The Miller, if I can, I also wanted one.
Thanks.
Thanks.
I would like to be on the list if it isnt too late.
Does rain water have a heavy enough mineral presence to leave a robust evaporate film that short electronics? Honestly? How do grapes grow to make wine in France with so much salt present in the rain?
Hahaha water coming through the roof is not clean anymore.
There is not a hole in the roof, there is/are opening(s) where water enters, then finds its way down the several layers the roof is made of
Indeed was rain just directly fallen on it I would just dry and only open if not working.
So I’ll take a look anyways now
Will update list later!
Being the miller is living “down there” i would assume his roof are made of slate shingles, and since some have been pulverized there must be some minerals in the rainwater.
The first winter in my house we had snow blow into the sealing :person_facepalming: so the following summer i had to go up on the roof and fix the very top of it as that’s where the problem was.
And i can assure you sitting up there with one leg on either side of the roof, pretty fast that become only enjoyable to masochists.
So i had to dismount the roof pretty fast and go get something thick and soft to sit on while i scooted backwards on the roof top as i fixed the problem.
<—- grew up in Dad’s lumber yard, built quite a few houses after he sold the yard (they [Dad and his brother] had up to 7 carpenter crews, sawmill, lumber yard, 35 years) So I definitely know the feeling Sparky.
Sad to hear that TF will not give us the 3 bladed tailcap but it is nice to see that the Driver PCB is now secured properly!
The delaminating traces are not so nice! Hope that it will be possible to reflow new LED´s on the MCPCB at least one or two times before the delaminating gets to bad!
I hope that the delamination was caused by my impossibly hot 80W solder iron, and that normal reflow temperature does not cause it, and that it can handle multiple reflows without problems.
Just to note, I'm concerned about what djozz experienced, but I have worked with the ThorFire predecessor to this MCPCB in the round 1 and round 2 prototypes and didn't have the problem, or at least noticed it. I de-soldered/soldered wires and removed LED's, reflowed others on.
I use my Hakko at about 370C or so.
I used to see SinkPAD and Noctigons exhibit this separation if I went to hot on the hot plate, now I use a hot air station at 370º C and have zero issues.
If temps above 300°C is not a problem reflowing LED´s should be no problem. But maybee someone can test the last batch of MCPCB´s. After all this MCPCB is not cheap or easy to get if damaged.
I've been bad as of late - I've been reflowing LED's with a small torch, heating the underside of the MCPCB. Gotta keep it under control of course, very careful with the heat, but seems to work ok for me. Only problems I've had with MCPCB's has been with the KD ones - not full delamination but on edges of traces, they were pulling up.
True - we should do more testing on these. Not only are they not cheap, but may not be possible to replace directly. Dunno if ThorFire will offer these for sale or replacement. Other MCPCB's could be used of course, but with some modding work I'm sure.
My ledboard is OK, after getting the wires off and on looks good
But I have a modest simple 45W iron.
I meant the threads on the screws.
With two holes - slightly misaligned, as shown in the picture above — notice the oval opening
a smaller diameter screw (as described above) will, yes, fit all the way down through to (barely) engage the threads in the lower hole
and it can be tightened because it’s wedged in, but it is going to be in contact less than halfway around each of the holes and barely engage the threads
It’s just the kind of thing to notice on a handmade sample that shouldn’t happen on a production line where they’d use a jig to align the pieces before drilling and tapping.
I was wondering ( cuz i see little things like that )
If the emitters was turned 45 degrees in their location so a corner faced towards the center hole, would that have a impact on beam profile, or would it just be me overthinking stuff again.
I think your assuming something that is not happening. There are no oval openings, it’s just the shadow thats making it look oval.
Maybe someone can take another picture with the light source overhead to better show the screw holes.
See djozz’s comments on this at
Some Q8 proto3 experiences: I had proto3 with me on a school trip to Amerongen and took it on a night walk to some prehistorical grave hills. An I must say that apart from it being quite a chunk of a light, it is an enormous pleasure to use: tons of light with quite some throw, despite the 5000+ lumen it does not get hot anytime fast, in the open air (21 degC, it was a warm night) after 5 minutes it still is not too hot to hold, the operation is logical and smooth. Here's two beam shots in the …
and at
That would mean that only half the threads are actually engaging with the holes, leaving it very easy to strip by overtightening. Just thinking about eventually modding when better LEDs are available, it’d be better if the parts lined up correctly. They need to align them using a jig, not hand-drilling. If your worried about stripping thd threads you can get some longer screws and maybe some metal washers for the top to spread the load better. Or even longer screws and nuts under the sh…
Since he thinks it’s no problem, I’m happy. I trust his judgment.
Just thinking ahead, I assume any LED is going to be replaced in a year or two with something better, so watching for possible issues.
As he says a longer nut and a bolt would solve any problem.
The shelf is thick enough that there is a decent amount of threading that will hold up to the several times that the ledboard will be screwed down after a led swap.
Btw, with the currently available leds I’m not sure I can think of a better led for the Q8 than what is in these prototypes, the combination of good tint (it really seems 3D to me), great output and even beam profile without obvious tint shift just does it for me, also in actual use. Both 219C and XP-L2 have such low voltages that they will draw way more current than the XP-L with not that much more output, with all the extra stress on the light that cones with that. And the XP-L2 will never give the nice beam profile that we have now.
I’m on the list for one Q8, I will try something high CRI in it but I’m not sure that I will prefer that over the high output proto3.
Could someone let me know the width of the contact ring on the underside of the driver?
I just want to check that the buttons on the Fasttech 30Qs aren’t too wide.
The contact ring sticks out over the plastic, the width of the buttons will not matter. You could ask then why there is a plastic ring at all, apart from that it looks good I would not know.
