With an Thorfire S70 lens it makes 5740.8 lumens
With an Klarus G35 lens it makes 6168.60 lumens
With no lens at all it makes 6523.95 lumens
So there ya have it. The S70 lens is costing it 783.15 lumens while the Klarus G35 lens is only losing 355.35 lumens. This is all on the same LiitoKala 5000mAh cells without recharging them, I took the S70 reading last night on fresh cells, the no lens reading first this morning, then the Klarus reading last.
I also talked to somebody that has used the SIR404DP MOSFET quite a bit lately and found them to be finicky, easily damaged by heat in the re-flow sequence. So I’ll be pulling the 404 and putting an 800 back on.
People ask why I pay $8 for an UCLp lens, with a lot of effort going into making a 6500-7200 lumen light it sucks to lose 780 lumens to the lens! Cutting that loss as much as possible is worth the price, considering the FET itself can be as much as $4, why not let the light out with the right lens?
I’ve shown a light to my Dad before after putting the UCLp lens in it (without saying anything about the lens swap), no kidding he tried to put his finger in the reflector declaring I’d forgotten to put the lens in! Then the astonished look on his face when his finger hit the lens, like that last step you thought was there and about fall down when it’s the floor instead of another step. I myself have completed a build and thought the same thing, you see the emitter so clearly down in the reflector that you have to tilt the light around and try to catch a reflection off the overhead light or a window, it’s really just amazing how clear it is.
With the 91K resistor on the switch LED’s and the new 20mm driver now having an SIR800DP FET on it, I’m still only getting 5754.6 lumens with the Klarus lens on and 6272.1 with no lens at all. So I’m nearly 1000 down from when I first built this light. In this instance, the lens itself is robbing me 517.5 lumens. Guess I’ll be getting an UCLp and see how that works out…
On the plus side, it’s working fine with the lighted switch.
Hey lads what KCD numbers are people getting from there L2? I measured mine at 270KCD but i am not expert at measuring distance. I shined it across a bay i was fishing at and i could see the light on a white house which is 1km away. It light up the reflectors easily but i was surprised to see it shine on a house.
Its hard for me to gauge distance i live on the coast and we stick out further then most of sydney so we cop all the wind this leaves a lot of water particles in the air. I have noticed if i do beam shots at my girlfriends parents although its a lake its like 30min inland and there isn’t much wind and waves so all lights shine better there.
Follow up to my previous post of L6 with TA driver w/ narsil v1.4. By Lexel. Previously the led had a very low glow with side switch in the off position & tail on. See post #227. Lexel thought it was a leaky 7135 chip.
Now I’m seeing this, batteries are at 3.9 volt ea. Wondering if there is a way to measure 7135 chips to pinpoint the culprit.
Regarding the glowing emitters while off, I think I know the cause in my case. Your cause might still be the 7135. I’m not sure of an easy way to check for sure other than removing the 7135 chip and seeing if the glowing stops.
I used all 7 emitters/MCPCBs from my 7xXPL L2 build to make my 7xC8 build, using a (different) FET-only driver with e-switch. Now only the first parallel string of emitters glows while off. So I think there must be a high-resistance connection from one of the LED negatives to ground. In my L2 build I must have had this one LED in the second parallel string, which made all of the emitters glow. In my current build that one LED must be in the first string (from positive), making just the first string glow.
