Also be aware that many USB cables use very thin wires, which does affect their ability to transfer high current, meaning that the charge time will be considerably longer.
Anker, for example makes excellent cables.
The Rolls Royce of cables is probably this one: https://paracable.com
You can charge a TIP, Tube, Imalent DT70, Zanflare F1, or any light that is rechargeable via USB with a Samsung USB cable/charger that you get with your Samsung phone (the exception being the Wuben T102 which requires USB C). At least, that’s how I see it.
All micro USB leads will fit , however the charge rate will vary I have some cheap ones that will pull a max of 0.5A while a good on will pull 2.0A . Makes a big difference charging my BT speaker (Anker 3143) on that its 0.5A generic lead vs 1.5A Anker lead.
Maybe I’m not understanding the question you asked or missing what your getting at,so apologies if I am, but in my experience if a device has a micro usb port then any micro usb cable will fit in it, - I’ve got a whole host of various devices, torches etc with micro usb ports,as I’m sure many people have, and ive never had a problem with any of then not excepting a micro usb cable - some may charge slower as others have mentioned , especially if it a cheap - or very long- micro usb cable on say my Samsung s7 edge, my FLIR camera and my Mavic pro drone, but they all charge,sometimes it just takes longer
As long as the device is listed as having a micro USB port any micro USB cable should fit and work. The only issue I have had with the EE X6R, for example, is that if I use one of the reversible micro USB cables it will only charge if inserted in one direction. Whereas the same cable charges my tablet and my pohone via the micro USB when inserted in either direction.
Last night while lining the Apple with the Samsung I notice the Apple was difference. After doing research on the lightning connector it makes sense now. The Samsung uses a micro b plug.
this is typically Apple (not in a good or bad way). They have their own proprietary connection so they can design it to their needs without having to take standardisation into consideration. At the same time this means that as an Apple consumer you are forced to buy their cable with a nice profit margin for Apple.
Having a family that all have Apple iPhones, the 1 aspect of the Lightning cable that I like is that it can be inserted either way. There’s not a top or bottom to it. On the other hand, the micro, mini, and regular USB can only be inserted 1 way. And with the micro USB, sometimes I think I’m inserting it the right way, but then it seems to not quite fit and then I’ll realize to turn it around. I haven’t broke a micro USB in a device yet, but my son has. They seem a little fragile.
