That is something I tries very hard to do. Not that I will write stuff in a non-technical way, but I try to limit the technical jargon a bit.
And sorry about the links in my last mail, I used the wrong syntax, it is fixed now. I give up on links in answers, spaces do not work (I am too lazy to do my answers in raw html, anybody that want to see where my links leads to simply replace %2520 with a space in the link).
The general problem is that spaces in links do not work and when posting links from the browser where spaces is replaced with 20 the board replaces that with an escape for the sign (%25), instead of accepting it as a code for space.
HKJâYou are true one of a kindâ-your countless reviews and post have helped so many peopleâI enjoy reading your reviewsâvery informative to every oneâââââââ-Thanks
teacherâI didnât forget youâgreat way to sum it all upâare you the guy around the camp fire that keeps the two drunk friends from fightingâLOL
gaussâŚ. :person_facepalming: ⌠Iâm not ragginâ on you my friend. But this is what I am talking aboutâŚ. I even âtriedâ to look it up. . No joyâŚ
Given, I am not the sharpest knife in the drawer⌠but this sounds like it came straight from a Jargon Generator ⌠:weary:
Meta-level tangents = ĺ ç´ĺçˇ âŚâŚ. both of these mean about the same thing to me.
Your gonna have to try and âdumb it downâ a bit more or at least provide a link so I can find out what you mean when you write something like thisâŚ. please.
Maybe that is how I learned how to use forumsâŚ. but at this rate Iâll never know for sure.
I just completed a trivial test with 3 chargersâ- 3100 / 3400 / Liitokala 500
With a 3 cell group of NOS laptop pulls that were charged and matched a year ago on the 3400 ( didnât want to abuse good cells)
My conclusionâthe BT-3100 mah reading is around 5-6 percent higher than the other 2 chargersâThe 3400 and the 500 test fairly close on averageâamazing considering the Opusâ discharge @ 1 amp and the Lii 500 @ .5 ampââ When you compare the readings as a group,then figure their percentage matchâall 3 chargers are very close in that regardâ- this set of cells with all 3 chargers is around 4% matchâ Not sure why there is #1 cell that is a flyer ( target term) but the overall average is pretty consistent
I love the UI of the Opus, but I feel like itâs worth the price point. I constantly get ghost battery indications (screen reads FULL after I take the battery out), bad voltage readings (full battery reads 0.2v), the fan has been giving me trouble for 2 years and just died, and one of the negative terminals snapped off so Iâm left with 3 slots.
So Iâve heard that the newer Opus chargers have fixed these issues, but it makes me wonder if I should just invest in a higher priced charger
