Hehe what kind of high did you get from smoking the springs
The Miller could you put me down for a 3rd one? Thanks!
That’s the definition of a sunk cost. People have great difficulty letting go of those, but it’s important not to let them tie you down to sticking with a bad decision.
Looks like the rush to get batteries is premature…
That’s true. But, in this case, I happen to think shortening the tube is a better decision in almost every way, and the “sunk cost” NOT becoming an issue is just one of the many reasons. :innocent:
Asked Thorfire if the smaller of the double springs can be made 2.5 to 3m taller so even short cells connect with them both.
mm i hope
This might explain the unexpectedly high readings of the protected GA cells tested.
That would make them connect to the ceiling
This flashlight is already perfect. I can mod my flahslight and bypass the springs. Can I have it now in this form? I need it now. How about a presale groupbuy for those like me who dont want to wait another month or two (or 3 or 4 or 5) till it is perfect?
This should not take very long
If my measuring is correct 2,5 mm longer small springs should connect having both springs take current and temp.
Or another solution with the springs for that does not require design changes on main parts.
I would just bypass springs so no problem with current and temp.
Is there option to do it in factory?
Maybe n my old SRK, two of the springs were shorter right from the factory. It was easy to work around by putting a magnet on the bottom of those two cells. Maybe short cells should have a similar spacer when used in this light?
Because one of my proto3 springs was toast anyway, I decided to replace them all. The only springs that I had that were the right size and nice stiff were my phosfor-bronze ’djozz’springs, so they went in:
This is how it looks now (VTC6 batteries, same length as 30Q’s) :
The batteries sticking out over the (shortened by a few mm!) tube so the springs are compressed well, and enough travel that long cells fit too.
Because phosfor bronze has one-third the resistance of steel, the out put went up too (not neccessarily what I desired), on VTC6 batteries 6130 lumen now (30 seconds). My 30Q’s are in the charger now, numbers with them later.
Oh that is nice Djozz!
So hope it is good with this solution!
I hope that Thorfire is willing to source beefier springs, my springs btw are 10mm base diameter, 15mm height (13mm after the first compression, it stays 13mm after that).
We could show Barry the above picture with the VTC6 batteries.
If you get the same or better lumens, please mail these pics, they fit, require 1 solder action and only 1 spring instead of 2.
I get better lumens but the output can not be compared, these springs are made from phosfor bronze which has 3 times less resistance than spring steel. What we can only ask for are steel springs with these dimensions, so they will give less output than these. Asking for phosfor-bronze springs of these dimensions is useless because they are not readily available in China, this was one custom batch made by an Amsterdam spring manufacturer.
But considering that my output numbers of the proto3 when it was still stock were done with the small inner spring not engaged, using a bigger steel spring will give similar numbers (the thicker wire will compensate for the longer length of the wire).
Charger was ready, output on 30Q’s is 6200 lumen now.
How hard would it be for them to move the driver board back, either by shimming or not machining as deep?
