I’m away for the weekend now, the screws are M2 I’m guessing, but perhaps one of the other prototype people can confirm.
I’m not sure how much harm the loose traces can do, Tom mentioned (and I have experienced that too) that the KD DTP-boards do that too. It is certainly a concern that we will communicate to Thorfire. Is there anyone who has experienced functionality loss or danger from the delaminating of KD boards yet?
The biggest issue with the traces de-laminating are first that without the heat sinking they could overheat, although they are pretty beefy so this should not be a big issue.
The second possible issue is they could possibly short out against the mcpcb base since the substrate is obviously not that great.
Although this could just be due to a bad manual reflow where they overheated the mcpcb, I have done this before. In which case with a proper production run where a reflow oven is used, this should not be an issue, hopefully.
That would mean that only half the threads are actually engaging with the holes, leaving it very easy to strip by overtightening.
Just thinking about eventually modding when better LEDs are available, it’d be better if the parts lined up correctly.
They need to align them using a jig, not hand-drilling.
I have reflowed some kd-board and did not had any issue.
But with very high overheating I had this on a sinkpad. Or I had Problems with a Nitecore EC4S.
There are no threads in the LED board, so no problem there. I don’t recall anyone mentioning the threads in the shelf being loose at all. As long as the screw has a snug fit in the threads of the shelf, and the head of the screw holds down on the LED board, all is well.
Correct David, the board is clamped in well and tight. Actually, I tightened all screws more than Thorfire did. I even think (imagine) that the better clamped tailboard boosted output a bit. 20A is a b*tch for any connection!
So far the best coating/paint i tested for lantern diffusers (to reflect & disperse a flashlights focused beam) is flat/satin white on the opposite end of the diffuser. it reflects the most of the output compared to silver, chrome, or even shiny white paints.
One trick to make the flood of the diffuser warmer tint is to use an “off-white” or cream flat/satin/matte color paint if diffusing a cool white flashlight.
Talk about preoccupied.
I was baking the Q8 this afternoon when a storm broke
Hail and thunder
So I get outside to protect a very small olive tree and when I came back in it was raining inside.
A tile or probably even a few must have been broken by the hail.
And a beam guided water Creating a nice waterfall
And below that beam, my notebook, soldering iron, box with Q8 parts.
Dang dang dang.
Quickly to the shop to get rice and roof tiles
Notebook in a bag with a kilo of rice.
And a sloppy fast assembly … Oh will it work, yes light!
So rest asure the Q8 lives!
(Not able to upload pics or edit OPs till my notebook is dry )
Somebody call a digital doctor!
Anyone know how to do CPR on a computer?
Or, anyone know who to call for a little techno-necromancy?
I hope the ghost will stay in the machine.
Heheh notebook not clear, I let it sit in the bag.
It is a 17” that is easy to take apart so I’m sure it’ll work or I get it going again if not.
Q8 is fine that is good!
And well did do a leak in a lower placed roof a while back, this shows its time to check all.
Also that ugly satellite dish on thw high roof needs to go, it messes up the beamshots
