Thermal Compound - Results Posted
51 posts / 0 new
NeutralFan
NeutralFan's picture
Last seen: 12 hours 15 min ago
I recently learned about the best way to apply Thermal Compound. Previously I thought spreading the thermal compound on the entire bottom of the LED MCPCB (surface spread method) would be best, but I learned that using a small dot of thermal compound (middle dot method) is better since air is not trapped with that method.
I modified a Convoy C8 not too long ago and it bugged me that I applied the thermal compound the wrong way. I didn’t want to have any issues with the flashlight so I thought it would be prudent to re-apply the thermal compound the correct way.
Before I re-applied the thermal compound, I took some temperature measurements with a fully charged Samsung 30Q battery:
  • Start – room/flashlight temperature at 67 degrees Fahrenheit
  • 1 minute – 84F
  • 2 minutes – 95F
  • 3 minutes – 104F
  • 4 minutes – 113F
I disconnected the wires and removed the LED MCPCB. It was really stuck in there, but eventually it started moving and I was able to pull it out.
I cleaned-up the thermal compound with Q-tips and rubbing alcohol. I then used the middle dot method by putting a small amount of thermal compound on the flashlight shelf.
I put the LED MCPCB back on the shelf, pressed it firmly and twisted it slightly back and forth. As you can see the thermal compound oozed out the sides affirming that I used enough. I then screwed the LED MCPCB back into place and re-soldered the wires.
I charged the battery to full and took the temperature measurements again:
  • 1 minute -
  • 2 minutes -
  • 3 minutes -
  • 4 minutes – ???
Your predictions? What do you think the ending temperature will be at 4 minutes?
I will reveal my results on Monday.
I’d rather use my flashlight around the house than turn on the lights.
Edited by: NeutralFan on 05/22/2017 - 20:41
Barkuti
Barkuti's picture
Last seen: 26 min 17 sec ago
I foresee no discernible difference within error margin.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
tekwyzrd
tekwyzrd's picture
Last seen: 13 hours 7 min ago
113°F
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
jf_smm
Last seen: 18 hours 54 min ago
114 Wink
Enderman
Enderman's picture
Last seen: 16 hours 8 min ago
Probably very little or none unless you’re running that LED at 6A+.
Lexel
Lexel's picture
Last seen: 10 hours 56 min ago
if you measure the body temperature no difference as the power dissapation is the same
on the MCPCB no real difference as with spread or place it in the middle
the contact surface is >90% even with bubbles when you spread it
you would need a good IR camera to measure the close to the junction of the LED to get thje difference that matters
30K junction difference can be from DTP to non DTP star, even if all other mesasurements are the same
Henk4U2
Henk4U2's picture
Last seen: 21 min 49 sec ago
Look at the top right picture. The distribution of the thermal compound is uneven. Seems like your MCPCB is a bit convex. I always flatten my MCPCB on a lapping stone before I put it in. No lapping stone? Use fine sandpaper on glass pane.
When your MCPCB is flat, you will have trouble removing it from the shelf. Because of the vacuum under it.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
thijsco19
Last seen: 20 hours 4 min ago
110°F
Just a small improvement.
LightRider
LightRider's picture
Last seen: 2 years 2 months ago
thijsco19 wrote:
110°F
If it’s an improvement the temperature should be higher
NeutralFan
Henk4U2 wrote:
Look at the top right picture. The distribution of the thermal compound is uneven. Seems like your MCPCB is a bit convex. I always flatten my MCPCB on a lapping stone before I put it in. No lapping stone? Use fine sandpaper on glass pane. When your MCPCB is flat, you will have trouble removing it from the shelf. Because of the vacuum under it.
The LED MCPCB was really stuck on the shelf. At first I wasn’t able to move it at all. I used a popsicle stick on the edges and with a lot of force I was able to gradually move the MCPCB. And then removing it was equally as hard. I didn’t notice any unevenness between the MCPCB and the shelf.
kennybobby
kennybobby's picture
Last seen: 2 hours 6 min ago
Thermal compound is intended to fill-in the microscopic valleys in which there is no metal-on-metal contact—less is actually better, as too much will act as a thermal barrier. As mentioned above the best fit is when the two surfaces are dead flat which maximizes the metal to metal area.
Looking at the cleaned-up photo above you can see the center lathe tit—that needs to be removed with a file or grinding stone at the very least, then lap both surfaces with a whetstone. Then apply a drop of thermal grease to both surfaces, spread around and then wipe if off with a flat straight edge—this will leave grease in the microscopic valleys and expose the metal tops.
Good luck with the testing it is very interesting.
Favorite Song = "Flashlight" (BLF of course, with a righteous bass)
https://youtu.be/gCTGMIXaD64
Exercise and Training:
My typical training routine: https://youtu.be/_aVASp9raMk
Morning Workout: https://youtu.be/ZEA_3yXG570
Remember Don't Do Drugs...
without me: https://youtu.be/oVKtxHTcnho
Jerommel
Jerommel's picture
It’s better to put a blob in the middle that will spread out when you put the parts together.
This avoids air pockets.
Jerommel
Jerommel's picture
Indicative of a good situation.
Jerommel
Jerommel's picture
LightRider wrote:
thijsco19 wrote:
110°F
No, because when the thermal path is good, the LED will get less hot and have better efficiency and thus produce less heat.
The heat that it produces either way will eventually end up in the body, so with a bad thermal path the body will get hotter anyway.
Enderman
Enderman's picture
If he is measuring the body temperature of the flashlight then the temperature should be greater because more energy is being transferred to the body.
The better the thermal path, the higher the body temperature should be and the lower the MCPCB temperature should be.
It is not possible to have the two be the same temperature, there will always be a delta T between them.
Better thermal path = lower delta = less energy in MCPCB = more energy in body.
More energy in body => higher temperature => larger delta T between body and ambient air temperature => more heat dissipation.
Jerommel
Jerommel's picture
When the LED produces more heat, the body will get warmer too, because the heat has nowhere else to go, albeit through a bad thermal path.
Of course.
The higher the delta T, the more heat will be transferred.
Texas_Ace
Texas_Ace's picture
Last seen: 4 days 16 hours ago
Ditto the rest, there should be no measurable difference in the body temperature. The exact voltage that the cells are at and the exact resistance that the switch had that time around, among other things will play a bigger role if I had to guess.
When I tested thermal paste, I found that as long as it is there and squished reasonably well,the performance is goning be too close to notice.
dchomak
Last seen: 2 years 1 week ago
You’re right that the delta T will be higher with the poorly applied thermal compound. But so will the thermal resistance.
Those that predicted 113 degrees know that the flashlight as a whole will eventually drift towards thermal equilibrium, and they are right. Energy into the light HAS to equal energy shed. That energy is the sum of heat and the energy of photons emitted.
Take it a step further and as the LED gets super hot due to the poorly applied compound, it will draw MORE current. Also as it gets hotter it will become less efficient. An even greater percentage of the energy input will be heat.
As I type this I can’t remember if the driver is constant current or DD.
For the better thermal path, my prediction would be temperature goes down, slightly.
eebowler
eebowler's picture
Last seen: 6 days 21 hours ago
neutralfan, did you press down on the star and gently twist side to side (45 ish degrees,) when applying the new set of thermal paste?
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
Enderman
Enderman's picture
Assuming it is DD, the energy will be the same in both cases, regardless of good or bad thermal path.
The difference is that when it has a bad thermal path then more heat remains in the MCPCB and less transfers to the body.
The total energy dissipated is still the same, but there is more energy stuck in the MCPBC than in the body (compared to a good thermal path, where the energy can easily transfer from the PCB to the body.)
Since the MCPCB has a lot more energy and doesn’t transfer as much to the body, that results in a higher temperature at the PCB.
In the opposite case where the thermal path is good, the temperature difference becomes less, so the PCB and body are closer to the same degrees.
That means the MCPCB is cooler and the body is hotter. (but the MCPCB will always be at a hotter temperature than the body)
dchomak
Enderman,
IF it is assumed that the energy input is the same for each case, and we disregard the decrease in efficiency of the LED at higher temperatures, then the body of the flashlight will be the same.
You are right, there will be a higher delta T, but there will also be a higher thermal resistance, so the heat flow will be the same! (Double the Voltage and Double the Resistance in a simple circuit, and electron flow is the same)
Enderman
Enderman's picture
dchomak wrote:
Enderman,
What the heck are you talking about?
This has nothing to do with voltage or current.
If you have 1kj of energy on a piece of copper with a bad thermal path to a chunk of aluminum, the copper will be much hotter than the aluminum.
If you have a good thermal path, the copper will only be slightly hotter than the aluminum because the energy will transfer between the pieces easily and equalize.
That means the copper temperature decreases and the aluminum temperature increases.
Think about it as two buckets with a tube running between the two.
Jerommel
Jerommel's picture
But the heat will be more because when badly cooled it will produce more heat and less light.
Only for a short while, until delta T is large enough to ‘force’ heat dissipation to the body. (it’s got nowhere else to go)
So in this case delta T is comparable with voltage. make it high enough and the ‘heat current’ to the body will be high too.
rdoc613
Last seen: 1 year 9 months ago
Well, first off, where did NeutralFan take the measurements? I don’t see where in the OP he states the location. If it is the outside body, close to where the shelf contact is, then with better heat transfer you would think the outside body would take on more heat, keeping the MCPCB cooler in the process. I’m guessing it will be slightly hotter but I doubt it will be noticeable.
Cool project though, you sound like me. I always want to do things as efficiently and effectively as possible, the first time.
Enderman
Enderman's picture
Makes sense, either way I still think it’s not enough heat to see a measurable difference, unless hes driving that LED at 6A+ or something like that.
Jerommel
Jerommel's picture
@ rdoc613:
The LED produces heat and light.
The heat has nowhere else to go then to the body.
So, the efficiency of the LED basically determines the heat going to the body.
The efficiency suffers when there is a poor thermal path (high delta T) because the LED will then operate at higher temperatures.
At a certain point (saturation) the delta T is high enough to stop the LED from getting even hotter and thus all of the generated heat will be transferred to the body.
Jerommel
Jerommel's picture
I don’t know how big the difference in efficiency between a properly cooled LED and a badly cooled LED can be.
NeutralFan
When I put the LED MCPCB back on the shelf over the thermal compound, I first slowly pressed down evenly and gently. Eventually I pressed hard and slightly rotated the MCPCB clockwise and counter-clockwise by approximately 5-10 degrees.
Enderman
Enderman's picture
Well unless you push an LED pretty far, it seems like the difference isn’t very significant:
http://budgetlightforum.com/node/53514
NeutralFan
I took the temperature measurements using an infrared thermometer. I pointed it at the body of the flashlight and found the hottest spot. The flashlight was tail standing in turbo mode. The hottest spot was near the top of the head, just below the bezel.
Enderman
Enderman's picture
You should use a thermal probe attached directly to the copper MCPCB to get a useful reading without all of the thermal variables discussed above.
