making 3. Batch Texas Avenger "TA" / Bistro HD OTSM drivers fully tested running Bistro or Narsil, Clicky or E-switch, SIR800
Yeah Tom E changed LVP to 2.8/3V for the Q 8 before it was 3.0/3.2V I can calibrate that to any level you want, 2S needs modified voltage divider And then change the setting before flashing to match 2S LVP
For medium single LED lights or big multi LED lights I recommend Over Temp Protection of 60-70dC
If your light has a tailswitch as well you can choose how the driver reacts to be powered on with a forward clicky tactical with turbo makes sense
more 30mm driver requests come in
I ordered today 6 more 30mm boards, but those drivers ordered lately will be ready a bit later as those boards will be produced almost 2 week later than the first
For Bistro OTSM 2S I got the information it may be running only with LDO properly, I asked flintrock if this is the case
Lexel, on the 30mm boards what diameter would they be without the excess material on the edge?
Is the center part basically the same as the 22mm?
the center part is almost identical to 22mm, some parts have a little more space between em like the bleeder
you can reduce it to about 24mm and still got some copper ring around
Do you use 350 or 380 mA 7135s?
350mA
When the time’s up to make an order?
I think that’s the driver I want, but I changed my mind twice in a week and would rather have it settle in me :slight_smile:
Getting in the final stage of ordering the parts
first 6 Oshpark boards and 200 AMCs arrived yesterday
today a big part of Oshpark boards arrived
just amazing how tiny a 17mm driver looks compard to 46mm
BUT
3 of the 22mm LDO bards came without contact ring on the MCU side
and 3 46mm SRK without the contact ring on the retaining ring side,
just removing the paint with a knife or chemical will work
I will contact Oshpark to get replacements for them,
but it should not be a big deal to use em, only if you got no problem with it
or you got to wait another 3 weeks
Please everyone check if the data in the Excel sheet is what you want, I will build what is listed there
Parts from Digikey will get ordered today
Batch is limited to 58 drivers by the SIR800 FET
2 Backup MCUs ordered in case one is faulty like last batch so probably 60 possible with IFR or LF PAK33 (15mm)
43 drivers are taken 2 pending feedback
I’d like 2*17mm. Max number of 7135. It can go without firmware, I want flash my own Bistro-based image anyway.
I will flash it for testing the driver anyway, of course you can send me your custom hex file
Standard TA Bistro or HD OTSM?
OTSM has more expensive parts but no more issues with hot light and OTC timing getting almost unusable
springs?
:+1: mine are OK
Seems ok
All good on mine.
All good for me
more boards from Oshpark
sorted by size
ordering from Digikey tomorrow
I’m a bit lost with HD OTSM, I haven’t spotted its existence until now.
Reading / skimming quickly through its topic I guess that’s what I want, but is there a summary of hardware differences somewhere?
I’ll take 1 short spring.
Hi there,
Id like to get in on the fun. Intersted in a narsil driver for Convoy L6
My line on the spread sheet looks good.
Question for all (not just Lexel). I have ordered a 46mm for a Q8. I requested the temp sensor set to 60°C. I see on the spread sheet the other 46mm orders have selected 70°C. Am I being too conservative (setting too low)? What would you use for a Q8?
You will have to choose between having low voltage protection and no temperature stepdown (narsil v1.2) or
temperature stepdown, but no LVP (narsil v1.4).
I went with LVP and let my hand control the temperature.
