Hey guys,
So I’ve searched and searched until my fingers are stubs from typing into google but to no avail.
Does anyone have a definitive, pictorial answer to what happens when you slice the dome of an XHP50.2.
Sorry to sound like a dick but i don’t want ‘the xpg3 is crap so the 50.2 will be too’ type of answers.
If possible I would like a before and after beam shot with lux readings or at the very least an ‘I did it and X,Y and Z happened’ type response.
I have a 50.2 equipped C8 which is really nice but I would like to eek out a bit more throw and reduce the spill a touch.
If I had a spare or 2 I would do it myself but as I’m in the UK I’m limited to intl sellers which means long lead time and high single item costs.
BobbyMK sliced an XP-L2 (same technology as XHP-50.2) and cut away all the excess phosphor on the outside. This removes the yelllow/green corona that normally occurs when you de-dome these new Cree LEDs.
Slicing has the same effect with most LEDs. You get half the hotspot size and 70-90% more luminance.
I don’t think these new flip chips (XPG3, XPL2) get as good a luminance boost upon dedoming as the old versions. For example in your link a well driven XPL HI or dedomed XPL would get significantly higher than 28.5Kcd in an M1. Same with the XPG3; people all got pretty underwhelming results.
Well I just bit the bullet and sliced my XHP50.2 and I’m absolutely ecstatic! No green and 196k lux at just over a meter. Not bad for huge die in a small reflector! I did as was done in the posted link and scraped as much of the excess phosphor as I dared (~1mm left surrounding the dies).
Also I thought I would add, the dome on these emitters is completely clear, the yellow appearance I can only assume is a result of the excessive amounts of phosphor covering the whole chip.
The gains may not be as dramatic as with the older gen emitters but gains are still gains. As a novice modder I’m in no position to give advice, but if I can successfully slice one of these with good results then I feel the pros among us should not give up on them.
The host is a convoy C8 with smooth reflector and pre slice measurement was around 92k lux, it’s over 100% gain but I think part of the jump was due to the fact the reflector was a little out of focus before the slice.
I will hopefully upload a picture shortly.
Lux meter is ‘max meter’ branded, cost around £20. I set the meter against a wall and point the light at it and took the measurement after 15-20 seconds. I can’t wait to the 30 second mark as it drops out of turbo at 30 seconds due to massive heat. The host can’t dissipate the heat generated by a DD 50.2 running at ~10A fast enough
I think the next question is at what distance did you measure the light intensity, with a C8 size reflector you want at least 4 or 5 meters to get anything correct.
Just from my experience and reading others’ experience I can guess about what an LED will do in a given reflector. ~190Kcd is what some of the best emitters will do (the emitters with the highest luminance, like dedomed XPG2) in a C8. From my experience with the sliced XHP50 I know it has significantly less throw than a dedomed XPG2, partly due to the gaps between the dies. From what I have seen the new style of LEDs from cree (XPL2, XPG3, XHP50.2) have even less throw than the old versions. So this is what makes me suspect your results. But, I haven’t actually seen any measurements for the XHP50.2, so I could be wrong.
What distance are you measuring from and what math do you do to get to the candela number?
Flash max: the LED is an 80+ CRI 3000k stock. I haven’t noticed a considerable tint shift and i stupidly didn’t take a pre photo for comparison.
Light bringer: I’m not sure what you mean by distributed phosphor. I’m pretty new to flashlights and modding but I like to dive into things headfirst at the deep end with a lead helmet.
I’m using 2 VTC5’s in series, in direct drive I’m getting ~10A at tail cap.
How do I convert from lux to cd? I just used rapidtables converter and it’s saying that 196k lux is 259kcd.
This is all new to me so I’m probably in need of some educating.
To convert lux to kcd you need to know the exact distance. For example I use 5 meters (the longer the better), so to compute kcd:
meter reading * distance * distance (distance squared in meters)
If you measure in true lux (typically I use the 10X setting), then for 5 meters multiple by 25 to get cd. kcd is 1,000 cd. We usually quote kcd - no need to add decimal digits - our meters ain't that accurate
Regular “old” LEDs would have a phosphor coating right on the chip itself, which is why white LEDs look yellow.
“Remote phosphor” would be a plain blue LED, but the phosphor is off the LED, like screw-base lightbulbs with blue LEDs but yellow-looking plastic “shells” around it that convert blue into multi-spectrum “white” light. On an LED it might be a hollow silicone dome but with the phosphor coating on the inside of the dome. Dunno any that do that, though.
“Distributed phosphor” would be having phosphor powder/flakes/whatever being mixed into the silicone itself and then formed into a dome or coating.
If you look at a G2, you can actually see the chip through the clear dome. The G3 looks like it’s got an orange dome itself on top of the LED.
I don’t have any G3s (only ordered some G2s for the first time), so I’m only going by the pix I can find online, not having an actual chip to eyeball.
