For the D size maglites there are holders which will take 3AA cells in parallel to make a single D size cell, this is a good option as it allows the use of AA eneloops.
For a light when working, you can’t beat a headlight. I am very happy with my skilhunt H03 but there are many others to choose from just as good (and maybe better)…
If you can wait for some time you might want to have look at the Q8 beeing designed on this forum. It is/will be a very strong and bright flash light capable of long runtime in the lower modes.
Both suggestions work on LiIon batteries. If you have frequent power outage for longer time then Liion might be the way to go.
I was thinking the same thing: working on a farm — headlight. I too like the SilkHunt H03. Some people don’t like the fact that the LED is off center, but it doesn’t bother me. It does take a 18650 Lithium Ion battery.
C8 (Convoy C8 or ThorFire C8S)
These are great little flashlights. Lots of light and affordable.
Battery: 18650 Lithium Ion
Review: ReManGstephenkcmflippen
ThorFire C8S on Amazon
Convoy C8 on Convoy store
ThorFire S70S or Convoy L6
If you like the size and heft of the MagLight you will like these two.
Battery: 2x 26650 Lithium Ion
Review: RobertB’s S70S and lumenzilla’s L6
If you want to stay with non-Li-Ion batteries I would look at some of the 4x AA lights. These would include:
O, man. Actually you need GenSet with AMF panel and ATS.
Better diesel one, not gasoline.
OK, it does not change flashlight need.
My suggestion is:
18650 battery;
Neutral or warm white;
build USB charger;
tailcap swhich;
pocket friendly.
Eagle Eye X2R,X5R,Thrunite TN12, TC12 are some options.
As far as a M@g style torch goes, if you’re willing to have some dosh invested, you really, REALLY can’t go wrong with the Convoy L6. As far as headlamps go, you could get the aforementioned Thrunite TH20, or if you demand more power or efficiency, get a Convoy S2 (fits most 18650s, protected or not unlike the S2+, and has a good general purpose beam) and Convoy’s head strap.
If you need a thrower, take a look at the Convoy C8 and L2. I think the L2 will suit you better since you’re on the sticks as you mentioned; the C8 doesn’t go farther than 200m unless it’s modded into a pocket rocket, and that’s more expensive.
The Thorfire S70S would be great for watching the property. I don’t know if you are allowed to shoot Coyotes or not, but if you get a C8 with an XPL-HI emitter in it, you could mount it on a rifle real easy and pick off those coyotes. If you really wanted to get serious about shooting coyotes Maxtoch makes the 2X Shooter in Red . Red doesn’t seem to scare off coyotes like a white light might
Don't you love it when a newbie comes and receives 30 different suggestions (that are all decent)?
You are willing to learn about lithium-ion cells safety, that's great because most of the powerful lights use them (either 18650 or larger 26650). Your budget is more than necessary to buy a quality light, charger and spare batteries. If you want a larger handheld light then you will be happy with Thorfire S70S or Convoy L6 previously mentioned, they're similar so whichever you like.
The C8 from Thorfire or Convoy are much smaller but still extremely bright compared to any old light you might have, however the beam is tightly focused (good range outside, can be annoying indoors).
Headlamps are useful to keep both hands free but then your wife may want a club to hold onto :)
Go for the Boruit. I got a few of them, they’re cheap, they’re handy, and even with the lowest level of light they’re perfectly usable, and will run almost forever. Even at its highest it’ll run on a fully-charged cell for probably 3hrs. Pull off the elastic thingies, and you can hand-hold it just fine.
Flood? Convoy S2+. The 4C tint-bin is nice.
Thrower? Convoy C8 w/ XP-L HI.
Überthrower? Convoy L2.
Nice EDCs? Thorfire VG10, Zanflare F1.
Small/Keychain? Jetbeam Jet-I. Takes an AA.
Smaller? Astrolux A01, ODEPro EA01, BLF348. All take AAAs.
Slightly bigger 26650 lights w/ more runtime? UltraFire DV-S9 and F13.
Wouldn’t have thought so myself until he mentioned spending some pounds.
My money is still on a 3D cell MagLite ML300LX using 3xAA to D adapters for eneloops or just alkaline D cells. Will be bright enough for 95% of things, durable, use common cells, and double as a club in a pinch.
I love super bright lithium stuff as much as anyone, but for an emergency light you just can’t beat something that uses cells you can find at your local supermarket.
Yeah, the more that I think about it, the Maglite ML300LX with adapters or Nitecore EA81 I think are the best options. The EA81 would also qualify as “super bright” for most people. It’s able to sustain ~2000 lumens while having 5 modes including Moon. No need IMO to switch to a lithium if they really only want 1 emergency light.
Another cheaper option is the energizer 6xaa 900 lumen triple for $20 at battery junction. I have one and for $20 can’t beat it. Has three tir optics two for throw one for flood. Works great and would fit the bill. Big enough to be a club and great for emergency. You have high low and strobe. High 900 lumen for 3 hours I believe. Low is 400 lumens. Strobe is hidden have to double click
