Great, thank you! The diameter of the threads here is 22.5 mm and the outer diameter is 25.5 mm. So giving the clip some space to the diameter of the threads and starting at 22.7 mm it should be possible to make it flush to the outer diameter of the tailcap. Btw, the clip from oveready and darksucks both fit on the Sinner, in case you’re looking to replace the Solarforce one.
Your comment made me thinking if it wouldn’t be better to go for a 0.8 mm thick clip instead of 1 mm. I actually like the clamping force of my 0.8 mm clip.
Interesting, do you have any ideas for the improvement of the FW3A design based your experience with Sinner lights in order to avoid broken lights?
Ah good point TK of having the clip protect it from rolling away.
Will update list later.
Well the driver design is almost done with adaptation to allow a future firmware with screen config to be used, but it will not likely be a feature directly and probably requires flashing new firmware later if it gets done.
If anyone is interested to see how the finish might look, banggood is currently selling a clear version of the BLF A6.
And the finish on the FW3A will go in the same direction, just the machining of the threads will hopefully be better
So your bringing attention to the bare A6 made me pull my down from the shelf and give it a look. And odd as it is, the Efest 35A cell inside is deader’n a doornail! No charger I have will recognize it at all. How does that happen? There’s no parasitic drain on this tail clicky light, so why did the cell die?
My clear A6 has a de-domed XP-G2, the moon mode is low but not ultra low, difficult to not see that it’s making light while setting it down especially as it resides on a top shelf above my head… it would have been shining virtually in my face as I set it on the shelf. A6 firmware, so there’s not really a hidden mode that would not have been noticed.
And, this is the third Efest cell lately that is totally dead on me. (worthy to note that this one IS 3 years old…)
