^ That should be purchasable where you live.
German is the closest Amazon store to me, but shipping is the same as the adapter. For know I have put it in my basket and it will have to wait until I need some more stuff from Amazon.
Any news regarding it?
Not yet, I have not needed anything else from Amazon yet.
I didnt get any response last time, so I will just quote myself
Any chance of testing this very cheap (costs like $11) and versatile powerbank Aili 119 (6Ć18650 not included): http://www.ebay.com/itm/20V-Mobile-Power-Bank-UPS-6-18650-Battery-Charger-For-Laptop-Iphone-Universal-/321866773183
Beside usb output it has options to adjust output voltage from 3,3V to 21V (up to 3,3A) so that it can also be used to charge laptops. I bought this one after I read a review where the writer claimed very high efficiency when charging laptop and average when using usb output . If this test is out of the question for you, can you please take a look at the methodology of this russian test and if its even theoreticly possible that boost from 9-12V to 20V is realized with such a high efficiency (97% ?). Thank you!
Link to the test: http://review-china.com/aliexpress/8488-.html
Translated into english: https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=\_t&hl=sl&ie=UTF-8&u=http%3A%2F%2Freview-china.com%2Faliexpress%2F8488-.html&edit-text=
I do have a couple of power banks in queue, I may even drop some of them because they are getting a bit old.
I have bought one of these and hope I get it tested.
Sorry, I cannot do better, but I usual buy a bit more than I have time to test/review.
How about the strange shaped usb power monitor.
John.
I have ordered the above two devices.
The usb supply will be reviewed, but at that price the most likely outcome is a couple of skulls . I hope the result will be better, but I doubt it.
I hope to get enough time to test the tester, it looks interesting.
Linking is hopeless, either I do raw html or I get errors or I answer my own posts, It looks like the above link works.
The problem is special characters like space, it is sometimes %20 and sometimes just a space, when doing links this often ends up in a non working result.
When doing raw html (Like in my reviews) there is no problem, but the editor tries to be smart and this do not work well together with me
http://www.gearbest.com/nillkin-adapter-_gear/
http://nillkin.org/accessories/chargers/
Asked GearBest staff about this strange āNillkin Travel Power Adapter Dockā, as in the advertisement āSupport 2.0A Quick Chargeā is claimed.
Synopsis:
ā¦
Your original question is "Is this a Qualcomm Quick Charge compatible charger? 2.0? Specs seem strange, what's the difference between this charger and http://www.gearbest.com/chargers-cables/pp_488880.html ? Thank you. Regards, Salvador"
Here is the answer from Our Customer service Team:
Hello Salva,
Yes.It's Qualcomm Quick Charge compatible charger 2.0.
" ā¦
Weird.
Weird.
If it is this one you mean: http://www.gearbest.com/chargers-cables/pp_630687.html
It looks like the quick charge is only a reference to 2A current capabilities, not to any QC standard.
8x18650 power bank with adjustable dc out. Does not come with batteries. The construction looks cheap as hell, but Iām interested how would it fare in your tests.
Or would it be too similar to the 6x18650 Qidian you tested earlier?
āQidian QD188ā:61.11ā¬ |Neue Vesion Spannung Regulierung QC3.0 QD Laptop Power Bank ADJ. 18650 batterie Box QiDian 8 Abschnitte Typ C PD Batterie (QD188PD)|laptop voltage regulator|regulated powerbattery box - AliExpress. 8x18650 power bank with adjustable dc out. Does not come with batteries. The construction looks cheap as hell, but Iām interested how would it fare in your tests. Or would it be too similar to the 6x18650 Qidian you tested earlier?
interested too... and i was about to provide the same link on aliexpress, but than i saw maukka had already provided everything
Got it today. First impressions are good. With 4x NCR18650B I got 40.5 Wh out of the DC output at 12V / 2A. Thatās about 90% efficiency.
Oh... Lol... So you didn't wait his review...
I know you have quite an impressive equipment for testing color rendering, but I do not remember if you have an oscilloscope... Maybe yes, I recall some rigor stuff,too lazy now.... Sorry...
I was curious about the Vripple, on load, V drop etc...
Voltage drop
USB1
No load: 5.32V
0.5A: 5.26V
1.0A: 5.20V
1.5A: 5.16V
2.0A: 5.11V
2.5A: 5.07V
Shuts off above 2.7A
USB2
No load: 5.27V
0.5A: 5.16V
1.0A: 5.09V
1.5A: 5.04V
2.0A: 5.00V
Shuts off above 2.4A
DC 12V (voltage measured after bundled cable at a dc-adapter)
No load: 12.09V
0.5A: 12.02V
1.0A: 11.96V
2.0A: 11.84V
3.0A: 11.71V
DC 5V
No load: 5.09V
0.5A: 5.03V
1.0A: 4.94V
2.0A: 4.79V
3.0A: 4.65V
Couple pictures from the inside:
Voltage dropā¦
Nice THANK YOU. I see you were able the push out 35W at ~12V... Nice there.
I wonder how close can it get to The "Chinese specs" that claim 60W @12V? 80W @16V
And between 88 and 89.7W theoretically for the other voltages.... Hmm... Seems an impressive piece of kit.
Also did you manage to test other random custom voltages at no load or at load?
P. S. ... Nevermind , Sorry This post became strange asking too much... Don't worry thanks for the thorough infos you already provided.
Could have probably done more than 35W, but didnāt want to push it with just 4 batteries.
