I am interested, put me down for 1
Welcome to BLF!
Will update list later
I’m in for at least one.
2 for me please!
Um, sorry TK, but clear anodization is merely regular anodization without dye added before the sealing process. Not thin, not any more so than any black anodized light. Take the ZebraLight or DQG Tiny III 7xXP-G2 for example, they are anodized without dye but hold up very well.
In the case of the DQG, it’s also a direct from machining ano process, showing the lines from the tooling. And by the way, these lines are really not necessary, a final pass can be made at slower feed rates for a near polished look straight off the lathe.
I sort of like the idea of clear anodizing if the threads are anodized to provide a lockout by a slight twist.
Please and me for 1, thanks
I don’t mind natural / no-dye anodizing, like what Zebralight and DQG do. It’s strong and it gives the light sort of a darkened grey or brown color depending on how thick the anodizing is.
Clear / silver anodizing like the Convoy lights is pretty thin though, enough that some areas can conduct electricity on some units, because thicker coatings darken the surface. From what I hear, Simon had some trouble getting the right balance on those because a little too far one way makes it too dark and a little too far the other way makes it too thin.
Originally I thought it was anodized to a normal thickness with silver dye, but apparently that’s not how he did it. It’s just thin enough that it doesn’t change the color.
I wouldn’t complain if the FW3A used natural type-III anodizing, even if that makes the surface a darker color. But I also wouldn’t complain about a thinner “clear” anodizing or even none at all. I like all of them. Bonus points for purple though, or rainbow, or candy colors. Would be pretty awesome to get candy-grape purple (chromed with translucent purple over it).
In for one please
Candy-grape purple just doesn’t do it for me. :confounded:
I’m good with clear or natural type-III though. :sunglasses:
I’d take candy-grape purple if it included a lightning strobe.
Oh geez. Put me down for 1.
Yes will update list later.
Inger stuff about the anodization.
It seems a bit tricky to give it a look without the ano changing it.
Hello,
Too pretty to pass up. Please add me for 1.
Thanks
You sure??
I’m in for one please, Thanks.
:heart_eyes: Purple for me all the way and I’ll take 3!
That grape looks pretty good to me also!
Yeah, but is it the color or the light?
I am in for one. Thanks.
