiny 7x xpg2, so it’s nice to press.
Now I just need to wait for my 30mm Texas Avenger FET driver to arrive and I can trim it down to 26mm to fit. Wire up some nice power on leds to the switch, put the 26350 batteries in and then the xhp70. I’ll figure out how to get a copper block in there to add some mass while I’m waiting.
