You have made three nice lights ltp. Iāll have to take them out for a test drive next time Iām up.
Whats next on the agenda? I know Rob wants a bike light.
not a patch on your workmanship. you have set the bar way high mrsdnf.
I have a quad to build and that will be it for a while
but I need to plant some oats first.
Iāve got a c8 in the shed rob can have.
You are far to modest ltp.
Very nice indeed!!! :+1:
So the sickness continues
Assembled a few parts from kd driver from lexel
some ally I had and some kindly donated by Mrs Dnf.
this wont make sense as I have just uploaded the finished product
due to photobucket issues
recess for driver and battery tube
tech specs. 3 xpl hi ta/lexel/ bistro driver single 26650 powerā¦
Very nice, I like these :+1:
Looking good and looking forward to Sunday morning. Is your mum going out Saturday night to someones 80th?
no idea.see you sunday,
thanks for the kind words guys
This is coming along nicely Ben.
I was good to catch up for brecky yesterday. Short and sweet.
Dad is still talking about his new custom built light you gifted him yesterday. Cheers.
With those fins you should be able to get rid of a lot of heat ok.
What size thread do you cut lostheplot? I find the bigger the thread the easier it is to cut neatly.
I use 1.25 pitch
Have just bought some hss to grind my own tools as my external tool
(cheap ebay) doesnt have any rake.
I use a carbide tip job from banggood for internal
ok so finally done as had to wait for some 3 mm taps from ebay
battery tube is 5mm thick and 10mm where it bolts to head clamping the driver in position
bezel is bolted with 3mm studs and acorn nuts
pictured with c8 and srk
the shed 60 metres
the quality control comitee at about 50 metres
thanks for lookingā¦lastly the lexel ta driver runs just over 11amps into the 3 by xpl2 leds
so I guessthats around the 3000 lumen
thanks for the tip but it is not wanted
Thats one fine looking light ltp. What reflector and led did you use and was the three mm tap any good you bought of Ebay?
this is the reflector which I trimmed to 50mm dia
http://www.kaidomain.com/p/S021812.52mm-D-x-26mm-H-SMO-Aluminum-Reflector
slightly bigger than the srk one and a bit deeper
the leds 3 x xpl v2 hi 5000k
I am actually fairly happy with this light ran for 10 mins on high and still no ware near getting to hot I think the battery will go flat before heat becomes a problem
as it was down to 3.9v after 10 mins
the taps I didnāt break them
:+1: Thanks.
so this will be my first build with my own reflector.
picture with a c8 reflector I used for profile.
machined some chunky fins and thread and a bezel /pill.
my knurling skills suck today just couldnāt get it right
tail cap to go and then some assembly will be using xml2u4 1aā¦possibly a single mode driver or a biscotti
Are you going to dedome the led?
