I would think so. What I did with the 47 was strip it down to just the shell and clean thoroughly then with the head & body together I put a rod through the head opening and held it over the gas cooker.
This was my first attempt so I don’t have much advice on the technique except to heat the light evenly and remove from the heat before the desired colour as it will continue to change for a few seconds.
The colour changes progressively from left to right, it was the far left colour I was actually aiming for…
Thanks mate, you know how I like stupid emitter/ host setups
It was originally an XHP50.2 but it killed itself, worked out fine though as I love the MT-G2.
I do my Ti coloring a bit differently. I gut the light, run a section of all thread through it and using a washer top and bottom I snug it with a nut on each end. Then I mount the all thread in my drill press and use a propane torch on the Ti while it’s spinning. Easier for me to get a more uniform heat build up this way.
I’ve had the MT-G2 in so many small lights it’s ridiculous! lol A chopped Mini Mag was probably the smallest, using a pair of IMR 14250’s.
