JAXMAN, M2, E2 & E2L, Sitting in row,eatting fruits together with you.
2017 April 27th
1. JAXMAN M2
CREE CREE XM – L2 U2 LED 400LM: 1A 6000 – 6500K/ 3C 5000 – 5500K
http://www.gearbest.com/led-flashlights/pp_621642.html (link is external)
High – low, two kind outputs meet your requirements
CNC machined 6061-T6 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan and reverse polarity protection to ensure users’ safety
Adjustable two brightness levels: 50Lm ( Low ), 400Lm ( High ). Slightly tap the tail switch of the torch to switch the brightness.
The default level is low level.
2. JAXMAN E2
CREE XM-L2 U2 LED 580LM: 1A 6000K, 3C 5500K
Nichia LED 350LM: 5700K, 4000K
http://www.gearbest.com/led-flashlights/pp_355970.html (link is external)
High – mid – low – strobe – SOS, multiple outputs meet all your requirements
Compact and lightweight, with premium lanyard for carrying every day
IPX-8 waterproof standard, even protects your light from powerful water jets
Powered by 1pc 18650 battery (flat top)
High CRI, more than 90 RA
Switch Location: Tail Cap
Reflector: Aluminum Half an Orange Peel Reflector
3. JAXMAN E2L
CREE XP-G2 LED 900LM: 1A 6000K ( white ), 5A 4500K ( natural white ), 3C 5500K ( neutral white )
http://www.gearbest.com/led-flashlights/pp_619108.html (link is external)
High – mid – low, multiple outputs meet your different requirements
CNC machined 6061 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan, reverse polarity protection, low-pressure slow flash tip and over-discharging protection to ensure users’ safety
Powered by 1pc flat top 18650 battery ( not included )
Running time: 29h ( Low ), 295 minutes ( Mid ), 90 minutes ( High )
Adjustable three brightness level: 50Lm ( Low ), 300Lm ( Mid ), 900Lm ( High ).
