I have several Solarforce and UltraFire P60’s in my collection My favorite is the Solarforce L2. I think I paid around $15 for it 4 years ago. Well worth the price.
Mine warms up quite well when left on unattended, like when I accidentally bumped the bottom of the holster on a seat-arm and turned it on. Almost too hot to handle…
If you want to increase heat transfer if it’s a bit lacking, wrap the pill in a little Al foil, or better, Cu foil. Rarely need more than 1 turn, sometimes less. Mine fits in quite snugly, so no foil needed.
I think you saw how i solved it.
Didn’t want to mess with foil and / or sheet (there’s quite a gap to be filled there) and i wanted to lose the spring too.
You see, the head seems to be designed for how i did it, only the bezel doesn’t screw on far enough to push pill and reflector on to the head and tube.
So i messed with the McGyver lathe…
I reduced some overall length too, which is nice.
The only unfortunate thing is the few threads on the tailcap.
Apparently they did that for the screws that hold the clip…
But i think you’d be better off buying a $5 502B host from Fasttech and a $2 empty OP drop in,
put a 6x 7135 105C driver in it and an LED of choice and you’ve got a very nice light for around $12.
EDIT:
Uhm… i forgot the thermal problems…
But hey, that’s the fun of modding, isn’t it?
Okay Matt I got one for ya, no better place to make this post.
Several years ago I picked up an Eveready circa 1937 brass and copper flashlight. I have not yet been able to find the exact model # for the c sized cell version.
I picked it up at a local flee market for oddly enough, 10 bucks. Now you are probably wondering why I am writing this in a P60 thread. Well, in an ahhh-haaa moment I had one evening while looking at the light on my shelf it came to me that I should upgrade the vintage piece. Cutting a long story short, a p60 host fit perfectly after removing the stock reflector and catch piece (both of which unscrew out).
Two small issues plague the upgrade. One I resolved and the second is further complicated by the first resolve. Here is the low down; If you notice in the pictures below i show some rubber washers and the inside of the front of the light. With a small piece of copper and solder I extended the original switch about 1/4 of an inch so that it contacts the reflector to complete the circuit. Unfortunately for the setup to work I had to isolate the drop in with the washers. Not good for thermal management but the XRE emitter didnt seem to mind. I also placed and XHP50 P60 drop-in in it which really made it come to life but will quickly overheat if left on for too long.
The batteries, a single 18650 with rubber grommets or an 18650 + 18350 with grommets worked great to power the light (XRE n XHP50 respectively) with the addition of a tail cap spring borrowed from a mag light.
Also tmart . com sells the Ultrafire C1 host for 9.99. (or used to anyway) Personally i like the C1 alot. There are several variants out there and if you buy one of the 9.99 hosts maybe you will luck out and get the longer front bezel and linear driver capable of powering an XHP50. just swap in two 18350’s and solder in an MCPCB XHP50.
