Klein is a reputable brand, but like others mentioned, it may be overkill, depending on your application. For a little over $20 you can get an autoranging Innova 3320 from Amazon.
I was looking for a DMM, and not sure which. The UNI-T UT61E or Klein MM600. It seems like the UNI-T has some issue and the Klein I can’t find much on it. The UNI-T has a extra digit when compare to the Klein. Don’t know if that matters. I’m just looking for a dependable and accurate DMM and one cheaper one probably the Innova.
@teacher That was my plan. I was going to do a little research to see want kind of flaws the ut61e has and to see if I kind find more info on MM600. I was going to use them for auto and around the house beside checking battery.
While I was at Walmart I pick up the ONN charger they had in stock.
If you can return it for a full refund without a hassle, then it may be worth trying. When you get it, compare it against a known reference and if it’s pretty close, then you can keep it. Otherwise, return it.
If I go through Home Depot it has a 30 days return policy. None of the Klein Tool DMM can be calibrated. My concern is after the warranty period if the calibration goes out i’m stuck with a expensive paper weight. I’ve been reading on different forums and it seems like the calibration goes off a little in about a year (not sure if it’s true).
I see. Well, there are other DMMs out there in the same price range as Klein that can be calibrated.
If I didn’t already have a DMM, I would have gotten a Uni-T UT61E.
But let’s face it, we are splitting hairs here. Majority of these DMMs, even if they’re off, they’re off only slightly. For what we do here, these differences in readings would not be significant. So I would not go as far as calling them “paper weight”.
Since I’m not the only person using it I like to get one that is quite accurate without going over board on the price. It’s going to be used for more than checking batteries.
Most any modern day meter is very accurate. Remember the story of my years old Innova 3320?
For what we do that one is just fine… as are any number of others. But if you want absolute accuracy, and none of the cheaper brands or knockoffs fill the bill for you……
Do like Pete7874 said and fork out the bucks for a Fluke.
I knew that somebody is going to mention to get a Fluke. That why I mention I didn’t want to go over board on the price.
I guess I was asking if a cheap DMM can be accurate as a Fluke and reliable over time (I know teacher is going to mention 3320). If a DMM needs to be calibrated, does it hold the calibration for a long time or does it need yearly calibration?
For hobby/student DMMs, the answer is no. You don’t have to calibrate it every year. Please take note of the quote: “A long calibration period for the digital multimeter is normally to be advised, except when particularly demanding testing is required.”. For a 3 1/2 digit battery-powered DMM, most never get calibrated after being bought.
If you’re using a 6 1/2 digit unit, and measuring microvolts to trouble-shoot medical equipment, that’s another story.
It all comes down to how important absolute accuracy is to you.
Here is another link that might be useful….
——— @Venom
I think the answer to your question lies in how important is absolute accuracy to you?
If your meter reads 4.9998 V or 5.0001 V instead of absolute 5.0000 V…… is that acceptable to you?
Also be aware, as mentioned in the video & links above; that what I/we loosely refer to as “calibration”: does not always include adjustment.
Like anything else… this appears to be able to be taken as deep as one wants to go.
I have found a few more things on calibration that I find interesting (even if I do not understand most of it… :person_facepalming: . ), so I thought I would share links to them.
They are listed in no particular order of importance. I just listed them as I found them. The ones that are not bold seemed less applicable to the subject “to me”… but I listed them anyway.
I listed so many because I did not have time to read them all right now & wanted to have a reference I could go back to.
There is a lot more to this than I imagined……
So, without further adieu; let us proceed.
Precision Multimeter Calibration Reference
……… This guy said the following at the beginning of his article: “WARNING / DISCLAIMER: If it ain’t broke, don’t fix it. Tampering with the settings inside your multimeter will void the warranty, could mess up it’s accuracy permanently, risks causing mechanical failure, and could feasibly cause actual danger from high voltages. I accept no responsibility for any damage caused by following these instructions.”
I know I have mentioned a Innova 3320 meter many times. I am not saying it is a “quality” meter… in the big scheme of things it most likely is not. BUT, although I do have a more expensive meter, the Innova is just as accurate to 1/100th of a DC Volt as the more expensive meter.
For me this is more than adequate. I am not testing pacemakers, other medical devices, the Space Shuttle, or anything that has to do with life or death. Sooooo, I’m good.
And as I said before, when I received the more expensive meter & a VRM (voltage reference module) as a gift from a BLF friend in the UK…. (thank you again Ian… :+1: ); the years old/rough treated Innova and the brand new meter both were right on the money.
Sure the newer more expensive meter has more resolution, it will measure to 1/1000th DC V and do a bunch of other neat stuff such as temperature; that the Innova does not have or cannot do. And all that is pretty neat.
So basically, as far as “I am concerned”; a meter choice just boils down to how much money one wants to spend and the absolute accuracy they require.
And I am far from an “expert”…… so take that .02 for what it is worth.
But as for me, I am more than covered with what I have.
When looking for a DMM you also have to think about it usage.
Fluke is designed for mains work and will easily handle industrial or outdoor conditions, they do also use very good parts, meaning that the calibration will hold for a very long time.
Second up is Keysight(Agilent). They are very good, but a bit more technical than Fluke and in my opinion not as precise over time.
After that there is a couple of brands that is good and also usable in mains work.
Below that is all the cheaper DMMs, they may be precise, but the safety is not up to industrial mains work, as long as they are used for batteries and other low volt tasks there is no safety risk, but do not take them to a high power environment.
I usual use Fluke and Keysight DMM’s, I know they are very precise and I do not have to check them against my references very often (For precision over time nothing beats Fluke).
I haven’t read the whole thing; I just figured out you’re looking for a DMM? Here’s my take on why I’m happy with a cheaper DMM (maybe someone else already wrote something similar…).
1) I want to measure parasitic drain, and let’s say I measure 20 uA resulting in a self discharge time of 20 years. A 10% error is extremely high, resulting in 22uA and ~18 year discharge time, but nevertheless this is sufficiently accurate for me. I’m interested whether self discharge time is 20 years, 10 years, 1 year, or one month. That’s the kind of ball park range data I’m interested in, so there is no need for an accurate DMM.
2) I want to check status of my four 18650 cells after using them in a 4S flashlight. Let’s say my DMM says that voltage of one cell is 3.657 Volts. I’m not interested whether the actual voltage is this value, or perhaps it’s 3.75 or 3.51 Volts; the error would again be fairly large. Even if my DMM is not accurate, repeatability is high; this means that the voltage of my other three cells should be about 3.657 V as well. If this is not the case, then something is wrong with my cell, and I should monitor it during charging and next discharge.
Basically you pay a lot more for enhanced accuracy, and accuracy over many years of use (Fluke), but I’m not interested in absolute accurate values of voltage, current, lux (it’s on my DMM). I’m interested in differences in values of voltage, current and lux, and cheaper DMMs are good enough for this purpose.
