Difference between Opus BT-C3400 & BT-C3100 v2.1?
You’re still not explaining why the heat is building up and shutting the charger off early in the Discharge cycle—at that point the charger has no idea what size the cell is—I usually don’t read manuals(I don’t have those problems—why would I)—when something gives me too much trouble —I toss them
That is all well and good. But none of it answers the questions I asked.
In addition mine does not do it with 4 x Sanyo NCR18650GA’s…. 3500mAh each.
4 x Sanyo GA’s [3500mAh ea.] = 14,000mAh … Additional 400mAh from the K’powers
What I am asking is quoted again below……
teacher——-I tried to answer you as far as I know from reading here—I thought the first instance of the New problem was when Wolfdog tried the replacement fans—yesterday he mentioned that other 3100 had this shutting down on discharge problem
gauss163—I thought about the IR after my last post—most of my cells are low resistance—as far as ambient temp—I have mentioned my wife keeps this house like a meat cooler—-one of the things I see is—all of his chargers are/maybe coming from the same lot
the only way I could make my 3400 replicate the first discharge/charge reset was to use my Littokala 2amp PS—-with this PS as soon as you tried to charge 4 cells @ 1 amp it reset
I understand teacher! Your charger is just like King Opus that I killed,It has NO issues,be grateful. I have had 2 chargers that could not handle 4 x 18650,that is why I am determined to get this one or another one working like it should.
The results I post later will show the difference b/w 3 or 4 batteries discharged when you have a charger like the one I have now. Lastly, Jon only discharges 3 batteries at a time because of this issue and the other[reset] that I mentioned in a post yesterday!
HKJ and I have been exchanging emails/photos of my board. He has been tremendous help in pin pointing the destruction of King Opus. I will post that later.
My fans are in the mail to Dale! :+1:
I am testing 4 X 30Q Now,10 cycles only,basically new. I will find out soon enough if it stops or if it can handle 12,000mAh. It could not handle 13,600mAh[4 x KP 3400.
_
Although not mind boggling this will give you an idea what the difference is in charging 3 X 18650 3400 VS. 4 X 18650 3400. Same KeepPower batteries.
I believe this is evidence that numerous stoppages during discharge directly relates to over blown and inaccurate capacity readings.
- 4 X 18650 3400mAh Keeppower-Numerous stoppages ~15 lasting 90 sec. to 2 minutes.
Four slot median:3278mah
Average time: 3h55m
–3 X 18650 3400mAh KeepPower
Four slot median: 3096mAh
Average time: 3h3m
Difference: 282mAh and 52 minutes longer for the 4 x 18650 3400mAh
Obviously the stoppages ADD time and the also add mAh because as the battery rests, the voltage goes up ~0.03v to 0.06v and that is measured AGAIN!
The solution, other than what I am trying to do[Delta destroyer] is to do what Jon does and only put 3 batteries in!! I can not accept that,at least now I won’t!
And a stellar job you did my Louisiana friend. :+1: … :slight_smile:
Thank you. :wink:
All I was attempting to ascertain was when the heat problem was first noticed as wolfdog has now mentioned it has happened in 3 of his 4 OPUS chargers.(1)
“I” did not recall any of that being mentioned until the last day or two.
  • So I was trying to determine if this had been an occurrence all along and just not been mentioned OR if I had missed the mention of it in all this vast quantity of material. :slight_smile:
Nothing more nothing less……. :slight_smile:
(1)
How do I get a hold of him. More than a free Opus I would like to know if the Resistors Q18 and 1AMh can handle using my Delta 12v/0.12a/1.44w fan.
These lie directly behind the plug of the fan on the back of the board.The white piece of plastic is for the plug insert.
I had to get a magnifying glass to read them. HKJ worked with me over 1 hour telling me what to look for and I took some pictures.
1AMh resistor is the one that HKJ was not able to find info. on. His guess is the fan would be ok.
Q18 and 1AMh
Not resistor, but transistor. There is a significant difference between the two type of parts.
I asked about the SMPS. I am not sure who replied. Let me locate the email.
Sorry,no intention to make you look bad!
How do you like the improvement on the pictures?! :+1:
I do not know what happened. About 7 of my folders disappeared with all the emails in them. :frowning:
EDIT: The folders are there,they are just empty.
I did not expect you where, you are just not an electronic guru.
They are very good, the transistor is probably this one: http://www.onsemi.com/pub/Collateral/MMBT3904LT1-D.PDF
It can handle a bit above 2W at 12V
Probably some “double naught” spy after secret OPUS information…… :wink:
Seriously that sux… :person_facepalming: … :frowning: …
I hate to think it that happened to me. It might be time for me to learn how to do a backup. :open_mouth:
That technical stuff[specs] is out of my league!
Can it handle my delta fan?
MY 4 X 30Q are almost done. It looks like the first success out of Four tries. The other 3 failures were [1]KP and[2] Orbtronic 18650 3400mAh
No STOPPAGES and the discharge is @ 3.15v! NOW it must be accurate like king Opus who had his funeral today!
Good detective work Gauss! I will send him a detailed dissertation tomorrow w/ links, Pictures and data.
You fan was about 1W, two watts it more, i.e. it can handle your fan (but not any shorts).
The more I think about this chops the more I like it! You know, being preventative and all…………. :wink:
I am gonna see if I know anyone who knows anything about 3D printing…. cause I sure don’t. :smiley:
4 X 30Q Were a success! NO STOPPAGES.
These are the same batteries.
ALL DISCHARGES ARE AT 1Amp
King Opus on April 3, 2017-3 cycles
Newest OPUS. Today-Batteries have 15 cycles.
ALL 1Amp discharges
HKJ-2884mAh
King Opus-4 slot ave.–2910mah
Newest Opus-4 slot ave.–3009mAh
100mAh difference. But you see why I love King Opus. Out of the 4 chargers it was the most consistent and was closer to HKJ’s numbers than the other Three.
RIP King Opus
:cry:
:+1:
:+1: :+1: :+1:
Almost 1.5,but still safe!
