If anyone is interested to see how the finish might look, banggood is currently selling a clear version of the BLF A6.
And the finish on the FW3A will go in the same direction, just the machining of the threads will hopefully be better
It will be smaller and brighter than the A6 though, yeah?
So your bringing attention to the bare A6 made me pull my down from the shelf and give it a look. And odd as it is, the Efest 35A cell inside is deader’n a doornail! No charger I have will recognize it at all. How does that happen? There’s no parasitic drain on this tail clicky light, so why did the cell die?
Left it on moonlight or one of the hidden modes by mistake? I’ve done that
My clear A6 has a de-domed XP-G2, the moon mode is low but not ultra low, difficult to not see that it’s making light while setting it down especially as it resides on a top shelf above my head… it would have been shining virtually in my face as I set it on the shelf. A6 firmware, so there’s not really a hidden mode that would not have been noticed.
And, this is the third Efest cell lately that is totally dead on me. (worthy to note that this one IS 3 years old…)
High internal resistance is my first guess. If the cell was abused like I am sure it was, this is not far fetched. Possibly a short in the tail switch allowing a small amount of power to flow but then the LED should light up I figure.
How does the bare aluminium hold up? Does it scratch very easily?
Yes, bare aluminum is pretty soft / scratchable. However, it’s not usually very noticeable… and it’s not difficult to polish if desired.
Clear anodizing would make it much harder to scratch, and would still not look bad after scratches form since it’s at least the same color. However, it wouldn’t be polish-able, and clear ano is difficult to get right since it’s so thin.
Um, sorry TK, but clear anodization is merely regular anodization without dye added before the sealing process. Not thin, not any more so than any black anodized light. Take the ZebraLight or DQG Tiny III 7xXP-G2 for example, they are anodized without dye but hold up very well.
In the case of the DQG, it’s also a direct from machining ano process, showing the lines from the tooling. And by the way, these lines are really not necessary, a final pass can be made at slower feed rates for a near polished look straight off the lathe.
I don’t mind natural / no-dye anodizing, like what Zebralight and DQG do. It’s strong and it gives the light sort of a darkened grey or brown color depending on how thick the anodizing is.
Clear / silver anodizing like the Convoy lights is pretty thin though, enough that some areas can conduct electricity on some units, because thicker coatings darken the surface. From what I hear, Simon had some trouble getting the right balance on those because a little too far one way makes it too dark and a little too far the other way makes it too thin.
Originally I thought it was anodized to a normal thickness with silver dye, but apparently that’s not how he did it. It’s just thin enough that it doesn’t change the color.
I wouldn’t complain if the FW3A used natural type-III anodizing, even if that makes the surface a darker color. But I also wouldn’t complain about a thinner “clear” anodizing or even none at all. I like all of them. Bonus points for purple though, or rainbow, or candy colors. Would be pretty awesome to get candy-grape purple (chromed with translucent purple over it).
Only if the new emitter is infrared or ultraviolet or some other frequency the screen doesn’t produce.
mark
List updated
TLF and BLF nearing 500, wowsers
It is done when it is done
How my BLF Specials generally work, please read before asking Qs
The Q8, Exciting a groupbuy for a Premium BLF special high lumens soda can light!
The GT, A BLF special GIGA thrower
The FW3A, a TLF BLF special small, elegant, powerful triple
Lithium Ion safety 101 important read
Sorry grammarlovers, I am a real King Typo.
i am in for two
Would the abbreviated logo “T & B LF!” be too provocative?
In for one please
Thanks
Maybe BLTF? Bacon, Lettuce, and Tomato Flashlight.
31 knives for sale=USA only ☮♫☯
[WTS] Brand New Timex Expedition Vibe Shock Camo Watch [USA Only]
sweet
Very nice, interested in 2
Yes cabfrank, and a little more elegant and less boring too (IMHO so that is mere personal taste/preference
will update list later
I’m in for 1 please.
Texas Avenger Driver Series
My LED Test series - XP-L2 V5 - Nichia 219C 90+ CRI - Latticebright "XM-L" - XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5 - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Easy comparison tool for all my LED tests
Yeah, I wanted a bare one so I got them to make a bare one.
It’s not anodized at all; it’s just the bare machined aluminum. The texture is pretty grippy due to the machining grooves:
Some people have polished theirs to give it a smooth shine.
Thats how I think the finish on this should be, just bare aluminum. Clear anno doesnt seem really worth it
-the- Throw calculator - Pulsars list
That’s cool. How does the bare aluminium hold up? Does it scratch very easily?
I am interested, put me down for 1
Welcome to BLF!
Will update list later
I’m in for at least one.
2 for me please!
When I'm spending mon€y foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
I sort of like the idea of clear anodizing if the threads are anodized to provide a lockout by a slight twist.
BLF Member Map Add your name and location.
Please and me for 1, thanks
In for one please
